View Full Version : Lancer Troubleshooting
Pages :
2]
11
12
- 2003 Lancer ES - Constant battery drain
- '02 es, another no start
- Help with doors unlocking
- 2004 OZ dies during idle
- Misfire while driving FRUSTRATION!!
- P0335 and P0340 - Car Runs Fine
- Motor Mounts and Transmission Help
- Strange squeak
- 2002 Lancer ES won't start
- Codes after 4-2-1 header install?
- Radiator fan
- Alternator/battery relay?
- Input and Output sensor locations ?
- HELP! Battery drain and blower motor will not stop
- Door Locking issue
- problem with a EVAP HOSE, dont know where to plug
- 03 Lancer will not start
- Transmission Issue
- Radiator Fans Low Speed - Fan Control Module
- 03 lancer e's running issues
- Erratic speedometer 03 Lancer LS A/T
- 2003 Lancer Radiator Issue
- Bad transmission help?
- Car wont start. Simple quesiton.
- '04 Lancer ES - No start (detailed story)
- 03 Lancer Es rough idle/vacume leak
- 2002 lancer loose wire, solutions??
- 02-03 vs 04-07 rear doors
- Ac off or not cool makes my motor die
- 2003 mitsubishi lancer es ignition coil issue help
- P0171 EGR valve smoke test leak
- 2004 Lancer ralliart keeps blowing fuse #1 in the dash -no start issue
- 2002 Lancer ES P0443 - Evap Purge Solenoid
- Fuel sending unit going bad? 2002 OZ Rally
- A/C delete belt for 2003 Lancer models
- My Apexi SAFC was stolen now what?
- 02 Lancer ES - Sway bar bushing help
- 2007 Lancer ES
- Test Pipes??
- Will 2003 lancer es engine wire harness fit a 2005 lancer es? both 2.0
- 2005 lancer es egr insufficient flow
- tricks on removing this motor mount
- Persistent EGR Issue
- Lancer not starting
- HVAC Concerns
- 2002 Lancer with P0443 code.
- 2003 lancer es rough idle !! help !!
- What's this? Help asap. with pics.
- 02' Lancer front passenger window problems
- AC Relay or Clutch Gap?
- Lancer blowing hot air
- 03 lancer es trouble starting
- Recovery from water damage
- Catalytic Converter Issues!!!!
- 02 Lancer ES Idle/Electric Issues? Please help!
- Return fueline non existant after newer engine swap
- 2002 LS Dieseling
- A/C Compressor issues
- Dying Lancer Seeks Assistance :/// (sludge in bell housing)
- Intermittent Wiper Upgrade
- 4G18 Idle Problem
- just bought 03 lancer oz rally
- Lancer 2.0 P0303 code trouble
- Boss kit for a 2003 Lancer ES
- AC won't take refrigerant/blow cold air.
- engine vibrations
- How do I replace the backlight in the Automatic Stick?
- 04' Lancer! Catalytic probs!
- Rattle noise passenger side dash area
- Unknown Emissions Part help
- 2003 es overheating
- Dead ECU
- incorrect egr flow on 03 lancer oz rally
- Does alternator power run through battery terminal fuse?
- Cigarette lighter/ashtray wiring.
- will an Evo 8 steering wheel for in my '03 lancer es?
- Spindle fitment
- Lancer jerks when accelerates
- Poping sound when turning
- P0134 code, no activity, bank 1 sensor 1
- Starting Issues
- Downshifting gears from 3rd to 2nd-impossible
- parking light issue
- Rattling from brake??
- Hazard/Signal won't work.
- Ashtray light isn't working...
- cranking but no start...
- New Timing Belt Clunk & Slight RPM Surge
- Key was not turning
- 2003 oz rally no start. has fuel and spark
- 2002 OZ cluster light problem
- throttle body problem
- Replacing motor mounts - a cautionary tale
- Major coolant leak 2004 Lancer ES
- Window Regulator/Cable
- 2002 Lancer OZ Rally Overheating problem!
- Lancer spedometer problems
- Gas pedal sticking
- 2006 oz rally clutch or transmission, help
- Totaled body engine okay wont start
- What throttle body would fit an 06 lancer es?
- Why wont me lancer start
- 4G93 cam sensor, Cylinder misfire issues
- Turn signals not working
- Weird power issues...
- lancer ex original headlight adjustement
- Adjusting 2004 lancer oz rally headlights
- Lancer ES Won't turn on. Need help!! Please :)
- 7.5 fuse keeps blowing after hitting a rock on FWY
- vibrating sound when driving?
- Gasoline Smell
- P0420 Code on OZ Rally
- 2004 OZ-Rally alternator problem
- P0134, P0138pd, and P0141 Questions...
- 2002 lancer running rough
- Idle drops when using HVAC fan
- 02 Lancer Fan spinning fast/Temp Gauge going up
- 2006 ES Flywheel HELP
- Lancer Indicator Light Issues
- New Battery, New Problems?
- 02 lancer ES check engine light NOT coming on
- 2002 lancer cedia glx issues 4G18 1.6l Aisan carburetd!!
- complete lack of power after timing belt shredded
- Throttle Body??
- License plate
- Fuse Box Needed
- Code P0171 Please Help!!!!
- Auto Gear Change Cable
- a/c compressor/harmonic balancer problems
- Power Steering Idle/Tensioner swap???
- bad bearing, but which one??
- P0137 and P0421
- Engine Noise After timing belt, normal?? Please help
- 04 lancer oz rally, car starts and runs but cuts off when driving and come to a stop
- Foam Piece in OEM Air Filter Compartment
- Car stopped running please help!
- 2003 Lancer ES Steering Wheel Swap
- No power to fuel pump!
- 2002 OZ Rally A/C Blower and A/C Clutch - strange behavior
- Quick relay question!
- 03 lancer stalling when im try to pass or W.O.T
- Car won't start but cranks!! help asap!
- Remote start cranks but will not start without the key in the on position
- AC/Heater blower always on and also radio issues (not sure if they are related)
- Pioneer H/U not putting out any RCA signal - Lancer related?
- 2002 lancer OZ lose power high RPM
- Drain Hose @ Firewall?
- 02 lancer oz clutch bleed problems
- Lancer worrying engine noises (help explain)
- Is this safe? (Pics Included)
- 03 lancer es passenger side headlight
- Need help with programming new remote
- sputtering lancer... maf issue
- 03 Mitsubishi Lancer Oz Rally Suspension
- Front Right lower control arm rear bolt
- A/C Compressor leaking
- Engine hesitation issue 02 Lancer OZ
- engine trouble with my 2002 oz rally lancer
- idling Problem
- How to identify if a Lancer has keyless entry built-in?
- radiator core support replacement.
- Wife's ES
- Smug AssWife
- Evo 5 recaros
- Side Skirts interchangeable between trim models?
- SRS Catback Silencer
- Rough Idle / Engine light on
- Engine control fuse #8 keeps blowing
- A/C turns off
- Fan/AC issues 03 es
- 04 Lancer ES small issue when first starting...
- A/C issue
- Lancer fuel gauge problem
- Cruise Control Problem
- Wiring Help! Car not Starting!
- 02 lancer oz brake issues
- Spark Plug and Gaping
- 2002 Lancer ES Shift hard around 20mph
- Rea shoe replacement fiasco
- MN164188 Positive terminal connector
- Fast Tapping/Clicking noise while in Drive 2004 Lancer ES.
- 2002 Lancer OZ Sway bar link?
- Need some questions answered please.
- Depo Projector Headlights, Should I modify the terrible cuttoff?
- Fuel issue?? help!
- 2002 Lancer OZ Rally, No brake lights.
- 06 Lancer Tensioner Pulley Alignment
- '02 Lancer - Grinding noise when driver door unlocks
- Headlight Adjustments
- emissions problem
- what is this and where can i find one.
- a/c charged, no fans, intermittent compressor
- LED Strip Lights Q
- Lancer oz 2003 temp issue
- changed plugs and now running rough
- Inner tie rod question
- O2 Sensor for 2002 lancer
- Fixing 2003 Lancer LS Nightmare
- 2006 lancer oz evap problem
- Instrument Panel Problems
- 03 oz DRL's wont turn off!?
- RPM Dips
- 02 fouler and p0421
- Siphoning gas out of 03 Lancer ?
- 02 Lancer OZ Rally - Transmission Kicks Hard
- 2002 lancer OZ Rally cold start issue
- Is the sunroof fuse missing?
- Passenger right light being stupid.
- Horn Does not stop
- Stock Cat for cheap
- Front parking lights problem
- Help 03 ls evap nightmare
- 2002 Lancer OZ "thumpping" noise
- Electrical problems after fixing wire harness.
- P0421 pcm
- 02 lancer es electrical confusion
- ?? 4g94 dohc idler
- Power Steering Fluid for 02 Mitsubishi Lancer
- Any ideas on where to buy 03 OZ Rally trunk mats and wire harness?
- Need help with side mirrors
- Cars leaking oil!
- My car is electrically doomed /: Please attempt to help my poor lancer(Smoke&fire)!
- 2002 OZ AC won't turn off
- spark plugs covered in oil. 2003 ES
- Engine dies
- need help identifying a part
- 02 es
- 04 OZ rally having some bizzarre problems!
- Fusible link on battery?
- 2002 Lancer E.S. Won't Start?
- Help with HO alternator!
- need some quick suggestions... 2006 oz
- my 02 es wont accelerate.....or drive..help!
- Random White Connector Hanging by Left Foot
- 03 lancer bogs down
- 2002 lancer es o2 sensor Heater circuit malfunction bank one sensor one
- Car won't start!
- Power Failure
- Vibrations in acceleration/deceleration
- Airbag Control Module replacement, $850 dollars?
- 2002 Lancer Oz possible clutch slipping
- Hard Wiring L.E.D driving lights...
- dash light is not working ('07 lancer)
- Do not get exedy oem replacement clutch for 06 oz rally
- 2003 Rear window defogger not working
- 2006 lancer oz rally clutch install issues need help asap!!
- 2002 OZ Fuel Shut off valve
- 02 Lancer es heater hose leak
- Need Help Diagnosing Overheating Problem on 2003 Lancer OZ
- Lancer ES/ EVO Exterior Compatibility?
