- Parts help
- stronger belt for the 4G69
- 4g69 Headbolt torque specs?
- 4g69 auto turbo reflash?
- CV Joints
- CV Joints
- Rear axle vibration Ralliart Lancer
- Hello I was just curious if anyone could look at this transmission
- 2004 Ralli Hesitating when Upshifting
- 2004 ralliart ac bypass belt
- 4G69 head swap
- 04 lancer clutch problem
- Ralliart turbo stuff
- HELP hit a dead end
- Ralliart 06 transmission swap
- Grinding noise
- Load limit
- Throttle cable
- 2.4 ralliart walbro 255 pump upgrade
- moteur compatible Ralliart 2005
- F5M42 Transaxle Questions
- Ralliart overheating after launching in 1st
- Clutch problem. Air getting in system
- Newbie, having some issues
- Clutch release fork
- Battery draining , alternator is good idk what to do
- 2004 Ralliart - Crank, NO START!?
- Bell housing/Manuel transmission
- Can't find OEM style muffler anywhere. Wary of the ultimate-racing axle back.
- 90 octane no ethanol on tune
- Transmission bellhousing question
- Transmission Fit Guide
- 2010ralliart sst gearbox fault.
- I Need help turboing my Lancer!
- Replacing valves without machine shop?
- 04 Ralliart Manual Swap
- Differential Side shaft shims
- manual trans rebuild
- sloppy 5 speed 2006 ralliart shifter
- Sub-Frame Question
- Are 4g69's created equal
- electric problem
- Need some torque specs
- TPS sensor help!!!!! Throwing a code P0123
- 3 cylinders
- Intake Manifold Porting
- Stuck Shifter
- Car not cranking
- Oil Pan Fitment
- Clutch: Valve between master and slave???
- Help?!? - 04 RA clutch issues & questions (pics)
- 05 Lancer Ralliart Trans Swap
- What did I buy?
- 2006 Ralliart engine is silent
- 2006 mitsubishi lancer Ralliart 2.4L
- Reflash or piggyback ?
- Temperature Gauge
- 2009 lancer rallart
- 2004 Ralliart will not start, cranks hard, no spark on plugs
- Engine stall issue
- Injectors
- Delayed Start
- Getting Harmonic Balancer off 04 Ralliart
- Timing belt question.
- Radiator fans almost always on?
- Stayer. Pistons.
- Timing belt wear?
- Stayer. Header
- HELP! need shop service manual
- Cylinder wall scoring
- H beam and pistons
- Blown motor. Replacing with 4g69 from AWD Outlander. Issues with this?
- P0340 code (long list of troubleshooting details)
- Idler pulley question?
- High oil pressure reading
- Power cut off around 5k rpm when Mivec engaged
- 2004 Ralliart Tear Down
- Engine Reconditioning
- 4g93 GDI-Turbo issues?
- 4G69 Oil Squirters
- 4g69 compatibility to other 4g6*
- drive belt issues
- Clutch disengagement / Shifting Problem
- Weird noise after engine rebuild
- Ultimate Racing Exhaust
- 04 ralliart attempting to turn over but is a no go
- 2006 ralliart engine number
- Timing Belt Broken
- Clutch 04 ralliart
- Strange noise ACD pump
- M/T Removal Question
- MIL wont go out, always same code
- Stayer. Porting the cylinder head. Stage 4.
- :helpme: Injen CAI, sudden bucking and stalling
- E-manage Ultimate on windows 8
- Stayer. Camshaft kit 4G69.
- Stayer. Lightweight crankshaft pulley 4G69.
- Strange Overheating Issue (hear me out, please)
- Header and downpipes
- Cranking but wont start, and no Spark please help
- Oil in spark plug wells.
- IAT location and issue.
- motor swap
- Oil pressure sensor location???
- TDC/Valve Lash Oddity (cyl 4 never gets to tdc?)
- Hard to shift gears and a a squealing notice when I hit clutch
- 02 lancer ralliart/evo 8 motor nd transmission
- Throttle body and intake spacers.
- Engine build before tuning is needed
- OBX fuel rail opinion
- Colder plugs for nitrous
- 2006 Ralliart Engine Light - Transmission problem
- 04 ralliart cutting in and out in the 4000 rpm range
- Car feels fast when cold outside and so slow when hot outside
- Humming noise coming from left front area
- finding a Exhaust
- OZ lancer Exhaust and 2 Step??
- 04 RA transmission / clutch problem
- Weird starting issue
- Transmission codes P184B, P183B
- New motor mounts and engine moves like crazy
- What to get first piggy back or Timing box
- 2005 Ralliart timing belt issue
- oem 04+ exhaust needed
- Transmission compatible with the ralliart
- motor mounts, auto trans
- Car Jerks taking off in 1st Gear
- Brand new clutch but won't engage until the top almost
- engine swap
- Exhaust
- How safe is it to run 100 wet shot of nitrous
- Transmission Leak
- Looking for a Fidanza flywheel got cash
- 04 Lancer Ralliart trans swap
- New oil pan, problems
- Manipulating Mivec
- Is there any Guide to replacing the clutch
- Weird jerk when taking off in 1st gear
- Shifter hard to move
- Cat Back set up
- Ralliart 2006, No crank intermittent
- fan module, again
- 4g69 thoughts?
- Why is my car burn oil when I run nitrous
- Engine is eating oil when running 75 nitrous shot
- Safe overbore for a 4g69
- Does anyone have a Tune File ?
- What's the best clutch kit for our cars
- Weird sound?
- need help,,, need to pass emission asap!
- Change timing belt early?
- Limited Slip Diff Report
- There's no solution to exhaust rasp after obx headers!
- Balance Shaft Sprocket Note
- high compression build
- correct belt for Ralco RZ Performance Underdrive Pulley Kit
- 05 lancer ralliart transmission problems
- Ecu tune
- Hi flow cats for our cars
- Exhaust rasp
- Starting Problem
- TPS Problemo
- Need links to short shifters!
- Rusty down pipe bolts
- Will Evo 8 catback fit
- Aluminum Flywheel Install
- 05 Ralliart doesn't chirp in second anymore
- Aftermarket Throttle Body or Spacer
- Right Side Engine Mount Studs Sheared Off
- Oil pan help no clear answer !
- Pistons and rods ! Help!!!
- Misfire on 2: Code P0302. NEED HELP Narrowing Down Solutions!
- 2004 Ralliart Ignition Coils!
- Where is this oil leak coming from
- Information before I boost my RA
- Lend some clutch help? :D
- MAF parameters
- Need high performance clutch master cylinder
- 4G69 Tear Down Detail
- evo 2006 engine questions
- Possible O2 sensor issue
- car reving to 1500rpm in neutral
- After Head Gasket replacement, rough cold idle and no top end power
- 5 Speed to 6 Speed Change
- Throttle position sensor code
- Help - New to Lancers. What do you see?
- Rattling sound when in Neutral
- Cold start troubles
- swap 6g75
- need a clutch!!! need help
- help diagnosing problem please!
- flywheel PROBLEMS
- Piggyback ECU
- engine replacement
- Ralliart 6 Speed Tranny
- Head Swap to IX
- Need help, Car Barely Runs
- Check engine light help
- starting problem
- exhaust system
- Looking for a mechanic familiar with Lancer Sportback NJ.
- Check engine light codes
- evo 5spd transmission + 4G69, axleshaft fitment?
- Oil on Spark Plugs?
- Piston rod combo
- aem ems 4 standalone
- 06 ralliart timing timing/valve problem
- Help!!!! Have to smog car
- Tactrix 2.0 Cable
- throttle body spacer for the 4g69
- AC Condenser Fan Not Working
- raspy exhaust sound
- engine noise research... correct me if im wrong
- rotating flywheel clockwise
- F4A4B Transmission Overhaul
- AEM FIC RRM Piggyback
- Obx headers?
- 255 fuel pump
- Starter installation help.
- building a 4G69
- Obd code P0172 help
- Cam Upgrade
- Fastwork Problem
- Clutch install pics, correct?
- HFC and downpipe installed
- drenth gearbox development
- Transmission
- No start issue
- Check Engine light
- 2005 RA Shifting hard into 3rd (AUTO)
- Wtb : rrm headers+downpipe combo
- all motor build!
- Polishing headers?
- will a front suspension crossmember from an EVO 8/9 fit our cars?
- RPM drops and car dies??
- 2004 ralliart can't change gears
- Tranny problem -> tranny conversion?
- Oil Pan Removal
- Timing belt broke (need some advice)
- Windage tray
- tranny issues?
- EVO 9 clutch fit our 4G69 transmission?
- 09 lancer ralliart check engine light concern
- Gallant vs Ralliart Manifold Shield
- New Reflash on the way!
- RRM Underdrive Pulley
- engine click sound like a/c turning on...fan on engine shut off
- 05 Lancer Ralliart Purge Valve
- stage 3 cam specs?
