Can you E-brake turn?
Old Nov 16, 2010, 06:41 PM
GGP Wolf's Avatar
So this car has no clutch you can manually operate right?
I was wondering if you can do e-brake turn in the car Gymkhana style without braking the car.
Does it disconnect the clutch and tires when you yank on the E-brake and then engage the clutch automatically when you let the E-brake off?
Or will I burn out my clutch like a normal 4WD stick car would if I yanked on the E-brake without putting the clutch in?
The new WRC cars are sequential shifter with no real clutch to operate manually at race speedst, so what happens when they pull on the E-brake?
Old Nov 16, 2010, 06:50 PM
-Evo Aaron-'s Avatar
that is an interesting question. im curious to know the answer to this as well.
Old Nov 16, 2010, 06:53 PM
HR2L's Avatar
Try it and get back to us on your findings!
Old Nov 16, 2010, 06:54 PM
GGP Wolf's Avatar
I dont have one...yet
Old Nov 16, 2010, 06:59 PM
Robevo RS's Avatar
Will disconnect the ACD. You will find a wire connection on the e-brake which is signals to the computer to disenge the ACD so the rear will independent from the front wheels. Also turns your E brake light on on the dash . LOL
The ebrake is for rotate the car not to brake , so you still do braking before you apply the e-brake for sharp turn in racing.
Old Nov 16, 2010, 07:12 PM
GGP Wolf's Avatar
Yes I understand that the E-brake is for rotation and I will need to use normal brake to control the speed before rotation. My question was does it disconnect the clutch or are you saying discconectin the ACD is the same thing as disconnecting the clutch?(I just want to be sure) So if that is the case technically I will not break anything even if I E-brake turn on high gripping asphalt in the dry? Thank you for the reply.
Old Nov 17, 2010, 07:45 AM
gaabbee's Avatar
the acd will open up and "disconnect" the rear axle as in it wont be sending power there. so then the difference in speeds wont stall the car
Old Nov 17, 2010, 12:05 PM
GGP Wolf's Avatar
That is a really cool feature.
Is that the norm for AWD cars or is that something special for Evo's?
Also same thing for WRC?
Old Nov 17, 2010, 01:50 PM
Robevo RS's Avatar
yep WRC car also disconnect the mid dif.
ACD is an electronically controllod diff so it is unlocked by ACD ECU. Also many other ECU for a mid dif like motec, ralliart etc. and they all has this feture,
basically preventing damage on the drive train. Besides many other option you can do with them.
Old Nov 19, 2010, 07:11 PM
SME
SME's Avatar
My rear end rotates pretty easily with the sportback.
Old Nov 23, 2010, 09:54 PM
Toxin's Avatar
WRC does not allow active center differentials so I'm not completely sure how any of this can be true... PWRC, JWRC and so on - yes, the actual WRC (FIA Gr.A WRC) however - no.
Old Nov 24, 2010, 06:08 PM
EricJ@AMS's Avatar
My car e-brake slides like mad. It definitely disconnects the acd and allows the rears to lock up.
Old Nov 29, 2010, 01:13 AM
MR. EVO MR's Avatar
Didn't Jeremy Clarkson race a sti on a track and when he ebraked the clutch disengaged?
Made him loose seconds.
Old Dec 2, 2010, 08:28 AM
Midnighyt's Avatar
you're thinking of this
http://www.youtube.com/watch?v=BZPB4aSyq40
Old Dec 6, 2010, 03:47 PM
Crester's Avatar
So today we got our first real snow fall and I was able to pull the ebrake and slide the rear around. So I guess that answers the question. lol
Quick Reply: Can you E-brake turn?
