KUNiiiZZZEEE's HUGE PART-OUT
Hey guys the unfortunate time has come and the car is to be returned to stock and sold. For those who know me and my car, I not only rock unique parts that combined make the most efficient and logical sense, but also keep my car/parts EXTREMELY well taken care of. Everything listed is in immaculate shape and/or in new condition, (unless otherwise noted). Please no low-ballers as I'll sit on them if need be. Most if not all parts have less than 5-8k miles on them.
Oh and for those curious, I'll be rocking a my 2G in COMPLETELY stock form for at least another year or so till I get my head on straight and graduate .
EXTERIOR:
-JDM LHD Evo IX RS headlamps (non-HID TRUE JDM IX RS heads from Ecuador). SOLD
-JDM LHD Evo IX tail lamps. SOLD
-JDM Evo IX red rear bumper. SOLD
-Modified JDM bumper license plate bracket, (entire assembly that holds the license plate lights as well as mounting for the license plate WITH LED license plate bulbs - not separating). SOLD
-Modified JDM bumper beam painted red. SOLD
-OEM RR IX MR vortex generator. SOLD
-OEM Lancer Evolution rain guards. SOLD
-Evo 7 antenna. SOLD
-OEM Evo IX license plate mount. SOLD
-OEM Evo IX MR undertray with zero-lift kit built-in. SOLD.
DRIVELINE/SUSPENSION:
-Robispec KW V3 Clubsport Coilovers 8/9k springs. SOLD
-Robispec Custom 4-way adjustable rear sway bar w/adjustable endlinks. SOLD
-NEW Whiteline Ball-Joint Extenders. $50.00
-AMS brake duct kit. SOLD
-TRE max-lock rear diff. SOLD
-Buschur side diff mounts. SOLD
-Buschur mustache bar. SOLD
-Quartermaster 2-piece driveshaft. SOLD
-(2) Beatrush propeller shaft bushings (meant for someone with a aftermarket driveshaft). SOLD
-Enkei NT03+m 18x9.5 +27 wrapped in 265/35/18 Bridgestone RE-01r tyres, (8/32nds out of 10/32nds new). Comes with titanium CBRD lug nuts and custom wheel and hub-centric aluminum +12mm spacers to use in the front to bring overall front wheel offset to +15mm. SOLD
-Perrin PSRS bushing to increase front caster, (already pressed in, need OE piece to trade with). SOLD
-Nagisa Gacchiri fender braces, (powercoated red). SOLD
-ACD ECU, (ready for Gruppe-S ACD flash). $75.00
-OEM (20) lug nuts, no locks. $30.00 SOLD
-MR 6-speed transmission mount, (MUST for anybody converting to a 6-speed). $20.00
ENGINE:
-FIC1680 High Z injectors, (off a friend's car with LITERALLY 20miles, come with Evo X harnesses). SOLD.
-Tactrix 1.3U Cable for Evo 8/9. SOLD
-Authentic RALLI///ART red radiator heat shield. SOLD
-Mynes hood dampers. SOLD
-Black Hallman Pro RX. SOLD
-K&N drop-in filter. SOLD
-Saikou-Michi dual canister oil catch-cans. SOLD
-FORGE power steering & coolant overflow canisters (powedercoated flat-black). SOLD
-FORGE Evo IX 18psi wastegate actuator. SOLD
-AMS 3" MAF-LESS intake pipe with couplers. SOLD
-Spoolinup COP setup. SOLD
-Synapse Synchronic "updated port-c delete" BOV. SOLD
-Perrin black foam filter with MAF adapter. SOLD
-Polished AMS spark plug cover. SOLD
-Buschur exhaust cam sensor shield. SOLD
-Buschur polished spark plug cover. SOLD
-Buschur polished S.S intake pipe. SOLD
-Buschur polished Deluxe FMIC & IC pipes w/ t-bolts & couplers. SOLD
-Buschur IX turbo outlet pipe, (45degree "J" pipe that bolts onto the turbo directly). SOLD
-Buschur polished exhaust manifold cover w/ chrome hardware. SOLD
-Buschur mini-battery kit powdercoated flat black. SOLD
-Buschur shifter bushings. SOLD
-Buschur oil dipstick spring. SOLD
-Buschur 'Bullet' turboback exhaust with a 8" true 3" diameter magnaflow muffler in place of testpipe to quiet down the system, (courtesy of BluEvoIX's testing). This piece is also professionally shortened to fit the JDM rear bumper. SOLD
-(2) Hella Supertone horns. SOLD
-BLOX black front motor mount. SOLD
-Walbro 255lph fuel pump. SOLD
-OEM Evo IX exhaust manifold. SOLD
-Coated black eBay o2 housing, (has two little areas where near the flange needs to be re-welded). SOLD
-OEM Evo IX strut bar powdercoated to match valve cover, (red). SOLD
-OEM Evo 8/9 hood vent. SOLD
-Touge Factory 90degree Anti-Fouler, USED. $10. SOLD
INTERIOR:
-(2) OEM rear speakers. $10.00 SOLD
-Rexpeed "Evolution" gauge overlay. SOLD
-Nardi 350mm Deep Rally Corn leather steering wheel, Works-Bell Rapfix short Hub, & Works-Bell SE "Yoshioka" Rapfix II Quick Disconnect, (sold as a package only). SOLD
-COMPLETE Black Zeitronix ZT-2 wideband sensor kit (inclusive of EGT/Boost/wideband sensors). SOLD
-Black APEXi' TT. SOLD
-OEM Evo IX RS/MR Boost/Volt/Oil Temp gauge pack, (everything minus the oil temp sensor). $75.00. SOLD
-OEM Evo IX MR 6-speed shifter console. SOLD
-OEM Evo IX MR Carbon Fiber dash, (2-piece). SOLD
-OEM Evo IX RS textured HVAC control surround, (ONLY found on IX RS'). SOLD
-OEM "LANCER" all-season floor mats. SOLD
-OEM "Lancer Evolution" aluminum door sills. SOLD
-OEM IX MR faux Carbon Fiber e-brake handle, (has a few scratches and is NOT mint). SOLD
-OEM IX RS center console, (back half). SOLD
-Authentic RALLI///ART 5-speed white shift knob. SOLD
-Buschur base bushings. SOLD
-(2 sets) JID2[BINARY] seat-lowering brackets. SOLD
-DaFarmer LED dome light. SOLD
-DaFarmer trunk LED light. SOLD
-Unknown brand harness bar spray painted with trunk bed liner to withstand scratching. SOLD
-GTSPEC 4-point trunk cage spray painted with trunk bed liner to withstand scratching. SOLD
-OEM Evo IX RS trunk bar. SOLD
-Authentic RALLI///ART trunk mat (not sold in the US -VERY hard to find piece). SOLD
-Entire OEM trunk lining cut to fit the GTSPEC trunk cage. SOLD
MISC:
-OEM Flat-spray windshield washer nozzles. SOLD
-OEM Evo 8 FMIC grill & driver's side 'slit'. SOLD
-OEM Evo 8/9 airbox lid cut on driver's side for CAI effect. SOLD
-LancerEVO magazines editions #61,103,117,129, (good condition -never taken to the toilet :P). $75 all four, or $22/piece. MUST for any Evo connoisseur. SOLD
...prefer local sales, but shipping can be arranged. Items will be shipped in (1) batch a week. Paypal/shipping fees are NOT applied to the prices listed, please add 3% paypal fees. Please leave seller feedback and I'll make sure to return the favor!
~Thanks guys, it's been a great trip these last 5-6years!
ahh the memories:
ALSO HAVE THESE PARTS OFF MY 2G GSX:
(2) tan 8/10 condition Eclipse GSX floor mats: SOLD
(2) tan BRAND NEW NEVER USED Eclipse GSX floor mats: SOLD.
3-piece '99 Eclipse GSX tail lamps with "ECLIPSE" badge intact: $50 picked up.
DSMLink v2 used on my '99 complete with ECU, cable and adapter: SOLD.
GReddy P/H EGT (white, silver bezel, lights up amber): $100.
Autometer 0-30-0 boost gauge (white, silver bezel, lights up amber) : $30 picked up.
D2 coilovers, no signs of any issues: SOLD.
FP2 cams: SOLD
FIC 950cc injectors: $350.
Victory Performance huge "Street" intercooler (24"X10.5"X3.5") with short route S.S FMIC pipes, couplers, and t-bolt clamps: $400 picked up.
FP3065, no signs of any issues; polished compressor housing, ported exhaust housing, welded 90degree towards driver's side exit, FP oil line + FP inline oil filter + FP return line: SOLD
Hahn Racecraft 3" downpipe SOLD
APEX'i N1 catback: SOLD
Custom o2 housing to mate this v-band turbo to a Hahn-like downpipe: SOLD
TiAL silver 44mm v-band wastegate (forget what spring, but base was around ~22psi if I remember correctly). SOLD
FP dumptube for 44mm v-band TiAL: SOLD
4" black Dejon Tools intake tube with recirculation option: SOLD
Stock 2G head with intake manifold and throttle body (complete minus cams, comes with valve cover. Only "problem" is my car overheated and I'm having a hard time taking off spark plug wires). Make offer as I can't tell the condition of the head looks to be fine as valves/spark plugs/rockers/etc looks to be fine!
Please adding shipping if wanting to purchase out of state and/or Paypal fees if paying through Paypal. Thanks guys!
ps. all mods were put on roughly the same time with roughly around 10k miles.
pps. looking for an OEM 2G AWD turboback exhaust & OEM T-25 intake snorkel pipe.
~Kunal.
EXTERIOR:
ENGINE:
INTERIOR:
MISC:
ahh the memories:
FP2 cams: SOLD
~Kunal.
Personal reasons my friend, everybody that has known me or seen my car knows it's meticulously maintained/modded and I hate to see it go, but unforeseen circumstances don't allow me to dodge life right now .
I was just wondering. I recognized the screen name and it clicked you came up to Madison and tuned a few cars of people I hang out with, big one being Tim with his lime green evo.
Thanks guys, I appreciate the words, hopefully in the next few years I'll come back to the car 'scene'.
ps. yes i'll still be doing what I'm known for. Selling parts of course .
