- idle problems
- rear defroster
- ECU Reset
- does this sound like i have a tranny prob?
- handbrake adjustment?
- ECU help
- straight pipe
- Warped rotors
- Flat spot
- Hit A Curb
- squeeking
- Killed my engine
- Dire help needed for catalytic converter
- Scraped rear bumper!!
- Mitsibushi lancer Paint?
- my rpm fluctuates
- Which wire is the correct one for a air/fuel gauge?
- Urgent!! Need Help!!!
- Water In Trunk?
- Annoying Creaking Sound..
- Suspension Problems
- cant get it back on!! please help
- wiring behind gauges
- worrysome problem
- my lancer is 2 tone grr
- evo VII hood
- Air Intake problem
- test pipe question
- fuse help..
- how to install pivot shift light
- Headlight alignment question.
- Which MOD Chip is the best for the Lancer 2003 LS?
- SRS Airbag Light
- Help..I need advice on a repair problem
- odd sound
- How do you install fog lights in a 2003 Lancer LS?
- New Lancer 2003 LS Whistling Sound
- New Lancer 2003 LS Steering Misalignment
- depressed...burned clutch
- "clacking" valves?
- Last Nut 4 Header
- is my car ****ed up
- Headlight Bulb Socket
- rrm header
- i think i got hydrolock
- very strange prob
- massive smog
- wierd sound
- SHift Knob
- Eibach Pro-Kit rubbing problem.
- Lancer Fart?
- Removing Front Bumper
- rmr intake idle
- Slight Rattle at high Revs
- HUGE problem!!!!!!
- Shifting gears...
- dents above the drivers door
- How do I get moisture out of my headlight
- Pinched Vaccum Hose
- I need help with my check engine light
- oil plug
- testpipe mpg??
- Recalibrating Gauges
- Flakey electronic logic?
- oil light
- when i turn my car off...
- Buschur exhaust fitment
- Aem Cai
- Seat Belt Light
- automatic high idle
- strange noise
- Headlight Adjustment
- Silver Star Headlights
- Test pipe installation question
- RRM intake installed....question?
- knocking lifter??
- how do i reset the "service soon" light?
- How do you turn the CEL off?
- Road Race exhaust section rattling
- wiring safc
- front end alignment and kamikaze header
- SES and ECU Computer Code advice
- flat tire... hehe actually I noticed rust when changing it.
- motor mount question
- Headlight Fading Question
- Evo7-style Grill
- Vaccum Hoses
- Clutch Chatter
- Maintenance question.
- Windshield wiper removal
- RRM Brake Pad Instal Help
- engine question
- RRM throttle body
- Breather filter..
- power loss
- Gasoline Smell...
- yellow valve cover
- eninge bogs when i give full throttle
- RPM's falling backwards
- Engine stalling after RRM Valve Cover installation
- engine prob
- Gas smell in oil
- Daytime running lights...
- mas swap
- Mas Sensor
- spark plug Q
- Steering Problems?!?!?!
- turbo ok..intercooler?
- Front Signal Lights Broken
- e brake and battery light flashing
- ecu harness for installing apexi afc???
- Turbo lag
- RRM exhaust install . .
- RRM Intake and MAS Problems
- Mitsubishi Shop Manuals
- Installing a MIL Eliminator
- hesitation during acceleration
- Idle Problems to Stall..
- Adjusting headlight angle
- powersteering
- Cruise Contro and RRM Throttle Body
- Broken Injen-Anyone else?
- Wiper problem
- help anyone?
- Just picked up RRM exhaust...great but too loose
- my cel is on and i dotn know why
- Major Concern
- need help installing tach
- 11 Thousand Miles and Dropping Oil...
- Front license plate scraping
- Cool Morning Car Noises
- brakes,tires,struts, pull to the right
- Kamikazi header gasket
- Shocking
- Door Handles
- Ses
- Pissed off at exhaust
- fog lights installation
- hooking up a tach
- Kamikaze Rattling
- Aem Cai
- firewall plugs
- odd noise
- Paint peeling?
- tapping noise coming from front driver side tire?
- clicking noise
- steering
- Optimum catback/piping size?
- Hit the curb with my rims CHROME
- Muffler rattling
- anyone have no problems with kamikaze header?
- front bumper
- How do you remove wax from rubber?
- Kamikazi Header Help!!!!!!!
- Service Engine Soon light not working
- Is that just heat shield?
- some crap comming out of my car?
- Does anyoens car make a loud knocking noise
- RRM rear sway bar noises??
- Rock I hope your online...
- friends lancer intake problems
- Headers and the CEL?
- Lugs..Damn it.
- %&#!@ damn top strut mount... NEED HELP!!!
- Test pipe install problem
- Front License Plate
- IAT sensor
- Electrical problem
- Breather help!!!!
- warranty...
- WTF!!! check engine light off now
- rev limiter eliminator? anyone
- chatter clutch? dealer says normal when hot
- Catalytic converter going already?
- Header help....flange gasket
- Need help with the instrument cluster
- Intake into AIRFLOW SENSOR?
- Spare tire problems!!
- Turbo Layout
- Lancer steering wheel??
- Minor Weight Reduction
- Help on Alignment (Caster & Camber Specs)
- Summer=Slow Lancer
- rmr strut bar?
- do mirage parts fit us lancer??
- Cruise Control
- ALT Fuse on Batt.
- what oil to use????
- Injen CAI problem........
- My OZ Lancer Paint is Fading Green
- Front Grill Chrome? How could I shave off?
- Advance Timing Kits
- new wing, holes or no?
- Help...
- just got exhaust..
- Where to get a MIL elliminator
- Alarm signals don't work?
- i have a problem.........
- does your car start instantly?
- powerless engine
- Odd noise
- air filter box
- Curving noise
- how can i install Windshield Washer Nozzle lights.
- Tie arm thingy
- Kamakazi header :-(
- Damn engine problems.
- RMR strut tower brace question
- Oil Levels?
- Need Help to install RRM strut bar and exhaust.
- K&N Filter maintenance
- RMR intake
- no stock exhaust
- Switch the A/C ON
- A/C Controls
- cold air intake
- Does your lancer make noise
- Engine Noise on cold startup
- Oil change
- Injen intake diameter
- nasty a** stuff coming out of the intake
- paint chipping?
- i dont know what else to do now :(
- Help
- gum((
- Help.......
- K&N Performance filters
- missing pages in the instr, for intake...
- So, how long is this gonna take?
- problems with MSD DIS-2 box
- funny noise coming from under the car...
- The brakes!
- Evo 6 Wing.. looking for
- cylinder tackling noises
- You will get a CE light if...
- Can anyone help? MAF
- Loose Throttle body cord
- Tackeling noise on idle coming from gear box
- A blue crayon...my life is hell now.
- interior seat problem
- Turn Signals
- Fixed the vibration in the trunk from subs
- HID xenon light problem
- prob with rrm exhaust
- Inportant Lancer GLX 2WD to 4WD conversion
- Does your Lancer bounce?
- My lancer pulls from the start
- Removing The Front Bumper
- My left lights (and guages) are out... any idea?
- Breaking in the Lancer..
