View Full Version : Lancer Troubleshooting
Pages :
4]
11
12
- Heater problems
- Loose motor or tranny mount?
- No heat!
- Misfire?
- Coil not triggering properly
- Engine Bogs when heavy acceleration
- Poor Heat - OZ Rally
- oz rally turbo, erratic idle and sputter
- squeak from motor?
- no heat when idling
- Headlight "ring" broken, can't find part number, or buy online
- Temp Gauge doesn't move
- auto trans sounds like a lightsaber! LOL
- engine control fuse blows out
- corner light problems..advice
- Electrical Problem
- low fuel light
- Stereo issue.
- Trying to find this part.
- Headlights pulsing and car is idleing low.
- Gauge Cluster issues
- Paint [Evo and OZ Rally]
- Temperature Gauge - Abnormal Behavior?
- HVAC - Blend Doors - Possible Solution?
- Help please with acceleration problem
- Right Brake Light Problem
- Cluster Lights - Help!
- Uhohh
- AC/heat controller
- Help Removing Lic. Plate Light Covers
- fuse box replacment
- Hard Noise
- Replacing timing belt and need to know pully positions
- Noise when going from engine brake to acceleration
- Please help me diagnose my problem
- Ticking Noise after Timing Belt Install
- 04 Lancer ES Timing Belt Help!
- Car smoking like a champ! HELP!
- car heater blows cold air
- Front signal marker trouble
- Left front wheel issue
- Reverse lights not working
- Odd noise?
- HID problem
- Shudder In Drive but not really in P or N
- A/C recharge after accident
- Radio shuts off
- Idle Problem
- Engine Won't Turn Over
- overheating issue
- Long term fuel trim High...
- 2002 Lancer Stalls at red light
- need electrical/charging system help
- Need Help!
- Gas pedal rattle
- 03 Oz Missing?
- A/C Problem
- Lights dim, battery leaks acid
- Engine probleme
- Dumba@@!!! Drove threw high water!!!
- install intercooler on 02 lancer?
- Please help!
- Brake problems on 06 lancer es
- 04 lancer ES troubles (cooling)
- MAF sensor or IAC motor?
- A/C Leak
- Startup Squeal..
- 02 oz rally turbo downpipe
- Need Help With 'O3 OZ Rally A/C Clutch Questions
- 02 OZ Electrical Issues (Reverse Lights, Parking Brake Light, Low Voltage Light On)
- drive thru overheating
- 03 Lancer LS noob questions
- A/C hisses, blows warm
- Fan control relay/aftermarket hose adapter issues
- AFR problem Ralliart 2006 RRM 16G Turbo
- Extremly low idle
- sqeak noise
- lowering kit vs coilovers
- ok 2 problems. rattle noise from brakes and o2 sensor
- New... everything.
- Mystery car problem
- timing belt replaced..or no?
- A/C Smells Weird
- Headlight Issue
- 06' Lancer- Odd issue when hitting bumps?
- sputterin
- Rear Window Power Switch
- Engine Issues
- Idle problems 02 lancer es
- Weird Ticking noise on 06 lancer
- Oz antifreeze problem
- AC Stays On
- 03_lancer_OZ..PO507??
- Gas Cap Issue
- idle probem
- Tranny acts up with AC on
- Engine noise after timing belt change...
- 03 OZ not always starting
- power source for gauges!!!
- Shift upswich circuit?
- 02 lancer exhaust brackets
- Inner tie rod removal tool for 03 lancer oz??
- Strange o2 Problem with 4g64 lancer
- 2003 Mitsubishi Lancer A/T Fluid Pan Torque Specs?
- Slave or Master cylinder problem?
- Need scan tool and column ECU harness
- AC cycling/making knocking noise
- lancer idle problem
- Trouble with Springs.Please Help
- Serious electrical problems
- 03 Lancer Evo VIII Window Visors?
- Removal of Front Headlights
- Will EVO 9 side mirrors fit an ES?
- Going to Turbo my 06 ES
- Sunroof
- Head Stud Installation
- gauge cluster drop / stuck
- Indepth question regarding cat/02
- car mysteriously shuts off while driving
- Constant Fogging Cedias
- Cruise control not working
- A/C system
- Power steering pump going??
- 02 Lancer ES - Fuse Box Diagram
- 2003 Lancer ES Intense Rattling When Stopped (Automatic)
- Need some help!
- 2003 OZ Rally front speaker blown.
- Electrical Problem: flickering lights...
- Rrm piggy help again
- HELP! Problem With Fuel Pressure
- '03 lancer stereo wiring diagram!
- Taillight wiring harness>?
- Depo Projector/HID Setup.
- Wheel Stud Replacement (Front Driver Side)
- Exhaust help
- Valve Cover
- ecu bad maybe?
- NEUTRAL SAFETY SWITCH aka PRNDL switch
- o2 Sensor
- Strange smell on new Test Pipe-Catback
- Squeaking noise when accelerate
- emissions not ready codes
- Gauge lights out and dashboard
- Engine hesitations
- Exhaust system problems.
- Need a pic of an OZ rally lancer seatbelt...
- the clip in my headlight .... better in or out
- Warm Up Heat Catalyst??? what what what
- Gas Lid Wouldnt Open??
- RPM's go up and down when turning?
- Instrument Cluster LEd Question
- Car overheating
- cruise control light
- Red lug nuts for 2003 oz
- Low idle (almost dying) when coming to a stop...
- Low profile rims/tires and wheels bending..
- 06 lancer lock cylinder
- Car Shut Off =(
- Fuel Sender Wire color
- service engine soon light
- Projectors & HID 8k $299.95....Need opinions!
- 4-2-1 OBX Headers
- can't pop my hood..
- weird engine squeal type noise
- Anyone with 03 struggle with changing headlight bulbs?
- engine wont turn over
- New exhaust on 2003 OZ
- Any decent ebay parts?
- 02 Oz Cluster light issue
- Cruise Control
- Lancer OZ Rear Bumper
- adjusting aim of headlights 04-06
- DashBoard Light Problems
- high rpm, no power
- Misfire Problems
- so now what...
- Need help Troubleshooting... EGR Valve Maybe
- car wont start
- Alt problems? Brake n Battery light On...Help me out..
- Question about Condenser Fan
- Engine Fan Issue
- P0335 and P340 faults
- power flickering/flapping? bad plugs?
- CEL Question
- 2006 Lancer Stalls on start
- pass suspension noise
- Quick fog light question....:)
- Bent a performance rim..advice..
- 2003 Lancer OZ and 2004 Lancer Evo Mirror Compatible?
- Fuel injector problems?
- shake
- cel code 456 issues
- Need Help! Please! Airbox disassembly/ maf adapter installation
- Brake Light
- Po421
- Question About Dash Lights
- squeking rattling noise
- RPM idle is low Please help!
- SES - Threw x2 P0181 - Fuel Temp Sensor. Fix?
- Fixed Blown Head Gasket. Need help clearing Code
- blower motor bulletin
- Washer Tank
- Question about 2003 Lancer OZ Air Conditioner
- headlight
- A/C vibrations and Warm
- Need Help tonight ASAP on Crankshaft Positioning Sensor Location PLEASE!!!!
- Spoiler Question
- my 03 lancer es
- quieting down exhaust???
- AC light not lighting up???
- Carbon Fiber Hood?
- turn signal/HZRDS
- Fuse Problem! need help asap.
- headlights wont turn on?
- Lancer Factory Service Manuals Available Here
- Idle Problems
- Help... where should this go??
- 2002 Lancer OZ Rally Repair manual
- Engine getting too hot?
- Timing belt repair
- 05 ralliart hvac control panel
- Blown had gasket changed now low comp??
- Trouble after intake manifold install
- starter question
- AC/heat stuck, won't move. Sun roof problem too.
- vibration in trunk
- bad putter/studder
- car wont start
- transmission sensor diagram
- Parklights not working?
- issues
- Gas lid help
- 03 Lancer run rough after new plugs
- A/C problem, sometimes it works, other times not so much
- weird issue on a/c
- Engine Light Off and On
- Kind of unimportant question/issue about instrument gauge but..
- Acceleration Issues
- Pulling "P0090"
- Brakes issue
- engine knocking and ticking
- Check Engine Light and Water
- Problem with cruise control, piggyback
- P0421
- HID kit with relay harness, weird problems
- Lancer doesn't start sometimes
- Lancer sportback stalling problem
- lancer is overheating
- Why? Does it Matter?
- Mitsubishis from Costa Rica!
