Not firing on banks 2-3 and coil pack is burning up?
Hi I'm new on the forums I have 2005 Mitsubishi lancer 4 cylinder that was was running fine until messed with ground on coil wires. Now it starts and shakes bad and the ignition coil pack was replaced 80$ and still no fire on banks 2-3 but 1-4 is firing i think that is how it is wired also coil pack gets so hot it melts. on the coils connector there is three wires white,black and black with color stripe were does the black ground wire go from coil pack front ecu? Or pcm? what would cause this so weird please any help will be much appreciated.
white is 12v from fuse 1 under the dash and feeds the collector of the coil's transistor, black is ground for the emitter, and black-green, or black-yellow goes from the transistor base, to the ECM.
what did you do to the ground for the coils, and why?
Mitsubishi ^_^ (Jun 13, 2016)
My fan stopped working car was getting a little hot so I grounded my fans ground to coil ground black wire and that's when car started running rough and not firing on 2-3.
Mitsubishi ^_^ (Jun 14, 2016)
I'm sure I grounded it to the black wire the one in the middle and boom minutes later car missing on 2-3. It did spark a bit but fans were running as normal.also I did buy a coil 80$ and it melted it like butter to. Why would this happen is the black/wire with color stripe sending the pulse signal and charging the coil constantly? And thanks for helping.
sounds like the coil is drawing too much current, but the ground wire for the coils is electrically the same as chassis ground, because all circuits in the car are technically parallel, so it should be fine. but it's not...did you splice into the wire, or just use the ground same grounding point on the chassis?
When this problem happened I removed the wire and taped the splices up. I also found that the fan fuse under the hood was poorly connected and that was why fans where not working. I pulled it out reinserted it and fans are running fine. I then replaced the burnt coil with new coil and now new coil melts. I will check all the fuse and let you know thanks I really do appreciate all the help.
Come to think of it I may have touch the fans ground to the black and color wire on coil would this cause the pcm to short out and burn coils on affected side?😞
Raceghost
21
Nov 2, 2012 07:47 AM
joedr
May 20, 2011 12:51 PM
Thugline
Aug 11, 2010 01:55 PM
