- Fixed: Rear metal clunking noise caused by a worn & torn lateral toe arm
- Official Hawk brake pad bed-in procedure
- Brake Pads opinion
- Hawk pads extremely npisy and lots of dust!
- "Brake system service required"
- camber adjustment
- evo x on cobb springs
- Enkei RPF1RS
- Rim size question
- The Rays "HB1 air valve" can be replaced with a standard TR412 rubber snap-in valve
- SSR rims' paint peeling off
- Wider tire, what size to run? Evo X
- Rear Camber Bolt Removal
- Full Suspension Replacement - Help
- Rear Control Arm Hardware
- Is It Worth Buying Used Suspension?
- MR Bilstiens on GSR
- 19x11 wheels? EVO x toughest fitment?
- Thoughts on using ARP's Celica GTS wheel studs on the Evo X?
- Evo 8 wheel fitment question offset etc
- Goodridge Brake Lines installation help
- Nankang CR-S Directional?
- Flush Mount Wheels
- LCA ... Is this an issue?
- Rear Strut Part - identification
- Brakes and rotors for 2011 EVO MR
- Front Strut Mount Bolt Removal
- Handbrake Parts
- Evo x ACD codes
- Popping noise when turning...
- Need to replace a bushing, have pics, can anyone help identify?
- Evo x brembo calipers bolts
- Titanium Brake Pad Shims
- Tire pressure sensors
- Evo X MR Stock Bilstein Suspension question and information request
- Torque specs on Calipers
- Received a pro tip: Don't buy 5 wheels, just order 4 with a readily available offset
- Fortune Auto 500 vs Revel TS vs Bilstein B16 (PSS10): What's your experience?
- What do you think of run-flat inserts?
- How do u guys feel about 235s
- Enkei T6R Compatibility
- So the aluminum Enkei spare wheel has only a 66.1mm hub bore?!
- Coilovers instal question
- Ride height measurements
- Squeaking from Tein Coilovers
- KW Coilovers on a Cedia 07
- Front suspension arm
- suspension and brake advice
- Strong vibration
- Wheel fitment question
- Different brand Coilovers (R & F)
- Best suspension setup?
- Track Advise Needed - Help me beat a MUSTANG!
- Lowering springs
- Suspension knocking noise after install
- New Enkei Tms Wheels.
- 18x10 fitment
- Spacers needed
- Where to find ceramic brake pads for Evo X post-pandemic?
- How would these fit?
- suspension not working. HELP!
- Suspension knock
- Need help with removing hub assembly
- Will these wheels run into any problems?
- Problem with rear wheels hitting
- Replacement Rotor
- Rear strut thread pitch
- brake have a hissing noise
- Camber arm (black arm)
- Winter tires 2020 - What are you using this winter?
- Back brakes squeak sometime
- Staggered width setups verification on EVO X
- Where to find: Caliper pins???
- Springs or coils?
- What I'll need to do before installing 10.5" wheels?
- Adjustable Struts?
- Evo X MR BBS pricing
- MeisterR ZetaCRD Coilovers Review
- Basic track setup help!
- New Wheel/Tire Set up
- AYC bypass
- Swift Springs
- Offroad Winter/Daily Suspension Setup - Coilovers, Wheels & Tires
- Tire Size fitment Question
- Slight pull to the left!!
- EVO X Front tubular Subframe + Manual Rack - Diamond Race
- Flex Z bouncy
- Will I need spacers if I have coilovers and 18 x 10.5 +15 wheels?
- Do Cosmis mrII fit my 2011 evo x gsr with Brembo brakes
- spacer
- Superpro rear diff mount
- Bump stop and dust sleeve for H&R Coilover ?
- Preload on Coilover
- Messed up alignment
- all season tire
- Air cups?
- new brakes and rotors
- Any way to delete ABS and ability to brake and gas at the same time
- Work kiwami deep concave
- Rear Extender adjuster
- 18x10.5x18
- RAYS CE28 18x9.5 ET28 fit evo x?
- How hard is it to put a strut bar on?
- Summer tyres second car
- ST Suspension 25mm Wheel spacers
- Cfamber Question
- Canbus Timeout Errors
- Adjusting offset of wheels?
- NEO Motorsport Coilovers
- Options for Shocks/Struts
- Car lowering question
- Noise from Hawk HPS pads
- Work Cr Ultimate 18x10.5 +22 Clears?
- Mystery clunk, videos inside.
- Endlink Issue
- ATTN: HELP. Brembo retainer clip
- 16 inch wheel fitment
- Evo x 18x11 +8
- Time For New Rotors/Pads! Suggestions?
- Tire fitment question
- Brake bleeding issues
- Brakes, Rotors, Lines, etc @ Boostin Performance
- Need some new tires. Recommendations
- Evo X Front ABS wheel sensor/ removal and install
- Work Emotion Cr Kai 18x9.5 + 38 5x120
- front+rear swaybars, anything else?
- Spherical Bearing F&R endlinks inquires
- Looking to disable TPMS (NY)
- Front Clunking / Knocking
- Alignment shop recommendations
- Xxr 530d
- Is 18X9.5 +18 good to fit?
- LF: EVOX Rotors for BBK in GTA
- OEM 2-piece rotor clicking
- Summer Tire Recommendation 2019
- Evo x Coilovers
- Stock shocks springs vs coilovers weight
- Front brake hardlines
- Bushing Kits and Coils
- Rims and tires and offset (Oh my!)
- Ohlin's VS. Ksport Bags VS. FA 500 with air piston
- Tire recommendation, please.
- First set of drag radials
- steering wheel shake at 60+
- What wheels are these? Enkei
- Swapping from H&R springs to Swift worth it?
- Noob wheel fitment question enkei t6s
- suggestions on my suspension/handling list
- Brake Hose Bracket Rubbing Against BrakeTube?
- Will Whistlers KR3 18x9.5 +22 clear Evo X Brembos?
- Aggressive enough?
- Absolute best control arms?
- Suspension upgrades
- Looking for red rims to fit my final edition evo
- Ohlins R&T top mount swap??
- 15 evo x gsr 30k mile warped rotors
- Bilstein ralliart spring rate F/R
- Tpms turn off through etacs
- Help evox mr rotors brakes problems
- Need recommendation on brake set up
- Rear lateral links clunk?
- Evo tires for daily
- Brembo Cross Over / Link Pipe
- Shock/Coilovers + Winter
- Enkei RS05RR rims tire size recommendation.
- Who stuffed my rotors?
- H&R springs sagging?
- Does Cusco brake cylinder stopper fit both LHD and RHD, or RHD only?
- Problems with suspension setup
- Brake hypothetical: Can I install Evo X's front calipers to the rear?
- Whiteline KCA414 and Ohlins
- Bumpy feel during braking
- OEM equivalent rear rotors
- Brake noise with direction change or from stop
- Tire size 255/35 18 v 265/35 18
- Camber plates for stock - Cusco Front Camber Adjustable Top Mounts
- Replacement crossover tube?
- Rear Sway Bars
- XL vs SL Rated Tires
- What’s the biggest wheel I can run without cutting fenders?
- What is the best TPMS solution nowadays?
- 18x9 +30 caliper clearence?
- ABS Service Required
- Want to make sure wheel combo fits before I buy
- when to replace rotors vs having them resurfaced
- Brake noise
- Changing tire size on awc lancers
- Clockspring & Steering Angle Sensor question
- Random Hiss under braking
- Smaller Brakes
- 265/35/R18 Potenza RE760 or Eagle F1
- Fortune Auto 500 Coilovers
- Advan RZII 18/10 x 25 tires?
- Where to find new OEM springs
- Brake line plastic clip
- Mixed brake pads for track days
- odd vibration and noise
- A few questions surrounding alignment
- What if 225 or even 215?
- Confused on suspension/alignment???
- Clunk from front Driver, new pads and rotors
- Whiteline lowering springs
- Questions on coilovers?
- Brake & Rotor Packages Available @ Boostin Performance
- 17's on Evo X
- New front pads, some vibration after bed in
- Tophat Dimensions
- Camber
- 2014 MR Rotors
- Negative camber on one rear side?
- Gram lights 57cr 18x9.5 +22 black
- Aristocrat Autosport Evo X Brake Bundle
- ASC/ABS hydraulic unit - handbrake install help
- Godspeed free shipping
- Final Edition wheel center caps
- 2-piece MR ROTOR!?!
- OZ ALLEGGERITA HLT Wheels on Pilot Sports 4s
- Interested in these lugs?
- New Rotors & Pads Grinding
- 2011 evo x rear differential bushings
- Will 9 lugs fit a X?
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- Work cr kai 18x10.5 +22 or +15
- Which tire for the Evo X? Michelin PSS, PS4S of something else?
- FE with the GSR rims
- New bilsteins, WHERE?
- Does anyone have to deal with brake pads freezing to the rotors ?
- Whiteline SwayBar front and rear
- Enkei rs05rr 18x9.5 +22/+25 fits ond evo x?
- Right front wheel jolting randomly
- Sway bar bushings
- "Unfixable" alignment
- Brake Replacement
- Evo x 10.5 or 9.5 rims
- Stock Mr suspension
- Need some opinions on suspension
- Questions About Pads and Rotors
- tire rubbing question
- Rota SVN-R
- Top hat replacement
- Bilstein with lowering springs longevity (Swift, GTWorx, Tanabe, Tein, H&R, etc)
- TPMS Oddities
- Cosmis MR7's spacer needed?
- Found a comparison picture of Work Emotion T7R deep concave vs ultra-deep concave!
- Rear bumper bolt.
- Advan RG3 in racing red!!!!
- 18 x 9.5 35mm offset question???
- Wheel Size For Toyo R888
- help needed tyres/strech Question
- 255/40/r18 STOCK SUSPENSION
