- 09 es sport (5 speed sedan) transmission
- Loose Shifter?
- Begging for help here!!!
- CVT Issue - HELP!
- 08 GTS Code P0868 & P0841
- Lancer sx, awd conversion
- 2011 Lancer es
- 2013 ES CVT Filter question
- Lancer CS3 2005 Transmission Fluid change
- What types of fluid do you all recommend for the transmission?
- 2008 Mitsubishi Lancer GTS Manual Trans Rebuild Kit??
- 2010 Lancer 2L N/A aftermarket motor mounts ?
- What options do I have?
- Compatible transmissions? 2015 ES cvt in a 2010 GTS?
- Cvt lancer problem
- 2010 GTS CVT compatibility
- CVT Cooler
- Solution for p420 code?
- Owner Says 4th Gear sometimes pops out Since New ACT HDSS Clutch
- Aftermarket transaxle bearings
- Issues shifting on my 2008 GTS
- 2008 lancer swap to manual won’t run right need MT Rom
- Advice on converting cvt to manual 2012 gt
- Need help code po845
- Cvt Transmission fluid change
- 2008 Lancer CVT rpm limited until I gain speed
- 2009 Lance ES Transmission Stuck in Drive
- Lancer DE transmission whining
- Newbie looking for help
- Free lancer with clutch issues.
- Max engine block and transmission limit
- GTS Transmission Fluid?
- Transmission repair shop in Seattle
- 2010 lancer gts problem
- 08 GTS, CVT to Manual conversion
- Is there a spot to attach tow hooks onto a 2008 Mitsubishi Lancer?
- Transmission service required
- Need a torque converter!
- Will evo x clutch fit base lancer
- Where is the Transmission Control Module!?
- 2013 Lancer SE AWC w/ CVT drivetrain
- New clutch purchase recommendations
- CVT transmission fluid
- how to tune eengine for more power
- 5 Speed, Shifter Sloppy
- Lancer DE CVT Oil Cooler
- 2008 lancer mt how do u remove the axles
- 2008 mitsubishi lancer es shiftlinkage disconnect
- 2012 lancer ES trans in 2008 GTS
- Replacment CVT
- 2008 Lancer GTS Transmission problem under warranty?
- Clutch and flywheel for 4B12
- 2010 Lancer CVT filter change
- Can I put 2015 SST transmission into my 2017 2.4l AWD Blacks Edition
- when to change cvt tranny fluid?
- First gear problem
- gears skipping maybe
- Lancer GTS whine
- Pancake cvt fluid cooler removal
- Looking for GTS CVT oil cooler assemble
- 3rd gear grinding
- What CVT Fluid
- 2008 Shifter cable ball joint on transmission
- Trying to order a clutch slave cylinder online
- Gts Flywheel/Clutch on DE
- Who has had CVT problems?
- Transmission Blew?
- CVT Question
- Axlee pops out of pass side after seal replacement. Ideas?
- 2009 DIY Manual Transmission Fluid Change
- 2010 Lancer GTS Shifter Bushings?
- Grinds when trying to shift....still
- No clutch pedal after slave swap
- Clutch fluid leaking from trans
- Towing with a manual Lancer GTS 2011
- Whining noise when downshifting. Normal or not?
- CVT Quite Noise 09 Lancer ES
- Help! No clutch after fresh install
- 08 GTS new Transmission Cooler
- How do I bleed & fill slave on new clutch install?
- CVT Transmission oil change
- Tranny or engine? Or something else...
- 08 Lancer Clutch compatibility
- Tranny & Gear & Coolant change, (Dealership)
- bad slave/master cylinder? 2002 lancer ls
- 2010 GTS CVT issue
- CVT Trans wont stay in manual when using paddle shifters...
- trans fluid change
- tranny swap
- Finding tranny fluid in Alaska... ugh
- Flywheel...what type? 08 Lancer Es.
- ECM swap issue
- 2009 lancer gts no clutch pedal
- Wont shift
- Type of tranny oil????
- Whining noise from CVT? / + Question
- 2009 GTS CVT Issue
- Transmission Leak
- Suspect CVT issue - let me know what you think
- CVT SP-III fluid
- Trans. Oil Level Guage
- Lancer shaking at highspeed
- somthing weird
- HELP Axels
- 4b11 cvt
- Tranmissions swap?
- CVT Chain Slippage?
- Need Help - No Clutch
- 2008 CVT vs 2013 CVT Manual mode
- CVT Tranny Problems??? New to CVTs, Cant tell...
- Check tranny fluid while engine runnning?
- Cluth Replacement Pains
- 09 GTS CVT transmission failure
- Out of curiousity..
- 4B11 vs 4B11T Tranny
- Transmission fluid and oil change questions
- CVT Transmission problems
- Evo X tranny
- 09 GTS with CVT reverse uphill
- 2012 lancer se
- different cvt fluid
- Transmission oil cooler
- Galant Fortis AWD
- Lancer ES AWD Conversion
- 2011 Lancer GTS 2.4L 5 speed need tranny oil
- 2012 lancer gt shifter in 2011 es?
- New Clutch ideas?
- Transmission oil change 5 qts not 8.2 (like in manual).
- Transmission Seal Color
- Anyone interested in doing some testing for us?
- Transfer box
- Lancer 08 Warranty question! Having trouble
- Short shifter install
- WORKS Trans.
- Question about the 4b11 drivetrain
- Lancer GTS 2007 MT help
- GTS 09 Transmission Fluid Change
- Cracked transmission cooler (CVT)
- transmission swap
- 2008 ES M/T Clutch?
- Clutch
- Overdrive?!
- AWD conversion?!?
- CVT->Manual conversion
- Lancer Transmission
- 2009 Lancer GTS CVT tranny fluid change.
- Your exp with the GTS ASC
- TWM Performance Mitsubishi Lancer Short Shifter?
- 09 GTS Traction Control
- 1.8MT vs 2.0cvt, which faster?
- 08 mt transmission
- 5-Speed Gearbox ellhousing is the same or not?
- Downshift grind.
- AWD conversion info thread
- cvt-sst
- Scion TC LSD will fit the Lancer 08 MT ?
- Cvt service
- installed paddle shifters on my 08 es
- allow your es/de go into sport mode (same as GTS)
- lancer '08 GTS to evo x flywheel???
- Reinforced Cvt Racing Belt Update
- CVT Transmission fluid change
- beef up bullet proof A cvt transmission
- weird lancer gts not starting issue
- Air hose
- awd lancer
- 5 Speed gearbox problems
- clutch replacement
- CVT Clunk/Pop/Hard Shift
- 30K maintanence - Tranny oil and Transfer Case oil check
- Manual Transmission Fluid 75W-80 GL-3
- CVT Fluid change instructions
- exhaust help
- CVT Worries Me....
- ASC maintence/check engine/irratic idle
- Clutch adjustment 08 GTS
- 2011 GTS, does the CVT have a radiator/cooler stock?
- SSP evo x master cylinder for lancer GTS 08
- Gearbox?
- slave cylinder part number?
- need some help ASAP!! SS clutch lines?
- cvt upgrade belt?
- Synthetic in a M/T?
- TC-SST in 2.4 GTS CVT
- Rough Shifting???
- CV joint - clicking when turning (has anyone replaced theirs?)
- Tranny Fluid
- auto to manual swap
- Vibrating/Buzzing noise during fast acceleration
- is something wrong with my car?
- evo clutch in non evo will it work
- first gear clutch clunk
- Manual Trans. OIL
- '09 Lancer GTS Repetitive Scrape/Squeak Noise When Braking
- Help! Big Problem With Shifting Gears
- Downshift problem
- gearbox stuck in reverse gear
- Noise under hood/ Transmission problem
- sportronic help?
- New Shift knob?
- Clutch Kit
- Lancer ES Drivetrain Swap
- master cylinder clutch evo x for gts?
- Catback exhaust: Greddy Or Injen?
- where to shift
- custom short shifter!
- Gearbox issues
- Clanking noise from Engine
- 1st Gear Broke in Manual 09 GTS at around 7,00 miles
- tranny oil change
- 08 Lancer CVT Acceletation Bog, Any Solution?
- Rotational Grinding Noises...
- need help
- CVT Issue...
- Evo X Computability
- 5 SPD Tranny
- CVT Tranny
- Cvt oil!
- Trans swap?
- Short Shifter and base bushings?
- I need a new clutch!
- Advice and Opinions are welcomed. Please read...
- Upgrades for CVT w/ sport mode?
- new ACT clutch!! :D
- Trouble getting into reverse and 2nd gear grinds?
- Trouble getting into first
- tranny fluid
- Spec clutches?
- CVT ECU hack?
- Jerky ride in 2nd/3rd between 15 and 40
- Manual transmission - downshifting / Heal and toe rev matching
- Using cvt tranny to slow down
- RRM needs to make a tranny swap!
- About the CVT transmission..
- Quaife ATB Differentials available from July 2009
- which is better for torque transfer?
- belt or chain driven?
- RRM Grip Springs
- tranny change from automatic to manual
- Grinding while downshifting to 2nd gear
- * Did Mitsubishi Get the CVT Right?
- CVT Trans fluid
- Road//race make a lsd already!
- Tranny popping out of 1st
- cvt?
- trans messing up
- Stuck on 1st gear
- CVT E-Brake Drifting
- 3 CVT Tranny's
- help in runing 1/4 mille
