Squeaking noise from passenger side
Old Aug 31, 2012, 01:44 PM
timnan's Avatar
Hello everyone,
I have 2003 Lancer which I bought second hand on 2009. Same year the timing belt was replaced in a garage close to my school.
From 2010, my Lancer started making very small squeaking noise and then getting louder and louder. It happens every time I start the engine but after running several minutes the noise disappears. If I turn the AC on, the noise is more obvious. When I drive the car for about ten minutes there is no noise until next time I started it again. The noise kept annoying me for about 1 year and half (2011), one day the serpentine belt broke but not completely (half way), so I still can drive it to a garage. My mechanic changed new serpentine belt for me. Everything looks ok since then.
Recently (Aug 2012), the noise is coming back again. The noise still sounds not strong but definitely same as the one it does last time. I am just worried about the belt would be broken when I am driving.
So my question is:
What is the noise from?
Do I need to change the belt again? How often should we replace this belt?
Also, when the car pass through some water filled pits, the car will make really big noise, this happens after a mechanic did alignment and replaced tires. Please advise what problem is it?
Thanks for your consideration. This car is important for my family.
Old Sep 2, 2012, 11:51 AM
QuikSlvrLancer's Avatar
The belt should be replaced every 60k miles i have heard. i just did mine today for the first time at 86k. The noise got worse when it was wet.
Old Sep 2, 2012, 05:45 PM
timnan's Avatar
thanks.
the new belt last less than one year and I just run the new belt for 8000miles.
so I was not sure if this is because the belt.And the belt still looks new.
Old Sep 5, 2012, 11:30 AM
Green_Bandit's Avatar
I know other things that make more noise when wet. OH!
Sure the belt is tight enough? A one year belt shoudnt squeal any. Maybe when it's damp but not really at all.
Old Sep 10, 2012, 09:09 AM
timnan's Avatar
Yes. I just found that if it is sunny day I will not hear the sound. But if it is cloudy or moisture I will hear it. It is weird.
va1k0s
May 31, 2016 10:36 AM
va1k0s
Mitsubishi TC-SST Discussion
May 19, 2016 07:57 AM
delta6force94
Oct 31, 2015 08:24 AM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
cedes14bamg
Lancer Engine Tech
Nov 9, 2010 07:11 PM
Quick Reply: Squeaking noise from passenger side
