PDA
View Full Version : Lancer General
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. 2009 Lancer 2.0 CVT with only 36K miles. Maintenance Suggestions?
  2. 2016 Lancer EX 1.6L definition file xml rom srf bin
  3. Lancer 2003 automatic cvt transmission mn132933 pinout need
  4. Help please
  5. Stock Lancer 2.4L ROM files
  6. Steering feels loose and wheel does not always reset after tie rod replacement
  7. Anyone bought a complete carb from Alibaba?
  8. 1998 lancer with a 4G13 - How to fit an actuator for AC idle control?
  9. Question about wiring to my fusebox
  10. 2014 lancer does not turn right side
  11. 4G13 1998 1.3 GL 12valve - whining noise when hot
  12. Interior wrap cut file template fort Lancer X models
  13. Keyless entry not working - 2002 Lancer CE
  14. Help with EcuFlash Definition
  15. Shared engines
  16. Help
  17. Lancer 2006 4G15 Engine Hesitation
  18. Oz Rally Evo 9 Kit
  19. 2012 mitsuibishi lancer es itb
  20. Lancer 2015 SE AWC - Faint hissing sound under the hood
  21. 2.4 lt engine stopped
  22. recover thread?
  23. 2008 Lancer gts
  24. Exhaust question?
  25. 4g15 dohc wit evo transmission?
  26. 2015 Lancer SE Aftermarket Sway Bar
  27. Need 2015 Lancer ES definition file
  28. Help with lancer definitions
  29. 2015 lancer es alternator replacement
  30. Conversion
  31. For steering wheel
  32. Lancer 1300 GL 1998 Overheated Blown Head Gasket
  33. Looking for jdm catalogue setup for this specific lancer model
  34. 03 lancer rough idling some times...
  35. Tire/suspension stuff
  36. Lancer ES noise problem
  37. No spark on 2002 Mitsubishi Lancer oz rally
  38. Vinyl Wrapping
  39. Just how bad are the CVTs? Dump it?
  40. Does the Evo X Flywheel fit a NA Lancer 2010 DE?
  41. Help
  42. 2013 Lancer panel removal
  43. Help!!
  44. Looking to buy a 2004 Mitsubishi lancer O-Z Rally Edition with 146,000 miles
  45. 2016 Lancer ES 2.0 CVT mod suggestions
  46. Muffler delete affects on ecu
  47. thoughts on 1990 lancer sportback GTI
  48. 2002 lancer
  49. Advise in regards to the purchase of a 2000 auto Mitsubishi Lancer coupe
  50. Cp9a head lights on a cj4a coupe.
  51. CEL codes and performance issues after VLAND install
  52. Ralliart internals in base lancer ?
  53. 2017 Mitsubishi Lancer LE Camber Bolts?
  54. ducktail style lip for my 2002 ce lancer
  55. 2015 Mitsubishi Lancer se AWC 2.4l to swap 4b11t
  56. Aftermarket Shift Knobs
  57. 2012 Lancer SE exhaust
  58. Fuel Pressure
  59. Trying to find the body/chassis code for my SE AWC
  60. Fuel problem please help
  61. Turbo Lancer
  62. I need help with my '09 Lancer GTS
  63. 2014 to 2015 lancer parts
  64. Gauge Cluster lights out
  65. Any compatible ROM for this ECU Lancer 2002 CG 4G94 MT
  66. Any clubs, groups or regional meets for Berks / Bucks area?
  67. Keyless entry
  68. 2016 lancer 5 speed engine swap
  69. Please help me identify this door clip!
  70. Need help with a Lancer conversion
  71. Where is 2014 mitsubishi lancer power window relay?
  72. 2009 Lancer GTS Battery Problems
  73. parasitic draw pointing to "control unit relay" fuse, now what?
  74. Stock rom for Lancer EX 2.0(GCC) 2012.
  75. Polyurethane rear lower control arm bushings anyone?
  76. Help with cvt oil cooler
  77. Door trim fabric
  78. Need help to find Lancer front bumper
  79. Not to sure what to do next?
  80. Vibrations problems need help
  81. 2011 Mitsubishi Lancer Repair Manual Guide
  82. Lancer Evolution VII License plate logo suggestion
  83. Weird Ignition
  84. Lancer CS1: Performance Increase - Engine Swap from 1.3L to 2.0L or any other option?
  85. 2015 SE AWC CY4A break system swap
  86. Ignition Coils
  87. 4G94 Piston Options
  88. 4B12 Throttle body
  89. Stock for lancer es 2002 4g94 AT mh8305f
  90. old CVT Fluid - change?
  91. Aftermarket Steering Wheel Change
  92. Head swap 4g92
  93. Brembo Xtra rotors vs Otto Zimmermann Sport Coat Z
  94. MMCS Touch screen not working
  95. How to get the most out of my 100K mile warranty?
  96. Flywheel weight
  97. Difference in Audio wire..
  98. Turboing a 4g92
  99. Help car wont rev up
  100. GPS map Updates
  101. 2004 mitsubishi lancer missing bolt
  102. 2015 Lancer SE, Again.... Strange Voltages
  103. 2015 Lancer SE AFR Issues
  104. How much should I be asking for a 2003 Lancer ES stock 107k miles?
  105. 10k for a 2010 Sportback Ralliart?
  106. Lancer SE Suspension Swap
  107. lancer 2016 2.0 power cut / transmission slip
  108. Restored '09 Mitsubishi Lancer GTS
  109. Pulley bolt on crankshaft came loose
  110. ECU Tuning
  111. I need to install ASAP NEED HELP
  112. ShoRt intake for 2.4L mivec 4g69 auto
  113. Clutch replacement HELP!
  114. Floor Shifter Sport Mode
  115. Lancer hesitates
  116. Clear frame deal in climate control for the bulbs?
  117. WTF is THIS???
  118. Spark plugs stuck
  119. Deciding between 2014 Lancer GT and 2011 Ralliart
  120. 1997 lancer aftermarket ecu for turbo
  121. Fixing up Bumper and fender/Door damages
  122. Help Me
  123. 2017 Lancer GSR Hatchback modding
  124. Headlight On then radio sound is turning off - Lancer EX 2017
  125. Lancer SE Awc
  126. RKE extension?
  127. Evo X - Lancer GTS - Valve Cover
  128. Evo X Style Rear Bumper Cover
  129. Lancer loss of power
  130. 2006 Lancer estate 4g63T conversion
  131. Evo X muffler Fit on Lancer 2017 SEL AWD
  132. 2005 mitishibishi lancer
  133. Dash and ecu
  134. Can anyone find this
  135. Cooling fan connections
  136. Alternator Not Working: Repair or Replace?
  137. Need Help Buying Used Lancers
  138. First motor build. 2.0 suggestions
  139. Front ac hose alternate
  140. 04 Lancer Ralliart Turbo Questions
  141. Stuck horn on a mitsubishi lancer oz rally edition 2004
  142. Starting to have issues...
  143. Engine swap
  144. 1998 Lancer GLX stock- needs a refresh
  145. 2016 Lancer
  146. New boi
  147. Where to buy Engine Mounts?
  148. Led
  149. Tires
  150. Access Rear Dampening Adjustment
  151. I need Help with my Lancer
  152. Stock Evo X Muffler
  153. I need help building my Lancer, advise would help please!
  154. Tick after oil change. 2015 Lancer ES
  155. ramdom misfire
  156. Time has come and car is done dead jim
  157. Lancer radio wiring
  158. '17 Lancer ES Questions/First Mods?
  159. making my obd2 port compatible with a basic scan tool on a 97 mitsubishi lacner
  160. Future Evo Owner looking for Advice
  161. Lancer 1.3 GLX 1998 Speedometer not working
  162. Newbie seeking aftermarket steering wheel hub info!
  163. recent issues
  164. replacing possitive battery cable..
  165. Evo engine in base lancer
  166. Lancer strut alignment
  167. 09 lancer gts problem
  168. Considering a 2015 Lancer GT (Manual) ...Pls Advise.
  169. Mitsubishi 4g93 engine issue
  170. Hi there!
  171. lower profile tires?
  172. 2002 Lancer fuel gauge issues
  173. Mitsubishi Lancer subwoofer enclosure
  174. MOD 2018 East Coast
  175. 08 lancer engine noise urgent
  176. 2002 lancer oz rally art check engine light
  177. 2015 Lancer GT 3" Headers, Cat Converter, and Exhaust recommendations
  178. 2008 gts lancer wont start
  179. Will evo x clutch fit base lancer
  180. 2013 lancer es cv axle replacement
  181. Help needed to swap my F5M42 Gearbox
  182. lancer wagon swap
  183. How many of us still have a stock lancer?
  184. Purchasing "Fangs"
  185. Door Handle Button Inquiry
  186. Lug Nuts Question
  187. definition file to tune ecu
  188. Suggest Decals??
  189. What is this chrome piece?
  190. Just Bought My Lancer ES Sport FAST Key Issue
  191. Service indicator - correct reset? 2012 SE
  192. Evo MR and Lancer GT
  193. Do 2010 doors fit the 2009 lancer?
  194. no spark
  195. Es front struts to oz front
  196. lancer seat swaps
  197. Phone for GPS - Mounting Options?
  198. Flutter Sound at 3k (possible dumb question)
  199. Just wanted to say hello.
  200. Can't figure out what is wrong with 2005 Lancer... HELP!!!
  201. Fuel Pump Location
  202. recommendation on top of the line car battery?
  203. 2008 Mitsubishi Lancer parasitic battery drain
  204. lancer repair manual
  205. 03 oz rally cat question
  206. 1.8 Lancer Transmission Swap
  207. Mitsubishi lancer 1.8 cvt 2015
  208. 03 lancer oz rally help
  209. Anybody interested in these parts?
  210. Mitsubishi Outlander (Sport?) 2.0 Turbo 4WD
  211. What is my minimum and maximum offset for 17x7.5 wheels?
  212. CK4A Suspension advice?
  213. Where's everyone at??
  214. 1998 mitsubishi lancer speedo,revcounter,fuel&temp guage not working
  215. I'm adding all performance parts to the Lancer
  216. 03 outlander throttle body on 01 mirage
  217. Trying to get new and wider tires
  218. Hood
  219. Hid
  220. Can a Mitsubishi dealer restore to factory default an ETACS after a bad flash?
  221. need help rebuilding the front of my 2017 lancer
  222. Cracks in gas cap causing fumes?
  223. Why do people keep having to hit my car....Again
  224. led headlight bulbs
  225. nav head unit
  226. Hey everyone im new on this forum and to moding cars
  227. Random Wiring/Plugs Lancer 2009
  228. Has anyoneused "Full" Brand filter on their Lancer? Are they good?
  229. 02 CG vrx suspension replacement
  230. August 2017 Featured Car of the Month
  231. New toys (10.2" Android Indash & Paddle Shifters.
  232. RR wheel locked, need self adjuster for drum brake
  233. Trouble fitting 4g64 in 06 Lancer
  234. Lowering my Lancer
  235. Rear spoiler: 2006 Ralliart on 2011 Lancer SE?
  236. CVT Fluid Question
  237. compatible parts
  238. angel eyes
  239. Installing OEM Rockford Fostgate system into a lancer that didnt came with it
  240. New member with a new Lancer
  241. 3" test pipe
  242. Dash board
  243. Turbo Kit-2014 Lancer GT 2.4L
  244. Buying a Lancer
  245. 09 Vibration in steering
  246. Jerking when shifting gears. PLZ HELP
  247. Ce lancer
  248. Help. Best colour and style on my white lancer 2013?
  249. Hello
  250. 3900$ 27,000 miles, worth it? Only rear damage
