View Full Version : Evo X General
- Rough idle dies below 1500RPM
- Evo X stuck in park sometimes SST
- Looking for someone to install or a shop that can install a downpipe on a evo X IN NJ
- Help with ida pro
- Binding/clunking/popping noise when turning at slow speed from the REAR.
- Clutch pedal squeak..
- Evo x more power
- Vacuum Line Question
- Shop Recommendation in Tristate
- Swapped evo x diffrerential to Ralliart rear cross
- Cylinder Scoring
- Evo X MR needs transmission rebuild
- ETS HFC vs MAP Evo X Catted Mid Pipe
- Where can I buy baffles for my aluminum valve cover?
- Strange Engine Behavior when Pushed
- Clubspec products
- Inspection issue?
- EVO X problem remove TIPS
- Has Anyone Bought An X Again After Selling?
- Lean on idle and hesitating when accelerating
- Evo X flush fitment with 18/8.5 +?
- Non Mitsu Lubricants
- special evo x?
- Code P0017 Crankshaft Position – Camshaft Position Correlation (Bank 1 Sensor B)
- Figuring Out Evo X MR Repairs After an Accident
- Transmission help/ Advice needed
- Evo X handbrake problem
- Evo X GSR idle and low RPM stutters
- Cobb drop in high flow filter
- Target for a 500hp Evo
- coilover advice
- Looking for Trunk Width measurement
- Modified Evo X Questions
- Any help appreciated thanks
- It smells like gas
- 10 second stock block passes
- Spark Plug Issue
- Should I trade my STi for an EVO?
- Evo X - Cinematic
- 2013 Evo X GSR pops out of 4th gear at higher RPM
- Pulled over ETS V3 Extreme help!
- New Evo X Project!
- RH OEM Rocker Molding (Skirt)
- 93k Evo X @ $21.5k
- Fuel Pressure Regulator?
- Looking for a Shop to Work SST in South Florida.
- Part Out - EVO X, Lancer and Aftermarket Parts FS
- Evo X FQ400 body kit?
- P3701 misfire?
- Evo X Bogging at idle and take off
- Driveshaft clunk... again!!!
- Radiator fans not kicking on automatically
- Drl fuse relay size
- Need some help!!
- Fuel System Woes
- 2015 Final Edition MT or 2013 MR SST-AT?
- Thoughts on getting another Evo
- System too lean bank 1
- Forjar motor lancer 4b11 2.0 n/a
- Evo X SE want to know my number of Evo SE
- EVO X Staggered Wheel Help
- Evo X Massive Oil Leak Yesterday, Nothing Today
- GSC S2 Cams With Manley Valve Springs And Retainers
- Gsr p0014 help!!!
- Evo X pedal spacer
- Evo X 3rd/4th Gear WOT Stalls/Hesitates
- EVO X exhaust on Base Lancer?
- AC Blower / Cabin Filter
- I wrote an EVO song!
- Time to shine
- Evo X Not Starting after engine swap.
- AYC Pump
- recommendations for shop near Toronto
- Wastegate opening under light throttle normal?
- AC Install help
- Evo X OEM Navigation Moisture Inside Screen
- Evo VIII/IX Rear Chassis Legs
- [LINK] Fixed service manual PDF
- Just have my rear differential ATF replaced. Don't forget to change yours
- Fuel tank
- Hks muffler for lancer ex gta
- May come back to the Evo Fam - General Questions
- Evo X 6 point roll cage!
- 4wd system service required
- Idle Drop then Recovers
- evo x mr wont start after worm
- Evo x vs C6 Z06
- will wrong parts work?
- Vacuum lines
- Any good shops that work on evo in Michigan
- These bolt-ons can be installed while still using the Evo X's stock tune, correct?
- Evo x tuning help
- best exhausts for evo x with no drone
- evo x sawc
- How much did you pay for your Evo?
- What is the proper way to perform a coolant service for the Evo X?
- 2 hr drive to tuner am I safe?
- Stock Turbo and Downpipe?
- Key Programming Not Working (locks/trunk)
- Passenger running tail light works intermittently
- Bad AMS Downpipe welds??
- Looking at a X with a funky past
- Overboost temporary fix?
- Odometer Does not work.
- Big (huge?) fuel consumption (Too rich in fuel?)
- Turbo back Exhaust with no Flex section
- New X MR buyer - looking for car; Questions
- San Diego Autobody Shop recommendation?
- Cant get to the trunk as i took the battery out of the EvoX
- MAP Catch Can / Coolant reservoir AN fitting issue
- Looking to find the owner of this black 2011 MR with 40k in NEPA
- Looking for Evo X "SE" trunk badge
- Hood Stuck
- how to press in main rear diff bushing?
- Steering rack measurement
- Corbeau custom seats and digital format files required for embroidery
- 2008 Evo X GSR. ASC and loss of cruise control
- 2013 rallart what octane level should I be putting
- Gas smell when I turn on the ac or heater
- ACD/AYC Codes
- evo x FE vs GSR
- Fuel Hardware or Tune?
- Popping when turning left, CV joint or something else?
- Vacuum line
- Bought 2015 Evo with burnt engine bay in Oregon (looking for ex owner)
- Oil Catch Can and SMOG testing in TX
- OEM spare tire delete kit parts guide
- Service brake system
- Manual Transmission bell housing bolt part numbers
- Evo X door Sill fit in Lancer
- Evo X Wastegate problems
- Help!!! Check icon keeps popping in the center lcd
- Need help!!!
- Non-US Evos with repair kits instead of spare wheels
- Evo X Shifter
- No crank/No start car died while idling now doesn’t want to start
- Engine squeal
- frame rails
- 60 month maintenance on low mileage car?
- Is this a good deal?
- [WTA]Cams Identification
- Help installing SYGAV head unit w/ Rockford fosgate and Navi
- Local Shop Labor Hour Quote Question
- Evo x brake light fuse
- Small bumps and/or slight throttle cause hesitation or fuel cut?
- What tail lights are these??
- leaking brake fluid after dealer performed tcase install almost led to disaster
- Vent Gauge Pod?
- Apparently unique idle/stall problem?
- Help finding part number
- Evo x problems
- What is this plug for
- What do you think of these stock tune compatible bolt-ons?
- Radium fuel set up, fuel return vibration problem
- Evo x exhaust
- Clip/retainer for holding the tweeter housing PN ?
- Cobb Green Speed Update
- Need help with P0017 code after timing chain replaced. PLEASE!
- Does the EVO short shifter fits the Lancer?
- Berk Technology HFC and CEL
- Front Diff Leaking Should I...
- Just bought an EVO X FE and need some advice
- Does EVO X body work fit on Lancer?
- DRIVETRAIN PROBLEM! dealer?
- Wierd noise coming from behind the right front wheel/top right engine bay area
- need help Troubleshooting - Engine and A/C
- Rust paint spray, brake fluid & bleeder: Are these all I need to install a metal CMC?
- Looking to buy a 2014 EVO X MR, could use some help.
- Strange Noise coming from front and center of evo x
- Speaker wire location help.
- Where do i place S-video cable for reverse camera into back of MMCS console
- Road Trip Tuned on 91
- Question about 2015 EVO X FE
- In need of GSR transmission (options)
- Idle issues need help
- MAPerformance Evo X Valve Cover
- 2015 EVO X code U0431
- Final drive gear confusion
- New Evo owner. Whats been done?
- Trunk harness question
- Evo X's maximum cargo payload
- Rear seats
- Brand New Motor, With 'Service Engine Soon', light won't turn off...
- 4b11t swap for a 2015 Mitsubishi Lancer se AWC
- Won’t start
- Radiator motor not engaging
- Cylinder #3 Ignition Coil burning hot even with car not running.
- I'm Able To Move My Traction Control Button?!
- Evo X SST Transmission Rebuild
- Mysterious front end shaking at highway speeds--feels like wheel hop
- Short Shifter Feels Like It Wants To Lock Me Out Of Gears.
- ID 1300 with black 14mm adapters
- Should I buy the Evo X in 2021/2022?
- Sell my Si for an Evo X?
- Evo x engine bay rattle/shaking
- Drivers side interior leak
- Tools For MAP cast manifold and Stock Frame Turbo
- Purchasing Evo X in 2021 - 2022
- Where do these 2 harness plugs go?
- Engine Rebuild Taking Over 6 Months
- Clutch Disc Life Left (picture)
- Boost leak Passenger side
- New Exhaust Question
- Short belt anyone?
- Vland headlight question
- Ignition harness clip
- Turbo Support Bracket
- Clutch replacement 2021
- Boot covers
- Evo 6 wing on an evo X?
- Anyone seen this piece before? Fog light related
- SAS calibration failed with air bag light on from aftermarket seat
- Lancer 4b11 oil pump
- AFS SERVICE REQUIRED after installing new VLAND DEMON EYES headlights. please help!
- 2015 Evo x mirror how to remove the mirror as in glass
- Weird Vibration. Please help!!
- PT 5558 gen 2 and 6266 gen 2
- Evo x Headache....
- Please help me identify this clip/grommet!
- No click no crank start on EVO X GSR
- Automatics?
- Need help with a Lancer conversion please
- Evo x ralliart Mr
- Used 4B11 Longblock
- 2016 Lancer GT seat swap with Evo X Recaro seats
- California Modding Frustrations
- Evo X Canbus ID's
- Found My TWM Shifter
- Innovate afr gauge
- ABS/Brake & ASC OFF lights, code C2104 Valve Power Supply Circuit - Need Help
- Evo x idle issues
- Looking for Cobb Stage 3, 93oct map for 2012 MR / MRT
- Evo X Does Not Crank. Help?
- Evo X MR Trans Vs Ralliart Trans
- Evo X Cranks but won't start... is one of my relays blown?
- What color is my 2013 white Evo ?
- New Evo X O2 Sensor Code
- 2015 Evo X hood on a 2017 Lancer SE
- Evo x vs lancer ES
- A/C Recharge
- Power Distribution Center (PDC) ??
- Fuel system upgrade
- evoscan logging with AEM obd2 X series Wideband
- Drinking problem.
- Injen Short Ram Air Intake
- Steering shaft problems
- Thoughts...
