- Loose steering column
- high rpm
- bad noise?
- odometer
- Clutch problem?
- turbo lancer running lean
- Anyone have leakage?
- Please Help Lost Gauge Lights!!!
- tach issues
- Noise from Rear Suspension
- buschur racing downpipe problem
- blowing fuses, no rear running lights...
- my car is over heating!
- Will an Evo 8 Downpipe Fit OZ Rally
- auto tranny grind/hard shift
- auto tranny hard shifting/grinding
- Sagging Lowering Springs?
- idle drop ????
- Oz Feels Bogged
- Service Engine light???!?
- wtf do i really have to pay?
- running guage wire thru firewall
- need help on wut to do! Kamikaze headers
- can punctured radiator be fixed???
- Help.....!!!!!
- OMG! Accidently drove through a FLOODED ROAD with my CAI...
- exhaust hanging to low....help..
- low idle
- Help! My Engine wont start?!?
- Rattling or CLicking When in Reverse
- Hitting elbow in the 4th gear
- Somthings a leakin....i am scared
- going back to the dealer once again..
- Car running badly (02 Lancer OZ)
- broken teins
- HELP!! In the middle of my test pipe install.....
- problem with tranny ( taking to dealer)
- really fast help please...
- tail light troubles..
- exhaust banging on sway bar perch..
- noise underneath the hood
- Looking for help from anyone who works at a dealership
- Loud noise while AC is on
- Please Help
- A'PEXi S-AFC
- Oil in Exhaust
- Water Leak!
- front strut causing vibration noise
- Rear bumper dent repair
- AEM cai problem!!
- Slight vibration when parked..
- Spark Plug Replacement
- S-AFC Japanese INstruction
- How to align Lancer (ES, LS, OZ) headlights.
- Question!!
- Foggy altezza's? Here is what I did
- ODBII & PC Access ['02 & '03 ES LS OZ]
- Headlight alignment question version 2.0
- weird noise
- Who is actually running 80+ watt headlights?
- How does your car idle?
- Taillight survey
- brake noises....
- Signal Lights going tooo fast
- removing stock brake rotors
- Help a brotha out!
- earthing/grounding kit
- RRM SRI cf shield rattling
- Lights out on Gears and Ashtray
- Rubber seals around headlights
- rrm hood duct
- Turn lighs
- Car idels high...
- Question on Passenger Airbag
- Engine RPM stalling!? 1st gear light throttle problems
- Mil Eliminator - Read!
- Kamikaze CEL plz help
- engine surging
- rrm tail lights
- SERVICE ENGINE SOON light?????
- steering wheel hub
- No Ac!!!
- Engine Noise
- Intake part needed
- Ahh. The stench of burnt plastic bumper
- wtf help please low idle jerky accel
- aem cai installation
- Clutch pedal adjustment?
- Magnecor Wires
- What happened???
- possible fuel cut?? opinions needed about this problem
- RMR strut bar + Injen short ram = pinching
- Headlight Out?!
- 87 Octane + SRI + HOT Weather = Boggy Engine?
- removing stock steering wheel for an evo 7/8 steering wheel
- New HeadLights
- new car burns oil.
- C/F Hood
- Spedo/Tach Lights went out.
- How to Rid the CEL....so far..
- ?Removing Passenger Side Airbag? US OZ Model
- Nuclear Meltdown Temperatures
- how many pipe pieces in greddy exhaust system?
- FMU How To?
- exhuast sound
- RRM intercooler
- CEL on RRM Headers
- Passenger tire is rubbing
- Anyone else have sucky breaks?
- Engine noises
- Please help me with TYC Taillights!
- sparkplug coil packs flashing?
- D*mn Bolts
- Help!
- RRM clutch disk and pressure plate Q
- gas tanks?
- Problem with my moonroof
- if i take off my aftermarket muffler?
- Welded Bolts ?
- Help reversing in 5spd
- Right Tire Pressure
- autometer oil pressure gauge
- What do I say to the Dealer?
- Lancer engine is junk!
- Need Oz Ecu Wiring Diagram
- RMR intake question
- A/C Overflowing onto Floor
- My car needs an alignment bad..
- Getting Headers!?
- Second Gear
- shift boot
- unbalanced wheel?
- Lancer is stalling!
- Problem with My clutch? Help please!
- Blew Fuse from Cigarette Light... WHAT TO REPLACE?
- problem with my engine
- Sidemarker lights
- Stupid license plate frame
- check engine light?
- Front Right Clicking Sound??
- My O?Z lost a bit of torque?
- AEM EMS problems
- Grinding noise after kill.
- New Altezza Help
- Wrecked 03 OZ Lancer
- Catalytic Converter
- I want to drive around w/o my hood...
- Alternator noise
- Nitrous Question
- Sill having notchey 1-2 shifts
- Front Bumper
- Squeaking Rear
- Squeaking
- Inlet size for RMR replacement filter
- MAF sensor help
- Couple Things...New to this too
- Problems with Deyeme motor mounts???
- exhaust not as loud as i hoped?
- failed gsx pump swap
- Intake Help
- Faint rattling sound
- Clear plastic guage cover
- o2 sensor voltages?
- Greedy Evo Exhaust
- Feels like rotors are warped.
- AEM CAI Install Tips
- the battery
- Clutch seems to bite when cold - causes 'stutter'
- RRM SRI Install Help
- rmr intake help/pointers
- arospeed front upper strut bar
- coilover problem
- ECU wires and an AFC
- Acceleration pull
- oxygen sensor simulator
- Help Please! Short Ram Intake! Install!
- HELP!!! throttle problem
- Tail Light "out"
- Car Shuts off when cold?!?!
- Intake or Electrical problem??!!!??? HELP
- H/U and Clock black out
- need help removing rotors
- http://www.spiralmax.com/
- Anybody Online W. Test Pipe ??
- ECU pinout diagram for US spec OZ?
- Factory Wing/Wiring Removal
- engine
- Shaky Driving ?
- pls help tail light not workin'
- tail light not workin'
- removing dash !!urgent!!
- relocating battery to trunk
- MAS Adapter Plate
- Ecu
- Header & CEL. Please help!
- Headlights on while switch is off
- Fuel gauge off a little?
- RRM Exhaust
- Head lights
- i got a problem with me 2002 lancer
- Steering Wheel Shakes
- KN filter
- Noise coming from 2nd cat
- Replacement wing mirror
- Should i push for this to be fixed?
- Friggin busted gasket!!!!!
- Engine Problems........
- Turbo done/have bad tap?
- Test Pipe Prob
- Possible Control Arm Recall
- possible ECU problem...people who know about ECU's HELP!
- Back Seat Prob...
- Noise after new intake
- RRM exhaust
- Seat Burns
- Breaking at High Speeds
- regarding eibach spring install
- Mother Kills S-AFC
- Car Shaking
- put..put.. CEL again
- warranty voiding
- i need help installing my apex-i SAFC!
- Shor Ram Intake
- Check Engine Light
- wheel noise
- I think it's dead
- Installing Optima Yellow Top
- Fender QUestion
- serious or not?
- Header question...help
- Newbie's question
- fart sound
- engine is laggin
- Paint chipping
- Help QUICK! w/Greddy Exhaust Install
- rattling
- Turbo and emmisions?
- rrm exhaust nut size?
- need help with wiring through front doors.
- Water in headlight...
- bulbs
- HID healight kit
- Squeaky rear suspension...
- ac controls
- brakes
- blown fuses
- Help Me!!!!
- need some help installing strutbar
