- Purge Valve location? 2010 Lancer GTS
- How can I fix stereo not working?
- Crack head stole my radio...
- Electric Power Steering Icon on Screen
- After market carpet. vs upholstery shop
- HELP: Upgrading from Halogen headlights to HID Projectors
- '09 Lancer GTS Battery Problems
- Rockford Fosgate head unit wiring harness
- Rear License Plate Lamp Bracket
- Ralliart Exhaust on Lancer ES
- Is there any How To available for changing Clutch Master Cylinder for 14' Lancer ES?
- Do we have pilot bearings?
- What is a lancer GT
- 4B12 Swap Questions
- Lancer ES with turbo kit of Ralliart - ROM 52680015. Disable DTC
- Looking for sub enclosure for 2010 GTS Spotback Lancer
- Headers/CAT/Exahust Help
- HALO Headlights - Anzo vs RRM?
- 2001 lancer
- Max Engine block and transmission limit
- Tire Size Suggestions
- 2015 Repair manuals?
- Need a 12 V tap in source for map light DIY
- 2017 accident repair / compatbility
- VLAND Audi style Headlight intstall
- Lancer 1.6 Cruise Control Help DTC P0500
- 09 DE non-turbo - to turbo kit installation
- 2016 GT crazy check
- buying a 2012 DE with higher mileage, or 2009 with lower?
- EVO X front lip on GTS
- 09' Lancer SE A/C Compressor
- 2011 Lancer GTS Door Belt Moldings
- Backup camera install - Reverse sensor wire
- Help with a lancer build...
- Amp needed with sub woofer..?
- Can't find this O2 Sensor Mount
- Coolant fan question
- 2014 Lancer body under shield replacement
- 2012 LANCER SE Spoiler Install
- 2012 SE CVT Shift Knob Replacement?
- Megan Racing Spring Kit advice
- 08 GTS Engine Swap
- Best sounding mufflers?
- Installing Cruise Control
- Turn signal mod?
- Lancer 08 DE Rockford Amplifier how to
- 2015 es shifter conversion?
- Turbocharged 4 cylinder 2011 Lancer 2.0 L
- Need advice, where can I buy this?
- 09 Lancer ES - seat cloth compatibility
- Changing Condenser
- Lancer GTS options
- Will Lancer GTS exhuast systems fit on 1.8 GS3?
- Is it possible to replace the plastic airbag cover on a '09 Lancer?
- Exhaust Questions
- How much wrap to do the interior of Lancer
- What should my keyless key / FOB look like?
- LED Tail Light Problems!
- Upgrading sound, No OEM Replacing
- Lancer 09 GTS
- Muffler and Condensor
- 2010 Lancer DE PKE alarm system install headeache... please help
- Anyone familiar with ETACS Decoder and DRL feature?
- Performance
- 2009 Lancer GTS installing new air intake - suggestions?
- New lancer need help with mods
- 09 lancer gts a/c delete
- How To: Replace Knock Sensor
- Dimmer switch
- Vacuum gauge
- Different Rev Limit sounds?
- Modification Discussion
- SOS DRL Wire cut
- stock Blue Speedometor
- How to remove the power mirror switch
- Lancer Aspire 2010 Flappy paddle Gear box install
- Alternator replacement 2009 GTS
- Lancer headlights
- High Mounted Brake Light
- benefit of battery size
- Fuel Injector cleaners question
- '10 Lancer GTS Suspension
- Head unit Port
- Front Bumper Removal
- Plug and Play audio possible? 2013 es
- 2012 Lancer SE Turbo oil feed
- Upgrading 2016 Lancer GT 2.4
- Newbie. 09 DE
- Installed HID's
- Wheel making a loud popping noise while turning
- Spoilers and automatic car washes?
- Gear lights
- Looking to purchase a used 2011 Lancer
- Anyone know where to get a cheap ashtray?
- Aftermarket Rear Spoiler recommendations?
- Any lancer groups in san antonio?
- Carputer with microphone and steering wheel control
- Newbie stuff
- Need some advice
- Manually Read ABS Codes
- Hood spacer install
- Aftermarket steering wheel
- Hello Gents! Proud newbie owner of '08 GTS Lancer :)
- Oil and Oil Filter?
- Changing steering wheel
- Reinstalling interior light (wiring)
- How do I take the chrome piece off the grill
- Evo 4 wont start! HELP!
- stock 2008 lancer stereo. intermitent mono sound
- DIY Fog Lights
- Bluetooth and iphone 6 plus on 2008 GTS
- 2010 GTS Rear brakes/rotors
- 2007-2013 Camara wiring harness
- Factory wiring question
- '08-'15 lancer GT
- Howbro trouble shoot hydraulic problems after clutch install?
- 2010 Lancer GTS w/ CVT tranny...Mods???
- Are my brakes good?
- Will an Evo X Vortex Generator Fit an NA '08 Lancer?
- Sportback LED tail lights
- Help to identify these plugs and unit
- how to remove trunk liner on DE with no reclining seats
- Rubber Seal Around Trunk Key/Button?
- Double din frame for aftermarket stereo on 2015 ES
- A squeak sound from the engine when I press the gas
- 2011 Lancer ES 4B11 Engine
- Compressor Issue Please Help....
- Noise when I come to a stop
- Exhaust recommendations?
- 2015 Lancer Air Intake
- Aftermarket wheels + rain = Wet rotors/braking issues
- 2012 lancer ES front brake pads
- Rear trunk cover removal
- Just bought Evo headlights, but there's a leftover connection?
- Lancer SE exhaust help?
- dual exhaust help
- Looking for rear diffuser and front lip 2010 lancer sportback GTS.
- License plate relocation
- Rear lower control arms
- Using carbon fiber wrap in engine bay...?
- Legit Exhaust or nah?
- Ralliart/GT bumper on SE
- Upper pad/foam on inner part of the door trim
- 60K service help plz
- Stock alarm problem
- Where can I buy the complete transmission system (mechanically)?
- Semi How-To's / Tips 2010 Lancer gts sportback
- Headlight choice for my 2013 Lancer ES
- Front / Rear Strut Repacement + Other
- Can I attach a 2.0 catback exhaust to a 2.0
- eclipse seat swap?
- Exhaust for a 2013 GTS
- Best wipers & brakes for a 08' Lancer ES?
- Spoiler help... Please
- Where to get Rockford Fosgate Amp
- Stiffer suspension but keeping at stock height
- Converting Gauge Face Cluster To Metric
- 2011 gts shifter
- Valve seals replacement
- 2009 Lancer GTS RPM Loss
- How to install Defi-Link Meter BF Tachometer
- 2014 lancer es
- Help me find 4A91 (or 4A92) engine cover
- help with LED sill plates, front and back.
- Aux Hole Cover
- 2.0 Turbo Diesel oil change
- 2013 lancer GT front fender removal
- 2012 Lancer ES CVT 2.0
- axle back exhaust
- Navi install
- Unused 4-pin connector in driver's side trunk
- Stone chips!
- 2012 Mitsubishi Lancer SE Rear Bumper Lip
- 2012 lancer base exterior mods
- 2013 Lancer SE front bumper replacement
- Mid Pipe Lancer GTS 2011
- help on ralliart rear windshield blade
- What type of aftermarket pedal would you recommend?
- Knee air bag problem?
- Aftermarket alarm with FAST key?
- 2013 Sportback GT 2.4 Headers
- lancer de 2009 oil choice for engine with a lot of sludge
- What is this
- Tint window
- HELP! Going from LED to OEM taillights
- Will these rims and tires fit?
- GTS Stock Shift Knob
- rebuilding a 2011 lancer ES
- Regular key vs the factory FAST key
- Question about L gear in the PRNDL shifter.
- Front frame
- exhaust
- 09 lancer SE HID problem
- Turbo for 09 Lancer GTS
- Turbo kit for 09 Lancer GTS
- Have you seen this kit for sale?
- Replacing window glass - How do I get it in the track?
- is it an Amp? and want to install a new sub.
- Help please
- Need help deciding 2010 gts vs 2010 es
- Passenger mirror & rear fender replacement
- Body Kits
- LCD colored cluster !
- New Lancer Owner
- Front end components
- Will I melt OEM Fog light housing?
- Where can i get rear bumpers?
- is this a spare connector for a trailer hitch?
- 2009vs2010vs2011?
- 2011 Lancer GTS head unit question
- REAR Bumper Removal
- cloth seats
- 2010 Lancer GTS Front Bumper Removal
- Installing a new shift knob.
- Entire Dash Removal HELP!!!
- 2011 DE rear disk brake convertion
- evo X bumper on lancer DE will it fit?
- Aftermarket Tweeters In An 09 ES-Sport
- bumper change..?
- Fog lights and DRL questions.
- Tow Hook install.
- body kits, spoilers, etc ?
- Seat belt dinging is driving me crazy
- intake filter install?
- Exhaust system question
- Has anyone done the interior console/dash swap??
- Speakers That Will Fit a 2013 Lancer ES?
- 2013 Lancer ES
- Navigation Enter button (ENT) Replacement?
- Buying 08 GTS
- Headlight help needed!
- What fits? Diesel Model
- 2008 Lancer GTS coolant question
- Lancer GT or what?
- 09 Lancer GTS. Doors won't stop locking Help please
- Need help on Exhaust system!
- 2008 Lancer Brake/Tail light out
- Need help!
- Steering wheel help!
- Question: Non-HID conversion to HID
- Radio blues
- Need advice!!
- Question about 2012 GT
- Android Tablet/ MP3 player
- WTH is this and how do I remove the brake pad
- 2013 Lancer GT, safe to turbocharge?
- Lancer ES 2010 Service Manual
- Exhaust Kits?
- Will an Exhaust Tip improve sound?
