Heating Up at Idle With AC, 2003 Lancer OZ
I've talked to a coworker's husband who's an Autozone manager about this but I'm throwing this out there for second opinions before dumping my time and money on this.
If the AC is off, the car doesn't get hot/out of normal if it's sitting, moving, etc. If the AC is on, we're good as long as the car is moving, but if I stop or say, go through a drive through, the temps creep up.
I was told this is probably the 2 AC fans. Does this sound right? My understanding is if so, this can be avoided by just turning the AC off.
If that's the case, this is going behind the new timing belt in line for this car. I have 180k miles on it, and the belt was last changed between 90k and 100k. A visual inspection of it looks fine to people who've seen it, but I'm antsy.
I feel like this car and my health can both smell whenever I have money left over after bills so they can break.
Edit: I drive mainly highway with a 30mi commute to work. I'd say 80+% is on a freeway.
Car fan: https://youtu.be/csmIRtjgALE
you got some oil leaks on the valve cover and PCV valve...
ok, so your water pump is driven by the timing belt, so it's not slipping...when the engine is cool (DO NOT ****ING TAKE YOUR RAD CAP OFF WHEN IT"S HOT, IT WILL MELT YOUR FACE OFF, I'M NOT KIDDING) and have a look at the coolant level, is there coolant in the overflow reservoir? coolant level should be right at the top of the rad, and should not be frothy, or discoloured...
http://imgur.com/a/eDHAn
It looks like it was low. I topped off the radiator directly with prediluted prestone. The coolant tub had fluid in it but I guess over all system was low.
I drove it 30 ish miles home and have let it sit idle for a while with AC full blast without issue.
Bought a 2002 lancer gdi engine in April, been busy havent got a around to get it fully ready. The previous owner havent drove it in years. what are the parts i should change???? oh i noticed that whenever i get to 2000rpm or higher the gdi eco comes off
fullmetal7777
Lancer Engine Tech
Jul 3, 2018 12:36 PM
cocopuffz17
Lancer Troubleshooting
Sep 18, 2016 02:25 PM
