2004 Lancer ralliart keeps blowing fuse #1 in the dash -no start issue
Old Aug 24, 2014, 03:43 PM
ivkata's Avatar
Hello
and thanks for taking the time to read my thread .I just purchased 04 ralliart that died on the highway and will not start.The seller and i initially tought that the t-belt broke but thats not the issue.I have good compression across all a4 cylinders but there is no spark and no injector pulse.All fuses in the engine compartment are good ,all engine related one have power with key "on" .Fuse #1 in the dash was blown and will blow right away if replaced .I unplugged the ecu and the front ecu fuse still blows .what will be this fuse for ?
Old Sep 6, 2014, 12:48 AM
ichihollow's Avatar
Originally Posted by ivkata
Hello
If you have a multi meter check for continuity between the source side of fuse 1 and the chassis if no continuity check between output side and chassis. You're shorting out somewhere, if you don't know specifically what that fuse goes to you might have to just follow the wires. Also check your FSM in the electrical section it should help you figure out exactly where fuse 1 goes to.
Headhunterz1105
Aug 9, 2016 03:01 PM
Hell_Spawn
Jun 12, 2014 08:16 AM
TS Goofy
Dec 23, 2013 07:46 AM
bnr34rb26dett
Nov 9, 2011 01:20 PM
neurotic ramble
Lancer Troubleshooting
13
May 2, 2011 08:38 AM
Quick Reply: 2004 Lancer ralliart keeps blowing fuse #1 in the dash -no start issue
