Ralliart & Evo X MR TC-SST Beta Testing. Flash with Tactrix
Beta Testing is ready
SST Flash_Reflash Guide
SST Support Files
This thread will serve as a Q&A / Tips and Tricks to get this bad boy up and running.
SST Support Files
I tend to use the B001 for 2009/2010 , and the B151 for newer cars. For scientific reason other than they are the corresponding files for the Evo SSTs of those years
Well we did it....... Added LC to one car and removed it from mine......WORKED FLAWLESSLY!!!!
This is so easy. yes nerve racking cause it's a scary thing to do :P But it works great!!!
Thanks to everyone involved in cracking the TCU!!
kudos to you guys
How does this work with the Ralliart in 5th and 6th gears? Since they're a different ratio than in the Evo. I read the were issues with the previous flash for the Ralliarts with rev hunting and so on.
Mission accomplished as I now have Super Sport and Launch Control.
I would just like to say thank you to everyone who helped make this happen and put together a how to that was easy to follow.
Awesome work gentlemen!
SST Support Files
SST Support Files
I wanted to use the teach in function on my 2008 as it had done 175k . It made a huge difference in shift quality . I recommend any one with high km /miles to do it.
P.S I flashed to 2011 rom no issues
And for the guys who've done this (I flashed it a week ago) are you noticing any weird shifting or anything. I haven't but I don't drive my car much since I'm only home weekends.
Last question. The teach in procedure. What's this for (besides if you replace the trans ect) someone had posted somewhere that they recommend it for higher mileage cars. Mine is, 78,xxx miles. Which teach in items did you select? Or did you do all of them? Thanks I'll go back to my corner now.
I hate to quote myself but this hasn't been answered. I'm getting (as well as another member I talk to) a bit of rev hunting in 6th gear at around 45mph in all modes, auto/manual normal, sport, s-sport. Is this the clutches slipping? Will this wear them faster? I need answers. If so I can unflash then just reflash at the track.
I did them all. Just went through the manual that is in the download. Mine is an 2008 evo so can not help with the ralliart questions. Good luck
I figured out the programming changes that I needed to make and have removed Super Sport / Launch control from my car. Installed the 2011 Ralliart TCU programming and did a complete SST Diaqueen fluid and Factory paper filter change for the 4th time.
