2011 es spark knock!
Hey lady's and gents, I have a 2011 lancer es. It started spark knocking and I'd like it to stop. I checked the plugs and and they are burning clean and have proper gap as per the owner manual. Anyone have issues with spark knock? Could it be the knock sensor? Coils? Any info would be great.
You can hear it, car gets to temp and almost immediately you can hear it. I got the car used so I thought maybe someone put the wrong plug in it, not the case. I ran a higher octane gas in it thinking maybe that would help and it didn't do anything but empty my pocket faster.
did it start happening after you did something, like replacing spark plugs or something?
you're running the highest octane fuel available to you on a stock tune? might not be knock. most cars knock a little bit, but the ECU will retard timing when it's detected...you could try replacing the knock sensor, and double check your spark plugs are the correct heat range, not just the gap.
They are the correct plug according to the manual,I was running regular for the first 4-5 months of owning it, didn't figure it needed anything higher because it's not a performance car.then I switched to mid grade to for quite some time to see if it would make a difference and still nothing. The highest octane is $1.22 a litre right now.
thedru13
Nov 3, 2014 08:58 AM
Vivid Racing
20
Oct 1, 2003 10:46 AM
