- Issues With SST Transmission
- SST gears skipping rpms
- SST oil leak
- 500hp SST
- Kozmic HP8R SST Rebuild
- TSR Light On/Off & Weird Behavior
- Recent Issues with SSP Performance
- SST Teach-In Not Working
- Problem code transmission P0702. P1637
- What SST version (hardware) do I have?
- New SST - ecutek tuned. Wrong S/W version?
- Disable crawl/creep on Evo X Mr
- SST removal guide?
- TC-SST open clutches when accelerate
- Need help finding a MUT-III
- New Motul DCTF?
- Mitsuboshi 2010 ralliart p181f
- SST Not Working after rebuild
- SST 3rd Gear RPM Stall on WOT
- Problem Shift Fork
- Is the sst trans that bad?
- TC-SST ROM maps
- SST problem
- P0716 code on built box with new tcu board
- Down Switching Modes while driving
- Manual Swap
- Buying rebuilded american SST from Italy
- Trans upgrade suggestions 600hp
- P1831
- Launch Control not working?
- SST File Read/Write/Checksumm correction Canbus Binary
- DCTF options
- Sst jerks when not giving it more throttle from a stop?
- SST Almost stalls the engine when selecting Drive or Reverse
- SST Wont Engage
- Sst stuck in park
- How to separate the SST from the center diff
- P1590 and U0101 codes
- 2010 Sportback Ralliart code P2809
- EVO X SE SST overhaul at Moore Automotive
- SST issues seeking guidance
- Looking for SST Fill bolt - #2502A039
- Any SST experts?
- After teach-in procedure Evo X 2009
- SSP lifetime reusable filter arrived
- Heated Sump
- Liqui Moly Cera Tec?
- SST Temp Gauge
- Refusal to go into 1st
- How much fluid?
- SST loses 3rd and 5th gear, but only after trying to shift into 5th
- GEAR BLOCK 5TH?! Please help
- SST torque damper - repair\rebuilt
- Transmission fluid comparison
- Millers Oils Millermatic DCT-DSG Fuild (as used in the FQ440)
- Evo X mr sst '09 stuck in 2nd 4th and 6th
- 10 ralliart sst wont go in to reverse but goes into drive and drives fine.
- RA with Flashed SST question
- SST grind when turning car off
- Should I buy a Ralliart with bad SST maintenance?
- SST filter upper housing broken
- Stuck in 2nd Gear for first time today
- HELP! SST back alone 5th for 1th
- SST Throttle Requested Torque Base
- Evo x sst 100.000 km
- Evo X C161E Code, What Do I Replace?
- SST Fluids and SST Newb Question
- SST problem: code P1836
- SST. custom tune for higher power
- Problem with SST
- MR does not go into reverse
- P1875 - Damper speed sensor covered under California Emissions Warranty?
- Revhunting fix?
- Big torque on SST trans, what upgrade
- Evo X MR Gear Jumping Issue
- Advice - Rebuild the SST or sell the car?
- Want to be sure - sst failure
- Cvt --> sst ?
- Transfer Case Question
- Launch control RalliArt -10
- my transmission
- Slurred / slow shifting issues
- S-Sport
- 2013 Evo X MR sst wired noises
- SST Program
- Just got my MR's SSTF changed at 10k miles
- P1874
- SST Filter and Fluid Change Solved Codes P2733 and P2809
- Temp Switch for SSP SST Cooler
- Need help to manage intermittent transmission issues of Stock SST
- 08 evo x mr
- 08 evo x mr
- Transfer Case or SST Transmission
- SST transmission issue
- EVO X Check Sign (Triangle with Exclamation)
- Tc-sst p1885
- SST with ebcs
- Need help 2011 MR missing gears 2,4,6
- MR transmisson wont shift into even gears
- Thoughts on Jack's Transmissions?
- Amsoil for SST?
- Can the stock SST go to 400-450hp?
- Whistling noise when boosting.
- Custom SST Heater/Cooler Build
- Dodson heat sump vs. SSP Titan
- Spraying SSTF-I from vent hole/lose of 2,4,6
- 2008 Evo x Parting out full build
- Strange transmission lights momentarily flashing
- Do I need to Strengthening Transmission (SST)
- Amsoil DCT Fluid - Dia-Queen SSTF-I Equivalent
- turbo bbk full or bbk lite
- Clutch slipping when approach to stop
- Evo x sst
- SST issue??
- Clutch Pedal won't come back up after tranny install
- HELP : think the dealership is BS'n me
- About Evo x torque converter
- How I get the shaft out?! HELP!
- Mystery Engine Noises (Similar to Break Squeak?)
- (new)Exedy Stage 1 Heavy Duty Clutch/Flywh EVO X
- How I solved a P1875 torque damper sensor code with just a battery
- Very small tranny leak
- SSP VS Dodson SST Clutch Upgrades
- SES/Service Transmission light
- manual gate or no?
- buying TC-SST transmission for an 08 MR within a few days
- SST Problem, NEED HELP! P187A
- Preventive maintenance for the SST worth the cost?
- Where the hell do I go???
- SSP heat sump
- 2013 MR SST Issue. Dealers can't replicate?
- ABS Delete and SST
- Replacing trans in 09 RA with 15 MR SST
- Car rocks back and forth
- TC-SST Break In
- Great deal on SST fluid
- Sportsman's Plus News ??
- DTC code p3138 - does anyone know what it means?
- TCU Tuning?
- Need help!!!! Sst
- SST leaking
- What's the best SST cooler
- Redline dctf for sst
- ssport manual and shifting at 2k
- Sst cooler fluid flow direction !?
- SST paper filter
- Reverse Light Wire on Console?
- 08 Evo MR Valve Body Assembly
- what year trans interchange
- Sst failure due to fog lights ?
- Help - SST fluid leak
- SST disengaging every 3 seconds
- AYC Pump other options?
- Motul Muli DCTF for SST
- Intermittent P183D //Shift fork 2 malfunction
- MR X SST transmission, jumps from 2nd to 5th and loses power
- BUY Valve Body
- Should I change the filter?
- When driving around in manual mode, do you guys downshift when stopping?
- EVO X SST Sidewinder clutch 600ft/lbs. vs Dodson Sportsman
- SST Won't Engage Gear and dash going nuts
- Mechatronic Unit
- Mut III Help for SST
- Clutch 2 Slipping? Rev delay when accelerating.
- Anyone had SST sent to jacks in CO?
- SST Valve Body Testing
- Transmission Service Required
- sport or s-sport mode when in manual shift mode
- sst owner
- I'm whining (No really I am) - TC-SST Issue
- SST TCU flash question
- Wont engage reverse and unable to pull fault code
- SSP Trans cooler with or without stock intercooler?
- FQ440 MR trans - how is it different from regular MR?
- help sst problem!!
- question concerning an SST tranny rebuild.
- SST leak
- SST Tuners in the Northeast?
- Evo x fq330 and fq440 sst cff
- Won't shift 3rd,5th | P2440 Code?
- Dealer SST Replacement in Atlanta area
- MY12+ Model issue with SST
- 2013 EVO X MR SST Transmission on a 2008 EVO X SST
- New pickup: Dodson SST sump
- New pickup: Dodson Sportsman
- Browse Online Carbon Fiber Hood and Custom Body Kits
- SST loud bang and violent jerk on shutdown
- Anyone copy Super Sport SST Maps to Sport mode?
- How to do a Teach in/Relearn Via 2.0 Tactrix for replacement of clutches
- P1874 DTC code on my '08 MR
- Transmission Rattle at Start-Up and Shutdown
- Third Party Warranty
- What's next ?
- 14 mr
- Car and steering wheel shaking while parked
- SST Flush, what mineral oil?
- About to switch to Pentosin FFL-2...
- clutch upgraded
- Weird when shifting
- Noticeable difference after SSP fluid change?
- Rev Hang questions
- Stock SST Oil Cooler Leak
- Relearn Required (and other issues with mt TC-SST)
- Curious.
- Need Help Locating an Engine Thermo Fan Temp Switch to use with SSP Cooler
- Looking for some SST trans info
- Super Sport!!!
- Shift Points
- Low Speed Whine from SST?
- Ralliart & Evo X MR TC-SST Beta Testing. Flash with Tactrix
- Bung on SST to use for cooler install?
- MR transmission chatter and possible slipping
- SST small "jump" only after a shift
- Please Diagnose my TC-SST
- Possibly slipping
- SST Won't Shift Stuck in Gear
- Difference in MR SST shifting speed....2 videos
- TC-SST Help on 09 Ralliat
- Help recognize this part
- transmission
- throw out bearing
- Loss of power when shifting normal?
- Car jerks when shiffting (SST)
- clutch/sst slipping? not sure...
- Downshift!
- installed accessport v3 and now sst is skip shifting.
- SST - Best Location for Inline Temp Sensor?
- can someone help me out please SST PROBLEMS.....
- 2014 MR makes "thud" sound
- Help! SST Shift Linkage
- Installing SSP + AMS Oil Cooler + SSP Deep Pan + SSP Filter
- Delay for command to upshift
- Update to mastering/cracking the TCU status
- sst issues
- TC-SST Fluid Change - Filter Question
- SST Extra Cooler
- a sudden downshift from 5th into 1st.what the hell???
- Pentosin FFL-2 maybe not so good for the TC-SST?
- The best place to map your sst?
- Random Gear slip 4th to 5th
- Wayne Collona (ATSG) TC-SST Webinar
- Gear slip from 3-5 , Code P1833...
- Dual Clutch Transmission Thread
- Clutch smells please help
- Warranty Issues/Fixing SST(Canada)
- Is it safe not to upgrade my SST?
- Idiotic Newbie Question
- sst problem urgent help needed
- A theory on how you can extend the life of your TC SST transmisisions?
