View Full Version : ECU Flash
- Evo 8 Ignition Retard Limit
- ECUflash will connect with car
- What table to edit for starting fueling?
- [HELP] Looking for XML for ROM 93660005
- Tephra mod fan control?
- Newbie here with immo off 2004 lancer
- No ECU ID/Case ID/ checksum module normal?
- Bin file to xml def
- HELP! Need 2016 Lancer EX 1.6L definition file xml rom srf bin
- NY evo 8s that recently passed inspections w/Tephra
- Help with ida pro program
- Need XML Editing Help
- TephraMod installation video
- TephraMOD for JDM imported Evo 7
- Bosch 1000cc Injectors
- help needed please MH72002F
- MMC Pajero 3 6g74 ROM 36480014 Accel Enrichment Tables definition
- Fuel & Timing Map - Is this OK?
- Evo 9 ECU bricked?
- Any IDA Pro experts still around?
- MAT logging for 9626xx09?
- Look at my time map - Knocking
- Evo 8 fq300 definition file or replacement rom
- Mitsubishi Colt CZC Turbo need XML definition
- ECUFlash issues
- Need Help With Definition File
- Help identifying Evo 9 AUDM ROM
- 4 port EBC resolution?
- CAN Bus sh7052/sh7055
- SST Learn in help
- 4g18 base map
- need help getting tune from evo 8
- Unknown Rom on Newly purchased '03 Evo 8
- Help Hex addres to disable DTC colt/forfour
- Need a base map to start my car... Helpppp
- repository of bin files
- help a newbie with def file :)
- Proton Waja 4G18P XML 97400006
- MAF Error?
- 88580714 tehpra v7 decel cutoff off
- EcuFlash xml issues/ lean warm start with SD
- AEM X Logging issue via Rear O2
- Issue with warm / hot start (E85)
- Evo ECU swap from IV to VII with Tephra V7
- Openport2.0 logs with Evoscan... Won't flash/read With Ecuflash
- Looking for a bench reflash
- Phenem Pre-patched ROM links dead?!?
- Mivec table gsc r2
- Min Coolant Temp for closed loop on Evo8 tephra
- ECU Tables & Addresses
- Knock after installing GSC S2's.
- Ecuflash help
- Logged 1 byte load plummets at peak boost? -- Log inside
- GM 4 BAR map sensor
- Map switching cable - Anyone still make one for sale??
- Evo 9 88570008 sd rom coil dwell xml
- Evo 7 wont Log to SD Card with Tactrix 2.0
- 96260709 XML needed
- I need the addresses of Evo 7 for the fuel map and the timing
- Need help with knock tuning
- 4g93 swap to 4g64
- New to ECUFlash
- 93660005 rom
- Removing Wireless Control Module
- Evo9 ECU types
- I need definishens
- Missing ROM ID in 0x5002A location?
- Raising boost
- I need ecuflash xmls rom where can I download it?
- Who wants to read my ROM?
- stock ECU rom needed
- Rom definition needed
- Mechanical issue or setup/tune?
- find missing immobilizer value
- EGR or Evap solenoid controls
- After changing immobilizer code and saving, ROM is not recognized
- Evo 8 speed density rom
- Rom xml for 90556701
- Evo 5 Boost Tuning.
- What the hell happened to EvoScan?
- Help to cut off the fuel correction by egr
- Reflash to stock
- Bad miss and ECUFlash wont connect
- Cold Idle
- Injectors Zero'd
- help me! I used evoscan and got an error code.
- Which Maps to Change with bigger Injectors
- ecuflash dtc's
- Saving current mass air tune, switching to SD
- Flashing ECU
- Mitsubishi 4G18s definition file
- Ceddy mods for Evo 5 or 6
- Ecu stolen from car need help getting it started
- Srf/ROM reading error.
- Engine sputter wondering if its fuel
- Bad idle after flashing map
- Evo 9 wagon gta xml files
- Which ROM for EVO9 with ALS but no SAS
- 91860006 ROM help
- Modified ROM
- 1 Byte Load More Accurate??
- immobilizer ix to vii ecu swap
- Free Flexfuel for the Evo 9
- bench flash 1860a418 2006 lancer AT ecu
- MUT/RAM logging
- 9626009 JDM EVO 8 Tephra V7
- Outlander xml - rare shi...
- ECUFLASH cant read .srf
- map/boost over OBD2 on evo9
- Mitsubishi Magna Catch Can.
- XML definition Can anyone help?
- Rom definition
- Tephra V7 SD Who can find the missing link....
- Tephra
- 80700013 xml needed
- Help, Problem with Ceddymod in SD EVO 5 JDM
- Definition 88595715
- Meth usage 06 evo 9
- How to figure out what rom ID you need?
- Uk/jdm speed density conversation help!
- [Clarification] Merlin's Injector Setup Steps
- Idle afr
- Evo 9 EDM 88840013
- Car wont run when 1.3u cable is plugged in
- Cannot get EvoScan S/N
- wont idle after reflash to stock ?
- After Tephra Map car don't start
- Need Help could someone check this log for me?
- Tephramod V7 Help Needed
- Help with 96533706 Live Map (DMA)
- Can anyone help me with my current tune?
- Coolant temperature sensor maxes at 192.2F
- Ordering evoscan 1.3u cable, has anyone ordered recently?
- mitsubishi evo 9 flash
- can someone take a look at my MIVEC intake advance?
- Cant finde my Boost Limit Table
- Updated Tephra v7 9563 rom definition
- Is that already Tephra or is OEM
- Guide: How to flash the Airtrek Turbo
- Colt Czt eudm xml needed please!
- Experience with Evans Performance Academy
- anyone have evo live map for 96534706
- Tune sd 3d table with mad assistance
- Ipw patch evo 9
- EvoScan upgrade no response anybody there who knows?
- 560cc injector information
- SD issues cant see map VE
- Grayed out stuff in ecuflash what does it mean
- Tephra v7 engine light flashing
- Evo maps, Magna?
- Pops and Bangs on lift off ECU flash
- Ecu flash and Vag cable
- Can’t read ecu tj Magna Sports
- FIC 1220cc Scaling/battery data
- Evo7 FreeFuel ROM or Patch
- Uknown rom image
- J2534 Error report
- XML for 97470001
- Need Outlander 2010 XML Definition ROM ID 55140005
- Can't get ECUFlash to open my ROM, tried everything I can find
- Evo 8 life after storage issues
- Can't get rid of P0135 front O2 sensor heater circuit (P0135) error
- Tuning the automatic - W5a51 - GTA\Airtrek
- readiness test problem
- HELP tuning stock Evo 6 TephraV7
- Tephra v7 xmls not being found in directory
- Weird problem, boost doubles after battery ground has been removed
- Can't track down bizarre misfire issue
- Can't find the definition file for the Outlander on the Evoscan page
- EVO IX 9 GT-A Wagon XML ?
- Removing CEL for EGR & Downstream O2
- mh7202f hardware rom dump
- Logging airflow / MAF diagnostic
- Any way to have ECU control water methanol injection?
- Problem since installing and tuning 3-port
- Evoscan
- need help with Pajero xml
- evo 9 immo disable
- Need urgent help please
- Evo7 tephra v7 (90550001) Help
- Do the Tephra v7 VE tables change load cells for timing?
- V7 SD 88591715 2byte load temp + baro or regular?
- evo 4 boost control
- Evoscan downloading issues
- Rev Hang Issue on Tephra V7 on Evo 8
- Evoscan Logging problem
- Airtrek ecu flash plug
- EcuFlash/Evoscan tuners Australia
- changing temp scalings in 96530706 - fahrenheit to Celcius
- Can't open ROM-file Outlander Turbo
- Expand window size in ecu flash
- Evo 8 3plug ecu not reading MAP input
- Idle help? 3D SD
- Can't open ROM, XML file is present
- Tephra V7 for UK EVO 9 - 88570008
- HELP: opening .Bin file in ECUFlash
- Help: i need a stock rom for 05 evo 8 mr to pass smog inspection
- -20 timing, no pops&bangs
- In need of some assistance: xml file
- can i go back to stock timing tables and keep other settings
- Airtrek reflashing
- Need HELP logging AFR on Evoscan Autometer Digital
- xml for 1998 RVR x3 4g63t
- Evo 5- No definition for ID05092012 - use H8 n/a instead?
- Opinions on Fuel/Timing maps
- ACD ECU unable to connect with ECUFlash
- Jdm evo 9 on tephra v7 rom: 88592715
- ECU flash developer mode?
- Long iddle upper after cold stard
- Evo ECU, Naturally aspirated car
- Idle timing 2.4LR
- Hitting Negative timing between shifts
- Evoscan
- Identifying Rom & Help Logging
- Ecuflash Randomly Decided to Stop Working?
- Car runs super lean and surges on hot start
- Need definition file for Outlander (JMC728)
- How to switch maps on Ceddy rom ?
- 88583714 v7 SD xml
- 2byte load eval equation for 88590015
- 3D Speed Density Tephra V7 ROMs BARO Fuel Compensation
- Outlander turbo, wont read ECU
- Evoscan
- Omni 5 Bar MAP values.
- Boost cut, fuel cut or anything else
- Colt Czt Edm 2005 (not Ralliart) Definition Help
- Flashing Back to Stock Immobilizer Issue
- 96260009 tephra v7 rom
- Closed Loop not working evo 8 ECU on Evo 4
- ROM image not found (Flex Fuel)
- Looking for 94670106 definition file
- Hello - first time tuner
- Proper Tuning Order?
- evo 9 gt wagon rom definition EcuFlash
- Rear O2 Sim not working?
- Seeking knowledge about current ROM (file attached)
- Unknown Rom
- OBD inspection settings (88591715)
- Tactrix Openport 2.0
- Tephra 9626 v7 rom
- P0170 fuel trim error
- Problem With ECUFLASH 1.44.4799?
- ECUSCAN APK Download, Does it Exist?
- Subaru Legacy /Liberty 1999-2000 Cable and Evoscan
- MAF disable, P0102/P2228
- How do you disable/remove cels from the ecu with ecuflash?
- Evoecu.logic website almost down?
- Changing the timing retard past -10?
- aem wideband
