View Full Version : Motor Sports
- Oil cooler lines 8an vs 10an
- Project Evo 9 MR-SE finally made it to the track
- Bolt-in Roll Bar Options
- Gridlife Laguna Seca
- 2024 SCCA SOLO - XA Discussion
- 2024 SCCA SOLO - STU Discussion
- Has anyone in here tracked their base Lancers with the CVT?
- Track Racing Tire Guide
- NJMP Thunderbolt/Lightning
- Speedlab shifter cable brackets?
- Rear Window Vents
- Please help: 18x10.5 front, 18x10 rear with 285/30-18 RE71RS square wheel & tire fitm
- AX / TT Motor Options
- Thinking about selling my awesome Street & Track Evo X
- JMS Evo racing this weekend. live on motorsport.tv
- M2 Bimmer Weekend Car
- Skunk intake porting
- White Evo Viii at VIR Trackdaze Nov 2022
- Sebring International Raceway Dec. 17-18
- 2023 SCCA SOLO - STU Discussion
- Looking for Curt Brown intake manifold
- Oil-Pan: Done. Now it's time to fix the 4G63 oil pump.
- NASA NE Nov 4-6 @NJMP
- Exedy twin organic track use
- Infinite Evo oil pan install and first impressions
- Tcase & rear diff fluids?
- How to identify what tune is in the ACD
- Flexible wire sheathing?
- exhaust manifolds!
- Buy/Build rear wing
- 595-RSR alternatives
- EVO X Driveline Stuffed In A 2018 Mirage on Steroids
- Splitter mounting
- Wing mount options
- Crankcase Pressure and Blowby
- Modern Tire Options
- Launching Autox?
- Bought a used racefab pan, lip bent, fixable?
- Manifold to Turbo Bolts Backed Off, Again
- Big Brakes
- 2022 STU discussion
- Race seats with stock belts
- InfiniteEvo's Wet Sump Thread
- Upgrading to proper pedal box with OEM ABS
- evo X track car
- NASA 2022 Thread
- Setting Compression and Droop Travel
- Track front bumper and body panels
- 285/30/18 on 11" wheel
- Time Attack Advice
- buying a new evo, is it too much car for what i want to do
- Eff me, car all the sudden wont start (I leave for packwood tour tomorrow)
- Blown KW V3...should I rebuild?
- Surge Tank Alternative
- Standalone ECU motorsports thread
- Quicker steering rack
- WTB: AP Racing 4 piston CP8350 front BBK
- Need and ACD expert
- The time has come possibly to part ways!
- Is this the right line through turn 11 at Road Atlanta
- The End: Sold the IX RS. Accomplished my goals and loved every second.
- Wing with dry carbon trunk.
- Salvageable?
- 2021 Track Discussion
- Roll cage
- Prepping for the Track: Need Advice for Brake Parts!
- CT9A Front Rotors for <$10 on Rockauto
- Road Racing adventures 2021
- What am I missing? Log attached. What’s changed?
- Bad OFH thermostat?
- Borg warner turbo sizing
- Oil pressure drop paranoia
- Quick help: Rev hang after boost between gears
- Fixing the Tomei Expreme Ti 3 inch (sort of)
- GTA Enthusiast Class 2021
- Exedy Purple has me thinking.....
- Modifying front diff oiling on E4-9
- Sealed/Encapsulated Sphericals... Source for OEM style?
- Merry Christmas track junkies!
- Logging wheel speeds
- Haltech TMS 4 tire pressure and temperature
- Cutting the rear bumper cover
- Deals
- Swan wing aero options for IX
- 2021 STU Discussion
- WK Motorsports shifter
- After Shep Trans stage 2....what’s next?
- 2020 Super Lap Battle
- Cold Weather Autox - Hoosier A7 or RE71R
- Aftermarket sheet metal exist?
- Clutch slip on the high end or what?
- Track Specific Updates / All Regions
- -an to inches?
- Raybestos ST43 front pads for sale
- Tubular exhaust manifold reliability for track cars
- Track Insurance
- Stick With The EVO Or Sell & Buy An Ariel Atom?
- Tiny bubbles; should I be concerned?
- Surge tank?
- Upgrading 8/9 front brakes
- Sparco EVO L QRT fitment 8-9s
- Anyone run a ZL1 1LE 10sp auto?
- Lancer DE 600WHP+
- Good source for quality open ended lug nuts?
- Tire Choices
- Have you logged braking G-force?
- Vorshlag camber plate torque spec?
- Hotsides
- When your EVO is working perfect on track
- Decrease in oil pressure
- Basic track setup help!
- Oil filter housing gauge ports
- Facebook group for those who actually do performance driving
- 2.0 Track Car: OEM Stock short block or build?
- Transfer Case Rebuild Time... Do The Trans Also?
- How to: Hoosier’s to Slicks?
- Convert trunk mounted wing to chassis mount?
- Cowl air dam?
- Lithium Polymer Batteries
- Evo8 RS RHD track car build on FB
- Do I have the heaviest EVO?
- Re-using Moroso Oil slicer when upgrading to Racefab
- SCCA Time Attack ECR Texas in June?
- RPM at 170mph?
- VOTE / Car of the 1/4
- Spliiter Questions......
- Diffuser...........
- ACD Pressures, what I log
- A7 vs R7
- Anyone here ever drive a 2014ish Z28 Camaro on the track?
- Selling racecar?
- Slb 2020??
- Adding Brake Presure Sensor
- 2020 Nasa TT/ST
- Tpms
- Brake parts for sale
- Grid Life 2020 Time Attack
- 2020 STU Discussion
- Aero Questions
- Spring 2020 / Im just missing the track - Bench racing/Discussion
- Northwoods Shelby Club Open Track Events (Road America/Autobahn/Blackhawk Farms)
- Hoosier R7’s to FULL Slicks?
- New Data logging with Gopo
- CP 8350's/Ducting
- Aero balance question on Evos
- Nasa 2020
- New Setup
- ChillOut systems sale
- Running front splitter and stock wing?
- How do you get International D Race License
- Hoping these new PF01’s 18x10.5 +38 will fit
- Spacers
- Install pics: AP Radi-Cals & Dry Sump thermostat oil cooler bypass
- ACD with LSD front diff
- Rötheli Racing - Time Attack EVO VIII
- Track alignment help please - new shop changed my set up
- Trunk Lid Bracing
- Brake Deflectors. Thoughts?
- 18k turbo?
- GTR vs Evo wheel bearings, different bearing clamping
- Please take a look at the Yokohama Apex tire contest
- Decent tire temp probe that doesn't break the bank?
- Advice FP 54 Green BB turbo
- MoTeC MDC Diff Controllers - Who's Running One?
- Best manifolds hold up yet on track?
- Driveshaft upgrades
- Bumper Cover Structure
- AIM Solo vs Solo DL on Evo8
- Best fit and quality Voltex - Replica source?
- Autocross wheel/Tire size
- Assist Springs vs. Helper Springs
- Anybody running JRZ RS Pro's? (Evo 8/9)
- Tell Us Your Pinnacle of Performance, Win Yokohama's New ADVAN Apex™ Tires!
- Anyone running wider front wheels/tires?
- Issues with surge/bucking under partial throttle with aftermarket BOV's
- Catch cans
- 1-Way Front LSD Options
- Keep AC?
- Tuning for Track
- Brake ducting on OEM IX
- Bolts Vibrating Loose
- East Coast Road Race Tuner??
- YACT - yet another clutch thread
- Any gains on track set up with aftermarket intake & exhaust manifolds?
- 2019 HPDE/practice tire choices
- KAAZ Rear LSD vs Cusco
- NOOB question regarding brake fluid flush
- Bunch of Track Brake Bits for Sale for CT9A OEM Brembos
- Anyone got a spare rear diff?
- RaceFab install: HELP no oil pressure???
- NASA HPDE - Clumsy Cow - Autobahn South 08102019-08112019
- AP Racing 4 piston Kit. (forsale)
- Track turbo kit
- FS: Sparco Pro ADV seat (expired)
- Which motor would produce more power? (Road Race)
- Power Steering Pump Upgrade
- Tested my Buschur Race FMIC at Summit Point
- Very disappointed in my latest build (1/4 Mile Related)
- Time to make a change. Suggestions?
- PA Strut Camber Locks
- Its For Sale / Highest level EvO Track / Street Build?
- New addition to garage.
- Need some seat + slider help
- Rear wing options
- Harry's Lap Timer Thread
- Buttonwillow - 6/21
- Unofficial: Titanium stuff and interests thread
- Built trans and TC (track days, not drag)
- Lightweight & Quiet Exhaust
- Interest Thread: Functional Evo Specific Aero Parts
- Who Wants Some PROPER AFFORDABLE Track Wheels?
- AST 5200's for sale
- New Raybestos ST43 and ST47 front brake pads
- Yokohama A052 Review
- Modified iacv
- NJMP Thunderbolt.....
- Typical hpde questions (2019)
- best place to get new axles
- Hopping on corner exit
- Son of a.... X3
- Fuel Cell Discussion
- JR1 oil
- 2019 SM (Street Mod) Autocross Discussion
- Southern Fried HPDE at VIR? 6/1-6/2
- Finally installed my SSB rear trailing arms
- Oil Pressure drop right hander question
- Coilover Remote Reservoirs
- Buttonwillow, April 30th
- Gravel Rally Coilovers?
- Where to find odd wheel sizes and offsets
- Should I replace these rotor rings? (Pics)
- Feal 441 (standard spring) vs Fortune Auto 500 (standard spring)
- Essex Parts AP RadiCal's for CT9A's
- Evo IX 2pc rotor/caliper or Evo X OE rotor/caliper?
- 255 NT01 vs 245 slick.
- evo 4 - 6 and evo 7 - 9 axles different?
- The better choice......
- Anyone running the Weds TC105X in 18x10???
- Calcs on rotational inertia and effective mass
- Busted RS4 Tires
- Road Course Alignement Specs?
- Rally info?
- South Texas roll call
- Midwest Open Track Events (Road America/Autobahn/Blackhawk)
- Review: Corbeau Sportline RRB Seats in CT9A EVO 8 VIII
- 2019 STU Discussion
- CAE Shifter
- 2020 Gridlife Season - Changes / Discussion
- Breaking in new parts
- TrackTime Track day Laguna Seca, Dec. 22, 2018
