- Need to replace fuel pump relay N°2. Lancer evo 4
- Ignition Switch - Crank No Start
- Alternator wiring
- AYC relay testing
- Best sound system speakers and setups
- Keyless Entry Fuse
- Can’t get the fuel pump to turn on :/
- Power steering pressure switch connector
- Evolution GT-A
- 6 to 5 speed reverse adapter
- Climate control lights don’t work
- 100w led light bulb on evo 4-6?
- Audio help
- Evo 8 Passenger Tail Light Short
- EVO 8 Cluster Illumination Flashing
- 2005 evo 8 i step on the brakes and the hazard lights come on. electrical???
- Defrost/AC/Recirculating Buttons not working
- Help with signal light issue.
- Help with ECU compatibility please
- Battery and E-brake light is on
- Evo 8 Need help with cluster pin description
- evo 8 idle air control valve wiring diagram request
- Evo 9 JDM headlights not working
- Evo 8 tries to crank without the key in the ignition
- Evo 8 Check Engine Light Wiring
- JDM Turn Signal Bulb
- Battery Issues
- Relocated battery. Oops.. fuel level sensor not working
- Low Voltage Issue
- Sard pro meter el egt
- Sumo’s Evo 7 (Electrical Gremlins)
- AC compressor Aligator clips and Electrical end caps yikes.
- crank no start
- Under glove box wiring.
- Left Turn Signal ON!
- Buzzing noise
- external fuel gauge
- Digital dash / No alternator
- EVO IX MR all ACD lights come on
- Fuel guage issue with ic7
- 2003 Evo 8 Rapid Voltage Fluctuations. Please Help!
- Best radar detector for the evo
- Smaller light weight battery not requiring new tray
- evo8 reading light not working
- SRS light after installing NRG hub
- 03 evo 8 fusible link question
- Want to trigger LEDs by doors/unlock to light entry way
- MItsubishi Evo 8 - How to tell if I have central locking?
- Fuel pump rewire
- Turn Signal and Emergancy Flashers not working
- Voltage problems
- LED bulbs glow dimly
- Low voltage at ECU
- Etacs Access for Mitsubishi Lancer 8 gsr
- evo 7 windscreen wipers not resetting properly
- evo 7 central locking
- twin pump help
- faster/better way to disable Evo from theft?
- Need Help Identifying Cable Size
- Help with ETACS Access
- N.D. Upgraded cam sensor kit
- Looking for ACD pump relay connector
- Looking for SRS Harness connector
- LED ring size fot CT9A
- Evo 8 260 ecu swap in Evo 4 failure!
- Mishimoto e fan won’t turn on
- 6 prong ignition switch
- Fog light, power mirror switch
- Front ECU
- Evo 8 ECU harness
- no spark condition
- Power door lock opens when window switches pushed
- inside fuse box diagram wires colors
- fuel pump wiring issue ?
- grounding points
- Wires under armrest
- Door actuator problem perhaps?
- Evo 7 key fob / central locking
- Two connectors on the Evo 8 where do these go?
- Need help with choice android head device and tuning dashboard
- Best way to add an electronic column lock
- Issues getting power to car help!!!!
- Evo 8 Alternator number three....
- Fusible link
- evo 8 battery relocation question
- Evo 9 headlight rebuild / re-engineer & retrofit - custom project
- Anyone know where this cable connects?
- Instrument cluster
- Evo 7/8 - 9 full wiring loom
- lithium ion battery
- Evo 8 diag port weirdness
- What are people doing with their Fuel pump resistor and relay?
- Evo 8 stalls out when fan is on!
- Power Antenna Wire Colour??
- Stumped with new evo electric problem
- Evo VIII BCM lock wires
- 12V ONLY when car is cranked/running
- Evo 8 MR - Rear Fog Light
- after lock, 30sec and unlock automatically
- Driver's side parking lights not working
- ECU pin install problem
- Front windows stopped working after messing with climate control
- Negative battery cable corrosion
- Defi gauges help
- Fuel Cell Wiring
- Engine fuse box IOD connector help. Evo ix
- what wiring for 450 walbro
- Mysterious box
- Evo 9 Halogen Bulb
- Keyless Remote Entry FOB problem
- Old alarm & emobiliser trouble
- airbag scan software for openport 2.0 ?
- Flashing ABS, No ACD lights after alarm fitting...
- has a key less entry/push button start been done
- Headlamp Leveling Motor
- Key fob issue / etacs ?
- MAF Connector repin help
- Issues after harness swap
- Looking For: Evo 3 Stock Head Unit
- Wosp Alternator?
- Evo 6 (VI) ECU into a Evo 4 (IV)
- Electrical problem 😫HELP!
- Rockford radio help
- How to remove tail light connector
- Evo 7 GTA Kph to Mph help needed
- Wire Tuck ( Hidden engine loom )
- Need carputer help
- What do I need for evo RS power locks?
- Evo 8 Help Identify Wire
- Fuse box
- AC Control screws
- Evo 8 blowing fuse number 1 on stall
- No power Pin 12&25 going into ECU
- Audio setup (Speakers, Amp, Sub) suggestions
- HELP!!! TailLights
- Need help with Defi Gauge wiring (illumination/brightness)
- Faulty headlamp? EVO 9
- Aem series 1 (1313) box
- Evo 9 Battery Relocate - Starter and Alternator Fuse Location
- Need Help Sorcing Evo Pins and seals for Connectors
- Battery relocation specific questions, searched but no luck
- Replacement speakers
- Looking for the spade connector size that connects to starter
- Battery relay to disconnect
- RPM not reading.
- LED reverse lights
- Weird problem after cop kit install.
- Evo x navigation antenae
- Electrical Gremlin
- Hitachi CSB HRL1280W / Mini Battery / EvO
- Infotainment suggestions for logging EvoScan
- Amber signal front headlights
- Spade connector on starter keeps coming off evo 8
- CT9A Custom tail light design, build project for Evo 9.
- Custom DIY PCB LED CHMSL for Evo IX
- Front O2 sensor issue
- Possible broken clock spring?
- Headlight harness issues
- Vehicle Speed Sensor / Wiring
- Evo 9 MR wiring harness
- Handbrake light not coming on.
- Stock Stereo Brackets Needed?
- Evo 8 Stereo Wiring harness
- OEM Tail Light Options - Master Guide for CT9A
- Door open warning light wiring ce9a evo123
- Help my evo not running right after I replaced head unit
- Sony's new Single Din ~9 inch screen Media Receiver
- Antenna fell off
- Evo 8 Intercooler Sprayer Switch
- Help evo6
- Subs
- EV0 9 ABS faults
- Cluster Bulb Color?
- Wire that is wrapped around the key cylinder
- evo fuel pump harness replacement
- Battery Relocation Stuff
- Instrument Cluster Dead
- Burned ground wire when cranking engine
- Amber parking light bulbs.
- How To Replace Busted LED High Mount 3rd Brake Lights? (Evo 9 MR)
- Low voltage when turning on defroster
- Negative terminal clamp cracked
- SRS light help
- A Standard 12V Battery Option List
- Headlight Reseal
- New Evo 9 Key
- Brighter replacement headlights (non HID housing)
- Evo 8 GSR MMCS Language Help
- Evo 8 Speedo Needle Sticking/lazy????
- Mut 3 protocol
- HVAC lights ash tray lights, dimmer, and cig lighter light not working. HELP
- ISO info on custom dash setups
- Poor range with FOB
- Evo 8 Headlight adjusting help
- Evo 7 cluster into evo 4
- HKS turbo timer Help
- Help please swap evo 7 ecu into evo 4
- Highbeams wont stay on?!?!?
- Keyless entry key
- Various Electical issues stumping a tech/service writer of 5 years
- Evo IX Program Mode Help!!
- Evo 8 Navigation dash Head unit query
- 2 Odyssey PC680s dead in a 2 week span.... coincidence?
- My alarm system is tripping my windows
- Need help finding Ballast
- BATTERT LIGHT / BRAKE LIGHT after new alternator? Help
- Dimmer will not dim
- EVO IX stays running for 30 seconds after attempting to turn off
- Putting oem hid projectors in non sss car
- Car died on me, Some advice please.
- Anyone got any idea what this is?
- Wiring up 3 gauges from the center pod
- Confused about wiring / Window
- ECU for EVO 6 or 7
- Faulty fuel filter caused mayhem on my ignition assembly?
- Evo 9 tranny ground
- Starting issue
- LEDs or HIDs
- Will Evo 8 starter fit in Evo 7?
- Evo 8 Electrical Problems
- Battery Relocation for evo 8 wire type questions
- Battery wire harness????
- Evo 9 oem A Pillar Tweeter questions
- EVO 8 no voltage on pin 12 & 25 connector
- park brake light + battery check light + RPM gauge stopped working
- Evo 8 Ignition Issue
- Evo IX 3rd brake light
- Evo 9 rear bumper corner lights
- Headlight timer
- Power folding mirrors on USDM Evo 8
- HID headlights in an RS
- Anyone have their sub(s) installed in the cabin?
- What’s the best car alarm for an evo 8?
- What is this?
- 03 evo 8 engine wiring?
- How to use the trunk release button?
- Anyone with electrical knowledge? particularly alternators
- Tesla style screen? Has it ever been done?
- Evo 6 Gsr Cluster Pin Out Diagram
- H/O alternator options
- Testing a DIY LiFePo4 mini battery
- small battery help
- Voltage drops drastically as car is gunned/high revs
- Haunted Evo? odometer, WB, oil pressure gauge..
- why is there 2 yellow constant wires on my wiring harness?
- Popping fuse and car won't start
- PC680 Terminals
- Dash Light Issues...Any help appreciated
- Optima mini for ETS tray
- Evo 8 Rear wiper blade install
