Door Locking issue
Door Locking issue
2003 Mitsubishi Lancer ES
Power doors & windows
Auto
I am unable to lock all four doors via the master door lock (driver side). All other functions work including unlocking all four doors, windows, etc. Can anyone point me in the right direction as to how I can go about solving this issue? Thanks.
Auto
Auto
Auto
does the driver side key cylinder lock all the doors? or is that what you mean? what about the door lock switch inside on the interior door panel...
I see, thanks a lot. Will get back to you.
Hey Cranswick, so when I lock from outside by turning the key twice, all the doors lock & unlock. Pressing the switch from inside doesn't lock all doors. It only unlocks. Hope that can give you a better idea of what's going on.
the two switches share a ground and a power source from the ETACS-ECU...so it's most likely that the switch itself is faulty..the driver side switch panel (main door lock, power window lock, all power window switches? come as one assembly...it's $170 new from mitsubishi, so I would start looking at auto wreckers...car-part.com is a great source, for autowrecker inventory...use criteria: 2003, Mitsubishi lancer, window switch (front door) and they are as much as $100 and as little as $20, but most are in the $40-$50 range...call around, I've found small parts I needed that were really far away, and I found a couple of places that will ship parts at your expense, so that's perfect if there are none close to you.
I would open the door panel up, and have a look at the wiring, and check the harness for damage/corrosion or loose pins etc. before buying anything.
So I swapped out the master door lock and it didn't solve the issue. I'm guessing opening up the door panel and checking harnesses is what needs to be done. I'm just not sure what I will be looking for.
chrisff521
Jul 29, 2011 05:20 AM
Eugene@SPE
Evo 'For Sale' Exterior Styling
Apr 20, 2010 11:31 PM
OSiTO-PANDA...
Mar 22, 2007 12:51 AM
Gruppe-S
22
Jan 23, 2007 02:09 PM
