Trouble with my rear roll mount of my 2003 lancer es
I removed every bolt except the mounting bolt that is under the sway bar couldn't get a socket on it had to use 14mm wrench, couldn't get it, used heat still couldn't get it. The bolt head started to strip so I stopped because I didn't want to strip it totally. Had to put it back together, what do I do now ?
No it didn't strip using the box end I striped it before I tried the box end, By the time I used the box end it was to late, I couldn't even get heat right to it I tried to get heat as close as I can and still didn't work I'm gonna have to remove the sway bar like I figured I was gonna have to. Someone mentioned they make like and substance that come in like a caulking tube that you can pit on the motor mount but I'm not to sure
FS[Northeast]: Center-member/mount with urethane roll-restrictor mount
Jp7
40
Apr 17, 2017 06:46 PM
Hennybenny
Lancer How Tos / Installations
Jun 15, 2015 09:23 PM
tehforbes
Feb 10, 2007 07:12 AM
