- Driver seat rail sensor
- Cracked radio screen
- Asc system service required
- replace OEM subwoofer
- Car stuttering, MAF Sensor Terminal
- Issues with RCA AUX CABLE
- hands free bluetooth help
- Sensors types
- How to disable driver side column airbag?
- Battery Replacement
- vland headlights not working
- AEM Carbon CD-5 Digital Dash w/GPS and Logging
- replace Rockford Fostage amp and keep speakers
- SYGVA Android Headunit question
- question about stock Rockford Fosgate
- installing radio with OEM mounts
- Key in ignition power turn key no power
- Ralliart 2009 head unit question
- Cannot activate security alarm
- 2008 evo x
- Old & new alternator throwing 18v; small question
- Where do i place S-video cable for reverse camera into back of MMCS console
- Where to find Relay Package?
- Battery Cable Through Firewall Location
- RF Touchscreen Radio
- 2008 evo x gsr wiring engine wiring diagram
- Retro fitting 2015 EVO X door mirrors on 2013 EVO
- Chassis Ground Location
- Lancer with a evo x ecu
- Evo X Battery not charging
- Radio not working
- Sygav head unit maintenance menu
- OEM Back-Up Camera
- Backup camera quality
- Help RF Amp and Android Tesla device no Sound
- "Remove key" is all I get when inserting key
- LED Footwell Illumination
- All power going out after driving. Only brake lights work
- 2009 Gts w Rockford NO Sound
- Fuel pump not priming
- Chinese screen
- 2008 GSR Power Drain - Fuse #8
- Several System Service Warnings (Airbag, ASC, 4WD, and Low Tire Pressure)
- Installing Retrofitted Headlights with Demon Eyes and Halos
- Trunk brake light
- Vland headlights on SSS fuse issue
- Is fuse 21 ignition coil stop the car from turning on?
- Passenger side fender well wire. 2015 Evo X GSR
- Immobilizer / FAST Key
- OEM Steering Wheel Controls & ASWC-1 with Aftermarket Headunit
- Evo X MR 2014 DRL H11 or 1156
- Help 14 sss headlight to vland wiring!!!forever in your debt
- VLAND tail light problems
- 2014 Evo X Microphone Wiring Help
- srs light/backup camera issue
- Pulling fuse for security?
- Help with Evo X navigation
- HELP. Pop and Burning Smell from Amp
- Radio cutting out at high volumes
- Radio Upgrade
- Trunk open sensor
- Windshield wipers in Auto
- Removing/ cleaning up unwanted wiring
- Check Charging Systems ( too much voltage issues )
- New speakers, highs distortion
- Reverse/Back up Light
- Need dump from Mitsubishi Lancer EVO X Cluster
- OEM amp and sub
- Installed: X2Power AGM battery group 35
- Remote start - Compustar 1-way remote
- EVO X RS Control Cruise
- Speed Sensor Concerns
- Installed Alpine ilx-f259
- Radio not working
- LED taillights.
- Evo X - airbag after removing clockspring
- Bluetooth OEM connection
- Evo X Apple Radio
- 10.2 Android 8 Q/A
- Help me original rear cam on trunk
- Electrical - Push Volume Up Volume Goes Down
- John Hodgson
- Alpine HU Install Help
- Headlight Conversion: HID OEM (Stanley) headlight upgrade issues - AUS
- N-02 Navi with 8785A050 bluetooth module????
- Installed VLEDS Micro Evolution fog lights
- Wires under center console
- Aftermarket HU cutting out Fosgate AMP - solved
- VLand DRL Always On
- Dw Hardwire kit help
- Evo 4 Remote Starter Wiring
- reverse light blinks with turns while using central lock
- Projector Foglights
- Sub Setups difficult
- Defi boost gauge question
- Stereo / Radio Options for Evo X
- Engine whine from speakers
- Cruise control issue
- Android headunit 8
- Android head unit recommendations
- Touch Screen radio 2015 in GSR 2011r problem
- stock Rockford fosgate issue
- CobraTrack volumetric sensitivity adjustment
- Is it possible to install a 2014 Evo OEM touchscreen in 2008 Evo?
- Help with turning signals with vland headlights .
- Vland audi lights on sss hid retrofit
- Need Help wiring steering wheel controls
- Battery icon on after dash lights go out, no crank
- Nav unit unlocking
- Please help!
- Check blimps on engine turn off
- SYGAV head unit - automatic bluetooth play?
- Vland Audi Style Headlights Wiring
- Reuse stock Sirius antenna for aftermarket tuner?
- MMCS dvd hack
- Headlight question?
- Factory Headunit
- Connector?
- Ihave a question the front fuse box
- 2011 EVO X GSR, N-03 navi install
- Security solutions
- Does the RF sound system suck?
- What headlights are these!!!
- 2009 EVO X Navi install kit question...
- Passenger Rear Tail light Issue
- Installed: Shorai LFX36L3-BS12 LiFePO4 battery 5.5lbs
- SYGAV Android Head Unit
- Evo X wont crank after engine swap
- Automatic headlight conversion
- Viper 5906V DIY question
- 2011 radio swap to 2015
- What's this plug?
- Rockford Fosgate for Final Edition !!!!
- Android 10.2 not working with amp?
- Remote Starting
- USB Slot on eBay
- MMCS Buzzing when on AUX
- Interior Lights do not work! Help please!
- Dome/Interior lights do not operate
- Recommended upgraded rear speakers & door speakers
- recommendation on top of the line car battery?
- Anyone with Android 7.0 or 7.1?
- '11 MR Base - No Sound
- Serious Electrical Problems
- AWC button light
- Compustar Remote Starter Installation HELP
- Can i install a used airbag module in my car?
- Speech function not working on 2015 Evo FE after OEM Navigation Upgrade
- Parking Lights Fuse Location?
- Help the door pin
- Angel/demon eyes headlights gsr
- comment installer sorties rca préampli
- Evo x radio and fob not working after battery change
- FAST Key Receiver
- where to buy resistors for aftermarket seat airbags?
- about double din installtion
- Fan & temperature switch do nothing, help! They only light up
- Fosgate Amp OEM Replacement not Working
- Prosport gauges wideband not working
- 2008 VRX Lancer Bluetooth Module
- Help identifying wire harness/wires
- Bluetooth problems
- Heated seats
- Did anyone ever install the EDM or JDM window switches in their USDM ?
- Life Expectancy on Stock Evo X Panasonic Battery?
- Aftermarket radio - No Sound - Non SSS
- Aftermarket Headlight Install
- Kenwood DDX917WS/OEM Nav Dash
- Rockford System not working
- 2015 evo x GSR adding aftermarket sub and amp help
- 2015 Evo X sub and amp install help
- 10.2 Quad Core Android Nav System.
- Evo X RF system Headunit and Amp help
- Tapped the spare AWC switch and now problems
- ERROR DC - Stock Fosgate unit
- Audio | Head device
- Fog light harness
- Just installed MMCS, unit works but makes no sound
- Need help with hid not working.
- I need urgent help! Connector diagram c-411
- Headlamp Light Leveling Service Required
- Using Torque App to monitor Knock & AFR
- 2013 honda accord
- 2014 Mitsubishi Lancer EVO NAV Issue
- Rear Parking lights ?
- 10.2 Android 6.0 Q/A
- 14 evo nav problems
- 10.2 Android and Rearview Camera
- 2015 nav fit into 2014?
- MMCS conversion gremlins
- Footwell lighting
- New Aem X series gauges...
- 14+ Outlander dash kit ion evo x
- Question on factory headunit for 2015 Evo.
- 2014 navigation in 2010 mr
- Amp under Driver seat?
- 2015 Touch screen radio on 2008 EVO X
- What to do next for my sound system?
- Odometer reading
- looking for HUD, any ideas?
- Looking at replacement HID bulbs (D2S)
- Brake light and License plate lights
- Best Battery Replacement
- License plate light fuse?
- Tanabe Revel Boost Gauge install help.
- Component or coaxial or both
- MMCS 18.0.0 to 19.0.0 update worth it?
- Easy Tablet Dash Installation
- help on iDataLink Maestro compatibility
- HELP to connect oem reverse cam to android radio
- Fog lights activated with automatic headlights, possible?
- Battery help
- How to install HID relay harnes on Evo X
- Custom CarPC built to replace RF nav system
- RF OEM Amp issue
- Radiator fan plug
- LED DRL bar & switchback issue : always on even when car is off...
- Double DIN Aftermarket Plastic Trim Piece. Where to find?
- tried to install last generation mmcs but no luck
- Halogen Headlights converting to Projector
- Location of wires for brake lights and third brake light
- Evo X electrical issues.
- album art with sdcard music
- Those of you who installed LED exterior lights, how did you pass through the wires?
- Help with MMCS/FUSE versions
- Upgraded Sound System in My Evo FE
- Evo x GSR Halogens to HID help needed
- 2014 GSR double din HU
- best place to to tap LOC and 12v trigger?
- FS:Brand New Original Samung Galaxy S7/S7 Edge 32GB $450
- Varis CCFL Angel eyes headlights : many problems, disappointed !
- Brake/taillight issue! Help!
- Difference Between Headlight Housings
- OEM radio? 2015
- Moritmoto XSB in Evo X 08 Headlights
- 2011 gsr navigation unit advice
- WTF IS THE BEST BEST CAR ALARM FOR THE CAR! It's so hard to figure out..
- Spare Tire Woofer
- replacing navigation sd card
- What car alarm do you have on your Evo X?
- MMCS - Bluetooth not pairing with iPhone
- idatalink maestro sw install question
- What Headlights required for HID Converted GSR?
- Oil Pressure Gauge Issure
- 09 Lancer es stock rockford system harness
- Viper 4806V 2-Way Remote Start in GSR (Advanced Feature Usability)
- 2015 Double din question
