- AEM 100% sync no start
- Aem 24-1 cas no spark (aem series 1)
- AEM EMS V1 Evo 9 Can’t Start
- EGT sensors with the aem ems series 1
- AEM infinity PC logging
- Infinity - BISS screw
- AEM Infinity and kiggly 12 tooth settings.
- Aem ems series 1
- Infinity and oem fuel pump resistor
- Infinity pnp harness help!
- Fuel pressure sensor issues
- AEM Infinity won't make adjustments
- Setting up rolling anti lag/launch
- AEM Infinity Logs
- AEM infinity with kiggly 12T crank trigger.
- Ems series 2 flex sensor
- AEM EMS v1 problem
- Wideband/oil pressure logging
- AEM Infinity tuning
- AEM Infinity NO SPARK ISSUE
- Max IACV steps?
- A/F Ratio bouncing Rich to lean on decel
- AEM Oil Pressure sensor gone bad?
- Evo 8 AEM EMS V1 FIC2150cc map
- Aem Infinity English Racing 12t trigger wheel setup
- Swap between AEM Infinity and Stock ECU
- Kiggly 12-Tooth Trigger & AEM Infinity
- No Spark On JDC Coils
- AEM infinity + Plug and play harness question
- AEM Infinity - Cant Load base cal
- Another AEM v2 with 12 tooth issue thread
- AEM EMS timing tuning Help - Turbo Lag and Knock
- Aem series 1 throttle tip in
- look for a base map for my evo 8
- AEM ems-4 connection issues 6905-2092
- Have aem series 1 need to run pump and e85
- Boost solenoid verification that it is working in AEM Infinity
- Aem ems need idle help
- Fly by wire
- Car eating O2 sensors! Help!!
- Where to buy or get AEM V1 tuning software for Evo 9?
- AEM Series 2 Evo 9 Mivec not responding
- AEM V1 hooking up AutoMeter tach?
- How to brute force fat fingered password.
- AEM V1.0 Cold Start Issues HELP!
- Civic AEM v2 into Evo
- AEM EMS Evo III Timing Errors and RPM Issue.
- AEM EMS V2 - what table to adjust for driveability during warm up
- AEMPRO 1.0 Manual
- Need help
- AEM Infinity Flex fuel tuning with Full Race EFR turbo kit
- V1 Stat sync no start, get a fireball though
- AeM Infinity PnP Harness and Fuel Pump
- AEM CDIs > carboard/paper inside unit, aftermath dead unit
- AEM AFR Gauge on EMS v1
- AEM V2 30-6310 and Water/Meth Failsafe
- VDM and AEMNet Gauge -- Just got them :)
- Infinity with stock trigger disk question
- Infinity 6 ems individual cylinder knock control
- Question for anybody who has aem ems!!!!
- Infinity-6 and Evo 8 stock baro sensor
- The Ems Ver2 reads 261F & it isnt hot
- Want to kill Rad fan when the engine has stopped or hasnt start to run.
- Aem ems 1 evo rpm cut off at 4900!
- aem V2 e85 sensor intallation
- AEM v1 for 2g work on evo?
- Infinty 8h=no A/C*Help PLZ*
- AEM v2 removal?
- AEM Infinity Installation
- Stock igntion to cdi ignition help.
- Base map help
- About tuning AEM V2
- AEM Infinity Ignition sync & Tuning explained
- aem infinity pinout help.
- sorry made duplicate post. please delete.
- Antilag VS NLTS
- Random AFR changes, leaner WOT causing breakup
- Lock aem v1 help !!!
- HELP! Evo 9 AEM V2 idle surging issue
- evo 8 jdm mr
- I"m an evo guy, but have an AEM v2 question for my supra
- Need Help! Went from sea level to 6k feet and engine is suffocating.
- Need Help! Evo 9 Wiring 150psi sensor for AEM FP Fail Safe
- Evo 8 will not start
- Chaging injector - pte1000 to fic 2150
- sensor volt going down after a short drive.
- Schematic? pin out diagrams?
- AEM EMS V1 double pumper config
- Evo 8 aem ems start up issues when warmed up
- Lots of cranking before starting V1, Speed Density
- Help on AEM EMS series 1 30-1313 install on evolution 5
- AEM pass inspection?
- Need Evo 8 AEM V1 Manual
- 12 tooth trigger plate without instructions
- fuel tables
- aem ems v1 issue please help
- AEM series 2 crank trigger issue. HELP.
- AEM S2 ECA Hook up
- Aem Infinity mounting without using glovebox
- High RPM timing error cam/crank sync issue
- setting up NLTS
- AEM V1 Injector size
- aem infinity tune
- Sequential ignition/injector phasing
- Ignition map opinions
- Rule out AEM being my problem
- Aem Ecu
- AEM EMS V1 Ecu Wizard Error
- AEM V1 + Speed Density stalling on start-up
- Fuel pump keeps running when engine is off
- Help i upgrade my engine
- Help with cold start issue AEMv1
- AEM vs. Hallman vs. MoTec
- AEM V1 E85 base tune help needed
- AEM V.1 tuned with V.2 software
- EMS 2 and map sensor compatility
- AEM issues? Tuner Issues?
- Hard start when cold Evo 8 EMS v1
- Little help AEM v1 from 1200cc to 2000cc inj.
- AEM Infinity Question
- WTB used AEM series 2
- AEM Series 2 and Windows 8/8.1 Connection issues
- Reliable Evo 8 Tuner in tampa fl
- AEM EMS 30-1313 on Evo 7
- AEM EMS V2 on EVO 6 TME
- Car pops while being shut off
- Greddy ProFec B-Spec II locked from AEM
- aem series 2 and aem meth kit 30-3000
- aem rpm issue
- Injector clinin 1450
- Aem trigger disk
- Issue with an AEM EMS V1
- 2003 Evo 8 Hard starting
- Boost Solenoid not working?
- Wich c.o.p to use
- Map sensor question / issue
- Problem with tune or something
- AEM EMS injector no pulse
- Basemap needed
- Setting up Wideband in AEM Series 2
- EVO 8 AEM EMS V2 Base map needed!
- evo 8 mr jdm
- Evo 7 aem ecu
- evo 8 mr 3 pin
- Can I log AEM EMS V2 car that has a locked ECU?
- EMS-4 Universal Standalone Engine Management System
- Rough idle after 2 step
- How to disable Mivec on Evo Ix Aem V1 ems
- Series 2 with 12 tooth trigger disc
- Bad reading aem tru boost with external 30-4351 sensor
- Aem Ems/stock ecu idle problems
- Help on Aem v1 AC issues!!!
- AEM EMS Series 2 Setup Issues.. HELP!
- Aem 2 help
- Setting Bast Timing With Fluidampr
- Aem ems v1 dual map setting question
- Evo ix AEM help
- Evo 8 Revving/idle problem
- Need Help with correct AP Map
- MIVEC and Aem
- aem help
- AEM Launch control version 1 ems????
- stock evo on ems
- AEM EMS Series 2 NEW VERSION - Flex Fuel support
- aem gauges
- AEM EMS v1 log
- AEM ver 1 battery offset
- Series 1 base map for FIC 2150's
- need evo 8 base map
- Need a base map Please.
- Help.... Car only idles
- Need base cal file!!! E85
- EMS V2 Hard start.
- Aem 1320 toggle switches..
- Pin 58 -- If you trim the harness do not remove this one.
- Help AEM EMS no start
- AEM EMS 2 on my Lan Evo 6
- bosch 1680cc batt offset for aem
- Aem v1 evo9
- AEM 1313 trouble
- Remote Tuning
- O2 sensors with AEM and AEM serial gauge
- AEM EMS and IAC
- AEM Series 2 with 12 tooth trigger disc
- IAC Problem
- Afert Market Know sensor Fo AEM EMS
- injector scaling: latency values for fic 1150
- My car cant start with 12 teeth trigger disc ?
- What AEM ems do I buy?
- Random no start
- AEM EMS with Zeitronix ZT-2
- AEM EMS Series 1 to Series 2
- Help: Pulling log AEM EMS v1 ?
- Aem ems 2
- Shipping my car, possible de-tune?
- 02 sensor doesnt log internal 1313u
- AEM Wideband plugged into ECU
- evo 9 ems???
- Wiring harness help for AEM EMS
- How to read knock on aem
- A/C Fan Stays on with key and No start
- Spoolin up speed density harness ?
- AEM EMS V1 Problems I think
- Can't connect aem to my laptop
- BR double pumper to relay to aem question.
- Evo ems
- ame series 1 question
- Difficulty starting when engine is warm
- how to log
- Series 1 software ?
- evo rs aem mass airflow or map(speed density)?
- Buschur Racing 12-Tooth Crank Disc
- Fresh Rebuild..new injectors...misses...HELP!!
- Best aem tuners in the tristate area??
- evo 8 wont idle ems series 2
- GROUP BUY: AEM Series 2 PnP EMS
- My aem wont connect
- AEM EMS question?
- passing emissions in NY with aem ems
- In Search Of A Tuner
- So freaking HAPPY, my throttle hang FIXED!!!
- ECU Offline, cannt connect
- Map Switch on the AEM
- Cranking issues...
- Rad fan and EMS series 2 help
- aem flex fuel option
- AFR warning/alarm indicator
- factory wired fuel pump speed control question
- AEM EMS and ACD Pump???
- Help logging zeitronix o2 in aem ems
- AEM Direct Closeout Sales - $599 1320 / 1313
- Knock Sensor Calibrations - What voltages for built engines
- EMS good enough for 100% daily driver? Has anyone tuned with an iPad?
- 2 step
- Tuning Mivec (Valve#2) in AEMPro
- Confused about AEM ems v2. Need help.
- Mitsubishi Evo x MAP Scalar
- How sensitive is AEM EMS to mods?
- revving pass rev limit
- AEM 30-6310 2003 EVO Wont Start
- ID1000 Idle Setup
- Question about OBDII Port
- map not saving?
- AEM keeps eating my cam sensor
- aem ems series 1
- Another bad start, help here plase Evo VI TME
- TPS/ Cam Sensor unStable
