- Evo 8 Cam install guide?
- Evomoto cam install guide
- Evo VIII Restoration Thread
- Evo IX Restoration Journey
- Need some professional advice fuel pressure regulator
- Evo 8 engine mount powdercoating
- Evo 7 dying right after turning over, after fuel pump hardwire.
- MAF sensor (i think) help needed - Airtrek Turbo (i have searched)
- Can someone tell me what this bolt is for?
- How to: Evo IX Spoiler Disassembly + Enhancements
- A/C died after turning heat on
- Evo 8 ACD pump location
- Rough RPM at idle
- No Start, Fresh Engine...
- Is getting an Evo 4 worth it?
- I Need how-to with pictures
- Front Lip suggestions 05 EVO
- Removing Head and replacing timing belt question
- Roof drip molding clips?
- Request: Rear subframe and suspension remover
- Need tool recommendation: crank pulley holder
- Replacing coolant lines/hoses
- Tech Articles Mitsi - PDF versions
- Broken fan replaced with slim fan, help wiring !
- Help! Bumper won’t fit with new intercooler tips??
- Valve cover stuck
- Transmission mount question
- Rear sway bar bracket question
- Cusco Oil Catch Can & Press-In AN Fittings
- Need help don't know where this wires goes
- Evo 8 Salvage, should I buy it?
- Evo 5 AYC Ecu pinout diagram
- Evo 9 RS TCase swapped into EVO 7 acy casing
- FiTronic Flex Fuel DIY
- HID headlights in an RS
- Seibon Trunk Evo 9 Question
- Evo 8 Headlights ?????
- Question on rope method for springs/retainers
- Exhaust manifold, intake and throttle body
- How to put on wastegate arm
- 05 JDM Evo 9 Speedometer issues.
- How to wire behind instrument panel
- No interior lights or radio
- Is this the correct order for removing radiator
- Cannot tighten nuts on o2 housing
- How to remove o2 sensor
- Modifying a Evo 6.5 Tommi Makinen ?
- Tps adjustment
- how to tune with greddy profec spec 2
- Evo 9 injector resistor box measurements: 7.8-8.0 k-Ohm, G/NG?
- Why Rockers off for Leak Down test?
- P0429
- Double pumper with hobbs switch rewire?
- What is this and how is it taken off
- Starter Bolt Needs Tapping HELP!
- How to remove exhaust manifold
- How to take off window trim molding / side piece
- Idling issues
- Gear box, T-case and rear diff flush
- Wiring two senors into one gauge?
- Lancer 4B12 engine ground
- Rear Differential Leaking
- evo 9 idle hanging/pulsating
- brake bleed
- Cracking Evo headlights in oven
- steering wheel control
- How to replace Alternator belt on Evo 9 ?
- Sunroof stuck ( Lancer 2003 sedan)
- low vacuum and idle surge, intermittent
- Need help removal the valve cover for a gasket replacement
- Fuel pump housing
- How-To: Bypass Charcoal/EVAP canister VIII/IV
- Turbo back install guide?
- Painting Evo 7 vents
- fuse block in engine compartment
- OEM ported intake manifold question
- suspension
- engine oil
- ETS intake install, tune required?
- How to replace headlight bulb
- Spark Tech Pro CDI 14B System Install help
- Help/Input Needed: Exhaust Manifold fitment
- What tools needed to take apart Evo 8 Engine?
- Evo 8 Aftermarket Front Lip onto Evo 9??
- APR Splitter fitment help
- Full Lean AFR @ idle after PTE 780 install
- Aftermarket Recaro Seat mounting
- Radiator Hose Advice
- Fuel Line Size
- Shops Near Me. [Philadelphia]
- How to fix non-working boost gauge?
- Buschur 3.5" Street Core FMIC work with stock intercooler piping?
- Power Steering Pump Spec's? *Need Haaylp*
- Does it look like this downpipe will clear ACD?
- Noob question. Pls help
- i replace my egr vacuum solenoid. need help
- 2006 EVO IX Overheat with AC
- Evo 8 rear o2 sensor removal....HOW THE F***??
- Non-HID VIII/IX - TO - HID OEM Conversion
- new turbo setup unsure
- brakes
- I had posted this message in the wrong thread before (question regarding Mani)
- Engine/trans assembly and install help
- Rally armor urethane mud flaps help
- Anyone knows?
- Difference between 4G63NA & 4G63T
- evo turns off when step on the gas
- Hks Turbo Timer Type 0
- How To Clean Titanium Exhaust Tips
- Need help with a Surge Tank setup
- Power Steering fluid level?
- Jacked up headlight lens, HELP please. 56k warning
- Rear rotor guide request
- Fic 2150 o ring help!!
- FAQs- parts added
- Boost mitsubishi Evo 2
- Double pumper?
- Does the rear evo 6 calipers fit the evo8
- Looking at buying my first evo
- How to remove Manifold and Turbo in one piece at the same time...
- How to fit Voltex street bumper and the wide fenders
- s2000 projector retro into evo 8-9 mr? looking for a how to?
- EVO 8 starter...summit sent two different ones both wrong
- Loose steering/car swerves
- Fixing the drivers side "no-automatic-window" problem?
- Re-Installing Evo 8 Dash
- DW300 Fuel Pump, Delphi 1000cc Injectors - do I need a FPR? Evo V
- Installing replacement HID setup question
- How to run a External Wastegate with TD06 Twin Scroll Turbo
- Help With Rims!
- How to install Buschur Racing Alt Map Switch
- vehicle emission control information sticker 2006-2007 model
- how to get the starter to line up properly.
- Evo 8 spring and retainer install with head on block?
- Rebuilding Trunk of Evo IX
- need help with greddy type RZ bov
- Nitrous install
- BISS screw adjustment, no change at all!
- evo 9 mr hid adjust
- How To: Hardwire Fuel Pump Evo 9 Deatschwerks Kit
- Oil & Oil Filter for Evo IV
- uego questions
- Replace Engine Thermostat
- trouble unattaching trans from engine
- How to unlock my boost controller ?
- E-brake rachet disable?
- Instrument cluster problems
- Trailer hitch on 03-05???
- In need of a good body shop to get my jdm rear painted in nashville,tn.
- Brake Flaring Tool
- How to install a boost gauge in evo 4?
- Help with timing
- code 22 srs
- Evo V Shift boot/Center console removal
- AN hose for Mechanical Oil Pressure Gauge
- Question when car goes into boost... may be catastrophic
- evo headlight rebuild
- Low boost and load values
- How to prepare an Evo 9 to speed density
- Vendor for AUTHENTIC Ralliart Carbon Lips
- Evo 4 acceleration issue
- Evo 8 Inner Shaft Question
- busher racing throttle body shaft seals
- How to: Gauge pod where cubby holder under stereo
- Window Belt Moulding Trim Removal/Install Help
- Fitting a whole QT in transfer case
- how do you convert back to 93 pump gas from e85?
- Constant Barometric Correction
- Help in wiring the mapsensor in jdm evo8MR
- HELP! problem installing APR GTC300 Evo9
- Need help installing LC-2 wideband
- How to set timing from scratch
- What year HID wiring harnes do i need to work in my 2006 gsr?
- Evo 9 GSR non-HID to HID
- need help on how to remove rear marker light bulb
- Question
- OEM Clock idea
- anyone uses EVC V?
- Door panel armrest fabric
- How To Remove And Replace Oil Pump
- 10.5 hot side
- Redline Goods steering wheel wrap Evo 8
- fender mod question
- Fellow Evo VIII rear Mitsubishi badge help
- HOW TO: Change MOMO´s @ EVO 8
- Abs issue! Plz help me~
- POWER BRAKE EVO IX same as EVO VII?
- Removing Steering Column?
- How to change brake pads part 2
- How to change break pads Part 1
- installed fuel pump and wont turn over
- What am I doing wrong (IX UICP install)??
- Oil filter housing DIY?
- Front sway bar bushings.
- How to remove carbon fibre vinyl?
- transmiccion and timing belt questions
- ayc and diff oil change
- water temp probe location
- Intake System Installation Help
- Inner Tcase seal how to request
- the end of all evo IX JDM head lights low beam discussions.
- Modded Walbro 255
- 10.5 hotside help
- How to change AYC Oil
- How do you pull this bonnet vent plug off!?
- Boost leak test - quick question
- Door Chime goes off all the time..HELP
- How To: Custom PS/AC Delete
- Installing new center caps
- do luck carbon fiber trunk install
- Interior Air Vents
- Help needed on tiptronic gear knob
- egr valve install question
- Rexpeed Armrest install problems
- Need DIY for Evo IX 5spd Trans Rebuild
- Rear studs removal and install
- Alarm + Turbo Timer???
- Rexpeed SE CF Lip Undertray Question
- Having fuel cut @ 10-15psi? cant go WOT.
- How to turn down boost on Greddy Profec B Spec 2
- Help on Evo 8 not starting
- How to import an Evo IV to the US
- gfb boost controller how to?
- different kind of headlight adjustment?
- Request: Getting off of first gear in a way that wont mess up the clutch
- HKS Circle Earth EVO 9 instructions??
- MAF Cleaning advice?
- How to properly install factory seatbelts with aftermarket seats?
- Sensors, wiring, ecu's and noobs.
- Oil catch can line delete question??!!
- How to replace driver door lock actuator
- Turbo XS Intake question ???
- EGR Solenoid - which is which?
- nrg quick release
- New to the forum, question about gauges and headunit for an Evo VIII
- How do you 'dechrome' a cusco catch can?
- AEM wideband sensor
- a/c fan delete? Ambient air temp?
- How To Request: Wire LED indicator to ECU??
- help
- HOw to remove axle?
- Conversion of pull to push clutch
- 2006 ES Brake Light Switch
- Request: STM Overflow Tank
- Engine Removal.
- Help With Greddy Boost Controller
- Broken Bleeder Valve. Looking for suggestions.
- Which wires from AEM Inline Wideband tie into which OEM 02 Sensor wires?
- need help anyone rexspeed va style rear diffuser
