02 es
02 es
Well to start I hope there is someone out there that can help me.
A couple of days ago my es was running quite rough and then it died at a red light, I had it towed home and took off the timing cover and everything looked to be on time and still tight (no slack or slip) I then changed all plugs and wires and coils, I have taken off the top end of the motor and making sure that it wasn't seized or anything broken. and then put everything back together and tried again. and it seems like it just turns and turns and turns, no fire it sounds like its getting some kind spark but wont completely fire and run. I am completely lost and running out of ideas. I am praying that someone on here will be able to give me some ideas to help
Sounds like the timing is off. Start with a compression test. If its low then its probably the timing belt. Please tell me you replaced the Head gasket and properly cleaned both block and head surfaces? If not you may have a big problem. Check your electrical too make sure you connected the cam and crank sensors.
URNVS
Jul 16, 2014 01:48 PM
gallant
Apr 11, 2014 08:21 PM
