- Wondering what parts fit
- CVT Automatic Shifter
- Ralliart/evo intake
- 2008 lancer 2.0 engine compatibility
- Help with the Dedicated N/A ROM tuning thread dissapeard
- Oil and noise question
- Lancer 2009 DE Loud hum on startup
- 4B10 upgrade to 4B12
- 4g63 in a 2009 Lancer w/ manual
- 2.4 Engine Knock/Tapping
- evo x valve cover on 2008 lancer gts
- 4b12 TB Question.
- 2010 lancer
- 2010 Lancer DE CVT Swap
- 2015 Lancer gt 4b12 2.4l cvt Rom tune
- 2010 Mitsubishi Lancer gts Aftermarket Header?
- ECU rom issue
- 2010 Mitsubishi Lancer gts what cams fit?
- 2013 Lancer SE Exhaust Question
- Lancer ex cvt to swap??
- 2009 Lancer GTS
- in need of TUBE, T/M OIL COOLER LINE
- Seized engine, need interchange info
- 2003 lancer es model wont accelerate
- Need help please
- Newbie to the Lancer Life!
- Throttle body cleaning
- Modern performance crank and water pump pulley install
- ECU Flash
- The automatic gear shift "stuck in park mode"
- 4B12 Swap Questions
- 08 Lancer GTS Idle Air Control Gasket
- Mods for ‘11 Lancer GTS?
- Motor Mount upgrade
- 4a91 transmission to 4b11
- 2012 Lancer GT Tick/Knocking Noise
- 4G69 Throttle body conversion for CJ lancers
- 4b12 to 4b11
- Just a few questions
- Short Ram Intake for 4B12
- factory repair manual
- 2008 Lancer GTS Oil Leak
- Exercise in creative thinking, sleeved 4b11 vs 4b11T
- Lancer 2008 turbo rom
- OBX header or SUPER CIRCUIT?
- 2.0L Intake help
- Thicker oil s it possible
- MAF sensor question
- Planning to swap from 4A91 to 4B11
- Do 2.0 4b11 exhaust headers work on 2.4 4b12
- Engine swap, starts but dies
- ENGINE BLOWN. 2015 Lancer Es. Need help!!
- Lancer SE 2.4 Lucas synthetic
- 4B12 Engine blown. Possible solutions?
- Similarity between engine and trans
- Power loss while driving
- 2010 Lancer es 2.0
- engine ticking
- Have to replace Engine
- 2009 lancer gts throttle body
- Car Died Wont Start Back
- Ways to add power to an 09 ES?
- Catalytic converter recommendations?
- serpentine belt
- Lancer GT 2.0L 2015 4b11 cvt
- Will an engine from a 2010 fit into an 2009?
- Engine knock
- 2008+ Lancer AC compressor replacement/upgrade
- Ticking noose when accelerating (HELP)
- 2015 Lancer exhaust
- Possible mistake when flushing coolant?
- 4g69 throttle body idle issues.
- 08 GTS starts, idles, dies
- O2 sensor on second cat
- Performance upgrade 2016 Lancer GT
- O2 sensor question
- Egr delete question
- EvoX down and mid pipe on lancer gt 2015
- Best oil brand for lancer
- beginner
- Beginner
- engine swapping 2.0-2.4 (2008 lancer gts)
- engine Mitsubishi lancer IO lost power in engine no.1 and 4
- 2008 Mitsubishi Lancer Rod Bearing Clearance Specs?
- 2009 Lancer GTS Volkswagen VR6 engine and transmission swap
- 08 Lancer GTS engine replacement
- Picks up speed very slowly even though rpm go higher
- 08 gts standard cruising at neutral idle fluctuates
- Lancer gts 08 rpm drops when clutch pressed in (disengage)
- New to forums! 2008 Lancer GTS ideling problem:/ help!
- Shops in Miami
- Headers?
- 2008 4b11 swap to a 2015 4b11
- Boost without Turbo on 2012 ES
- Lancer ES 2012 (non turbo)
- 4B11 N/A head on 4B11T block
- 2008 Lancer SCCA Race car
- swap suggestions Lancer 2008
- 09-10 4b12 vs 11-16 4b12 Engines
- 2000-3000 rpm rattle / knock
- My new lancer. What to look for
- RRM Turbo Kit???
- Service Engine Soon Light
- Coolant temp sender
- 4B11 Open Deck Strength
- 2009 Lancer GTS installing new air intake - suggestions?
- Header and exhaust kit options?
- Where to Tap into the Oil Pan
- evo x and lancer block
- CVT Swap.
- when to change spark plugs?
- Engine swap question
- Remap
- What is the name of this part
- best NGK spark plug for 2011 es ?
- exhaust options
- Lancer problems!!!!
- ECU for GTS?
- Cam Swap Question
- Swapping a 2.4 into a 2011 ES
- 09 Lancer GTS Battery Replacement Options
- Engine swap on 08 Lancer
- ralliart into es engine
- what are actual info of fuel pressure / stock Injector size of NA lancer 2008+
- lancer
- Is the turbo kit worth it?
- Lancer 2015 es
- RRM Oversized Transmissioner Cooler - 2011 GTS CVT 2.4L
- Lancer over heating... but not over heating?
- 2014 Lancer gt torque specs
- Need new spark plugs, what and where?
- 2009 Lancer 2.4 GTS Throttle body or Spacer
- 2015 Lancer GT bolt-ons
- WTB : OEM Axle back muffler
- WTB: Used axle-back exhaust
- Worth it?
- Car Idles...
- Car Idles...
- Idler pulley, I need of a part number
- Engine bay diagram
- Mass air flow sensor cleaner
- Engine RPM takes too long to drop
- Needing some help with CEL/SES lights; desperate and out of options
- 2011 Lancer GTS upgrades
- 0-100 km OBD test results. ? My test result after tune.
- 4B12 engine questions
- need help finding power steering reservoir
- In Need Of Help!
- 4B11 Valve Clearance Adjustment
- 2013 ES to Ralliart Conversion?
- Burning oil
- 2014 Lancer 4B11 tuning
- 2009 Mitsubishi Lancer De Torque specs
- Engine noise at 1500rpm
- wierd click sound (help)
- Engine bogging out when going up hill
- 09 Lancer ES CJ Auto - timing belt or chain?
- 09 lancer gts. engine problem
- 4b10
- 2014 Lancer GT Tuning question.
- REALLY need some help with this one
- outlander's 3.0L in GTS (tranny fitments)
- Help!
- Help with P0037 code and P0137 code popping up
- 2008 vs 2015
- Evo X battery Terminal Main Bracket
- Engine Interchange
- 2008 Lancer Magnaflow Catback Exhaust
- Engine Question.
- spark plugs
- Side Plate Install
- Would A L4-2.0L Takeda Cold Air Intake (Tr-4202P) Fit Into A 2.4L Lancer Gt? (Pic Inc
- lancer 2011 transmission cooler
- pzev cat with test pipe
- SRT-4 Camshafts?
- Car randomly turns off
- 4b11 type catback exhaust,can it work on a 4b12
- Aftermarket Installations
- Jerky Power Delivery
- Theoretical Header/Exhaust setup. Would it work?
- Evo X injector swap in lancer es questions
- Intake question. Help!
- Ecm swap trouble
- Advice on mAkeing my Lancer GT A LIL MORE FUN!
- Throttle body size of 4b11 and 4b12
- Anyone interested in buying injen CAI?
- 2009 GTS + RA Snorkel question
- My car is mixing coolant with transmission fluid.
- RRM timing module any good reviews
- cvt turbo install?
- Steering Thunk
- ECU Reflash for all Base Lancers
- OBX/ RRM Header with OEM Cat
- Could it be my Alt?
- Lancer transmission swap
- Where to buy strut plates for a 2009 Lancer?
- Vibrating at 3k
- headers wanted
- Difference between 2008 and 2010 GTS?
- 2014 lancer upgrades help!!!
- Lancer ES upgrade Turbo !!!!!! HELP
- Catback/Axleback Exhaust
- after 9 months
- is crank pulley bolt reverse threaded?
- will a RA OR GSR OR MR DOOR FIT GTS
- 4B12 specs.
- 09 lancer won't turn over
- New ECU? GTS in a ES
- new piston 4B11
- 08 GTS throttle sticking
- 4G15 Engine Lifter Noise
- Need help finding forged pistons & rods
- Oil filter wrench for 2012 Lancer SE.
- 2009 gts delete cats?
- Is it worth it?
- Need all info on "chips" please help
- lancer es platform
- Why the Hate for Modding Lancers
- Can I replace my ecu to use a chip will it work?
- Slowest car Ive ever owned... Help!
- 4B11 Engine Vibration at 3000 RPM
- looking to buy used or new?
- Sick Speed 70mm Throttle body
- Vehicular Tard Mode (after hitting ABS)
- Lancer ES 2010 Rev Limiter
- 2011 fuel line routing.
- RRM SRI Minor Warning
- 2012 Lancer SE Pulley Options.
- CAI vs SRI
- Takeda gts 2.4
- Engine Upgrades
- Thanks! love injen SRI!
- turbo manifold for GTS
- Evap system question and help needed
- Need Help
- Spark Plugs
- 2009 Lancer ES SRI intake?
- how many hp have 2.4 GTS realy???
- Misfired cylinder
- Headers (2010 Lancer ES 2.0L)
- 2010 Lancer ES 2.0 (Exhaust Systems?)
- Head bolt question
- Air problem
- Injectors
- diesel D68 engine replacement/problems
- MAF cleaning
- Stupid Question
- Throttle body sizes
- where can I get a new MAF o-ring/gasket
