Oil Light Flickers at idle
Old Mar 29, 2017, 04:35 PM
realgone2's Avatar
I know a little about cars, but I'm no mechanic. 2 weeks ago I had my camshaft oil seal and crank seal replaced. Along with the timing belt. A few days ago after driving for about 30 minutes the oil light flickered at idle. It has done it everyday since. As soon as I hit the gas it stops. I know this is because the oil is thinner when it's hot causing the sensor to register. Also the raising RPMs make the pump work harder. I'm getting an oil pressure test hopefully today. My question is how common is it for the oil pressure sensor to go out on these models (2003)? Car does have a lot of miles at 219K plus. Second question is would there be a correlation between the work that was done 2 weeks ago and this problem? Or is it a coincidence? Thanks!!
Old Mar 30, 2017, 08:02 PM
Crazehen's Avatar
You're low on oil buddy, check that dipstick before your day gets a lot worse!
Old Mar 31, 2017, 09:37 AM
realgone2's Avatar
Nah. Oil level normal. It was the sensor. Oil pressure fine. Thanks for the reply though
Old Mar 31, 2017, 04:17 PM
Crazehen's Avatar
Gotcha, figured it was one or the other. Better safe than sorry.
StlEvo05
24
Mar 10, 2012 08:31 AM
omniprobe
14
Aug 21, 2010 03:48 PM
DevilDuck
10
May 23, 2010 03:35 PM
GinNBoost
13
May 28, 2009 03:31 PM
greenemac2003
Aug 2, 2004 07:47 AM
Quick Reply: Oil Light Flickers at idle
