Need a little help
Old Oct 27, 2015, 08:17 AM
jpholbert's Avatar
Need a little help
So i have read a lot of post regarding overheating and i am having an issue myself but let me give a little background on what i have done so far. I replaced the alternator and belt, thermostat, new battery connectors with fusable amp, new control fan module.
The fans came on and appeared to be running fine but quit after about five minutes and now I'm overheating again. Could this be the temp sensor or is there something I'm overlooking? Thanks in advance
Old Oct 27, 2015, 08:28 AM
jakermeister's Avatar
It sounds a lot like a temp sensor to me. It could also just be the water pump going out. I'm not sure how many miles are on your engine.
Old Oct 27, 2015, 08:42 AM
jpholbert's Avatar
close to 200k hope its not the pump sensor would be a quick fix i cant remember does the alternator belt go around the water pump pulley? maybe i dint tighten the belt enough if that's the case?
Old Oct 27, 2015, 11:41 AM
I think so? I haven't done my timing, alternator and power steering belts yet. They're a bit over due so I may be doing them soon. If you replaced the alternator you probably should've just did the timing belt and water pump while you were in the area. You could start with the temp sensor and keep your fingers crossed.
LancerGSRx
Mar 1, 2013 08:08 AM
EvoXjavi
Mar 29, 2011 05:02 PM
David Buschur
35
Jul 23, 2008 10:01 PM
rchristie00
15
Sep 15, 2007 11:39 AM
Quick Reply: Need a little help
