2003 Lancer ES Grinding only while driving, turning right
Old Aug 9, 2015, 06:50 PM
ninthtale's Avatar
So this thread seemed to match my situation pretty well:
https://www.evolutionm.net/forums/la...ng-noise.html#
Except one thing they never mentioned was the presence (or absence) of a fairly solid vibration which occurs even at low speeds, and of course intensifies proportionately to speed, which makes me wonder if it is at all the same problem, and if by spending on another bearing it will fix the issue as it did for him.
I've replaced the CV axle, bearing, hub, and tie rod end, all on the right side. If I'd done my homework and been a bit more patient, perhaps I'd have seen the idea that problems which are apparently on the right are actually on the left side.
While this partially excites me, as it means I have yet some hope for fixing the problem, I'm worried, too, since the vibrations are occurring on the right side. I get the left/right flipping issue but does that still hold true if the vibrations and noise themselves are on the right side, and not the left?
I hope that makes sense. Thanks for any help at all!
Old Aug 9, 2015, 09:27 PM
CrAnSwIcK's Avatar
left inner CV is my guess
Old Aug 10, 2015, 12:12 AM
ninthtale's Avatar
..Even if the vibrations are on the right side?
Old Aug 10, 2015, 06:59 PM
CrAnSwIcK's Avatar
how can you be sure?...vibrations will resonate through a lot of things...a vibration from an axle could be felt through the shifter, or heard in the passenger door etc.
Rival Legendary
Oct 15, 2015 04:43 PM
AKW89
Apr 20, 2015 06:24 PM
DarkEvo
Jun 9, 2012 08:23 AM
Boost3dxEvO
Apr 21, 2010 09:08 PM
screwnutbolt
Feb 2, 2010 08:26 AM
Quick Reply: 2003 Lancer ES Grinding only while driving, turning right
