Check Engine Light doesn't come on
Old Jun 26, 2015, 06:09 AM
Jaxson75's Avatar
I just failed inspection due to the Service Light not appearing when i turn the ignition to ON. Everything passed but would this be a fuse issue as my dome light stopped working a while back and I checked all the common fuses and they were fine. all the rest of the lights work when you put in to ON position.
Old Jun 26, 2015, 09:05 AM
jakermeister's Avatar
Most likely the light burnt out. You can replace it with a LED and it should be good for the rest of the cars life. Somewhere on here is the bulb size. I forgot what size it was. If you have a color of bulb you want your dash to be you might as well change the color while you have the cluster out.
Old Jun 26, 2015, 10:44 AM
Ev0ikon's Avatar
Don't use LED in your cluster. Every other places on the car are fine.
Old Jun 26, 2015, 07:25 PM
Jaxson75's Avatar
So you guys think its just a light bulb, is the cluster easy to remove and any advise on the dome light as well. fuse are fine too, but if i do the switch to ON or Middle switch nothing happens.
Old Jun 29, 2015, 06:13 PM
Jaxson75's Avatar
The bulb was the issue so i swapped it out with a good bulb and I now see the service light go on.....thanks guys.
Aar0nsite
Oct 26, 2012 07:25 AM
rino
Mar 7, 2011 05:37 PM
jnut24
Aug 14, 2009 02:57 PM
Peteypab2133
21
Jul 20, 2006 10:38 AM
Quick Reply: Check Engine Light doesn't come on
