Lance ES 2008, P0443.
Hi, I recently did my first attempt at diagnosing my Lancer's fault codes. I had two main ones, P0171 and P0443. Fixed the P0171 with some MAF cleaner but I'm left with the P0443 code. I read it has something to do with the Evap Emissions Control Solenoid, but I can't seem to physically find it in my engine. Can anyone help me locate it so I can continue to diagnose? (I will run a multimeter test to check voltage but not sure if that is the only thing I should look for).
Additionally, I ran some tests with a OBDII scanner and it seems the EGR valve pressure is strange. Does this relate? (Pic below)
Code
Negative numbers.
Code
Negative numbers.
neoakira
Apr 2, 2013 03:28 PM
