S-Sport In Manual Mode
Until the transmission temperature exceeds 60C, it should be operated in normal or S mode. SSport and the other modes have totally different programming regarding closed loop operation that will effect warm up time on the transmission. Operating the transmission outside of its correct temperature range is detrimental to clutch life.
How long would it take for the transmission to get up to temperature. And would warming up the car when you start it in the mornings warm up the transmission as well. I just want to know because i have been driving the car in S Sport mode for the past three weeks and I haven't had any signs of slippage. Mind you I always warm up the car in the mornings for at least 10 minutes before I start driving.
So how much time would you guys recommend that is needed before the car can be safely placed in S Sport mode.
I agree with this. I have noticed that even if I start my car in the morning and let it run at least 5 minutes before I leave for work that it seems to run/shift smoother. Besides, I was always under the belief that you should never drive a t/c car too 'spirited' until it's warmed up. Just better for your engine/tranny in the long run.
Sorry to bump an old thread...but I figured I'd use search and chime in...I've had my '14 MR for a bit now, and am still getting used to the SST. Depending on my mood, I've kept it in normal mostly...I've read a lot of posts about the transmission so far, and the general consensus has been to drive mostly 'sport/manual' mode - whether it was for overall feel of shifting was preferred, or to prevent premature wear...sport was it. Is there any difference between the years of the SST? I know the later the model, the more improvements are done to get the kinks out from prior years. If I am mistaken in any of these statements at all, I am welcome to any criticism and educational activities...
nickyd (Jun 6, 2017)
crak
906
Aug 14, 2022 02:41 PM
TheHolyLancer
Mitsubishi TC-SST Discussion
17
Mar 17, 2016 02:41 PM
