- Leaking Seals on Transfer Case and rear Diff
- 2014 Ralliart - cracked manifold and possibly more?
- Swapped evo x differential to Ralliart rear cross
- Looking for SST dual clutch CX4A gearbox
- Replacing a damaged intercooler
- Turbo to o2 housing hardware
- 2012 Ralliart - sons first vehicle - transmission symptoms
- 2011 Ralliart bolt torque specs
- Ralliart IMR Exhaust Manifold
- 2014 SST Ralliart return to stock ROM issues (p1870 , p1871)
- Tc-sst clutch
- 09 Ralliart engine help
- P0171 Log Read Help?
- Do evo 8/9 rear cv's fit ralliart?
- transmission swap
- Front CV Axles or Boots?
- P0068 help
- Ralliart 2009 battery drain
- HELP! need a new cat converter, car stuck at shop
- 09 Ralliart
- Engine swap with different parts spec
- Evo X Fuel Pump hanger compatible on a Ralliart?
- how can i find out how much oil i need?
- Evo X / RalliArt TC-SST weight
- Putting back stock downpipe
- Single Exhaust suggestions
- sst problem
- GST Tunes
- Turbo upgrade suggestions
- sst issue fix
- Ralliart exhaust manifold swap
- ECU question
- TC-SST help or suggestions
- Ralliart ticking noise, is this normal to you ?
- 09-10 Mitsubishi Lancer Ralliart Service Manual!?!
- Engine shake and acceleration jolt.
- P0171 code
- Evoscan error c1320?
- 2009 4b11 in 2012 ralliart
- Sst rebuild
- Small Battery Kit w/ EVO X AEM Intake??
- question on dyno result
- Sst transmission help
- Boost failure
- P0012 code
- Evo TCU to RA
- 2008 lancer gts build help
- Stock RA: Down-pipe on Stock turbo??
- Wastegate
- Part Identification (What is this?)
- 2011 lancer ralliart tranny
- Woowoo!
- 2011 lancer ralliart gas smell
- AWC control fluid drain and fill plug location
- 2009 Ralliart idle issue
- 09 gts beginner build help
- 2013 Ralliart UPPER INTERCOOLER PIPE
- Stock Ralliart
- Hello all my 2010 ralliiart
- Transmission stock on park/no power on shifter indicator
- New engine, no start....HELP!!! >.<
- Strange SST noise when shifting to 2nd from 1st
- Help!
- 4g69 6 bolt crank swap
- SST takes a ~1/2-1 second longer to shift UP into even gears?
- Issues trying to find. Used Evo X OEM exhaust manifold
- 2009 Lancer GTS Exhaust/Headers Help
- What is this noise
- 2009+ Ralliart CV Axles
- 2015 Ralliart tuning help
- Anyone else’s 4B11 sound like this? Doesn’t seem normal to me
- need XML please
- Whistling noise please help!
- CAD drawings - ACD Pump
- Engine System Service Required
- Evo X turbo
- How far can I push my 09 Ralliart with 208,000 KMs?
- Max psi at stock RA?
- 3 sec start then stall
- Service engine light MAF code at WOT
- RAX v3 w/ TephraMOD v3
- 09 RA Ecuflash defs
- Sst P1802 code
- Upgrading Ralliart 2011
- Anyone with Launch mode
- Mut Table address question
- TPS location
- Cold start issue with 2011 Ralliart
- Upgrade (wish)list.
- LICP compatible with AMS Transmission Cooler?
- Ralliart to Evo X turbo swap soon. questions.
- Motor Replacement Options
- Loud clicking noise from drivetrain
- Transmission problems
- Teach in SST
- ACD Pump Warranty Extended!
- Looking for a SST Twin Clutch Assembly
- This looks important, fuel line?
- Cracked Exhaust Manifold
- T-Case/Diff oil
- Nice triangle and P0012 code
- On the right track?
- Hypothetical - Ralliart transmission in a 2012 SE?
- 2011 Lancer Ralliart Front Diff
- Evo X manifold to stock ralliart
- Mod List Advice
- Looking for bolt-ons for 2013 Ralliart
- Turbo flange adapter
- Heat shields
- Ralliart transmission help?
- 2014 RA ECUflash XML file
- Engine sound
- UR exhaust fitment issue
- turbo manifold for 4d68t
- 2009 Ralliart idling fluctuation 1000-1500rpm. Help.
- 2013 Ralliart engine knock !!video!!
- Re-tune needed for different intake?
- Price
- Keyless Operation System Servicing Required
- Boost taper over several gears
- Default Sport mode - can it be done?
- What is the indicated oil and quantity for this automatic box evo 10 sst
- Timing chain and oil pump chain question
- Looking For A Known Good Camshaft/Crankshaft Correlation Waveform
- Cam and or crank sensor tests?
- PassThru CAN communication error on flash
- Japspeed Intercooler kit (insanely cheap!)
- 2015 ralliart
- flashing 2003 Airterk turbo R
- Ralliart wouldn't shift after coming to a stop from wot
- Replace BOV with Injen Pipes?
- More hp with stock turbo... ideas
- 2012 RA tranny dying?
- Oil leak "above" the gearbox/tranny?
- Hfc
- cant read ecu 53610016
- Tyre Change
- Evo Scan Not reading boost
- Buying an 09
- Cobb EBCS Issue
- Cobb tuning/EBCS
- 6th gear grinding issues
- Car jerking
- CX Racing FMIC Kit
- Ralliart Chambered Muffler on 4G92 1.6
- The dreaded ASC is OFF/Service AWD
- Engine Click/Knock with RPM
- Ltft
- Tranny Issues
- Flash Died at 51% now car won't start
- 2013 Ralliart Stock .hex/rom $50 bounty
- Do we actually have an option for exhaust?
- Starting issues again
- PS Pressure Switch
- Cobb for ECU tatrix for tcu
- Dayco 71967 and Evo X Map LICP
- xml for JMD ralliart
- Best down pipe and test pipe for 2015 Ralliart
- Twin Clutch Auto Issues
- E85 conversion?
- Exhaust and access port sale. Need to Go!
- Strange Sound - Timing Chain
- Oddball CEL
- Evoscan issues
- 4g93 GDI-Turbo issues?
- S-Sport TCU Reflash
- 02 Housing gasket
- TephraMod
- SST service
- Rebuilding My TC-SST Transmission Next Week
- sport mode not engaging?
- Cobb Maps with Tactrix
- SST experience request! SCV AREA!
- First Ecuflash read triggered "Service Engine Soon" Light
- Evox licp fitment
- Upgrade turbo new intercooler piping?
- Strange loud knocking noise ACD pump
- 2011 Ralliart Comparison with stock turbo & after Evo X turbo upgrade 93oct
- Ets ic
- Wastegate Actuator
- Ecu Flash and boost pill
- Strange transmission lights momentarily flashing
- SST Transmission Downshift
- Wont start after sitting for a week
- rpm shifting
- evo motor-tranny on a ralliart
- Smoking at idle
- Turbo outlet pipe bolt
- exhaust drone
- grinding noise from the rear of the car
- ISO someone to do S-Sport and teach in NE Ohio
- Cobb AP vs EcuFlash/OpenSource
- EVOX FMIC Recommended UICP AND LICP
- 12 Second Evo X Turbo Swap WHP and WTQ?
- Need help! Acd problem!!
- E85 in stock ralliart
- Ssport mode in a RA
- SST tranny issue
- Kakimoto Regu 06&R Exhaust
- Boost Pill - UK Stockist?
- Ticking noise. Please help.
- Clunking noise coming from rear
- Serpentine Belt problem
- To keep my ralliart or not...need advice
- Taking requests for TephraXMOD V3 for RA's
- Identify this turbo.
- Turbo Not Working
- Clunking sound from SST gear box when breaking
- Do I Need A Tune?
- Benchflash questions
- Ralliart issue, please help!
- Want to make an intake.
- What to do When ACD Fails (Out of Warranty)
- Unsure if I need to get tuned.
- Time for that upgrade.......
- Is an intercooler necessary?
- SST trans probs Kinda
- Unplugging the wastegate solenoid?
- Possible transmission issue or just need fluid changed???
- service engine soon code........
- Starting Modification
- Boost?
- Traction control
- Ralliart O2 Housing Vs Evo X Housing
- Launch control ?
- SST tranny education
- Now MY ACD is failing...
- Exhaust Manifold Cracked
- SST Problem, NEED HELP!
- This pops up on my dash. Any idea what it is?
- fuse for AWC pump??
- EBCS Pinout?
- New owner, possible issue, questions.
- How to read evoscan 2.9 sst log?
- E85 and flex fuel sensors
- Ralliartwga
- Throttle Body upgrade?
- [WTB] Ralliart 09 Exhaust Manifold
- Ralliart Cylinders Leaking 40-45% - repairs over 6000$?
- Blown Turbo/Seals?
- Twin Clutch SST questions
- Tranny help (lulz)
- bov fitment
- Evo X turbo swap -Oil lines options
- TurboXS-EvoX-CP with CP-E cat back? (Ralliart)
- Questions about a mod list
- Cobb accessport v3
- Borla Cat-back and what HFC?
