MitsubishiParts.NET | Timing Belt & Engine Kits
MitsubishiParts.NET
360.352.8558
As you know MitsubishiParts.NET is always trying to bring you a smoking deal on OEM Parts & Accessories. This is one of the times during the year when engine components are flying off the shelves left and right. So I have decided to knock the prices down to save you guys and gals some money. Please give us a call if you have some other items you are needing for your build and we will see what we can do. Have a fairly extensive parts list you need a quote on? PM me or call and you will most likely get an even better deal on parts than normal.
What ever the case may be - Im here to help!
MitsubishiParts.NET TIMING KITS
VIII OEM TIMING KIT $439.83 SHIPPED
VIII GATES TIMING KIT $475.70 SHIPPED
IX OEM TIMING KIT $512.42 SHIPPED
IX GATES TIMING KIT $576.48 SHIPPED
CONTAINS:
ENGINE REBUILD KITS
EVO VIII $249.99 SHIPPED
EVO IX $279.99 SHIPPED
CONTAINS:
These are all VIII Part Numbers
MitsubishiParts.NET ENGINE BUILD KIT
VIII ENGINE BUILD KIT $404.71 SHIPPED
IX ENGINE BUILD KIT $432.95 SHIPPED
CONTAINS:
MitsubishiParts.NET MAJOR ENGINE BUILD KIT
VIII ENGINE MAJOR BUILD KIT $824.60 SHIPPED
IX ENGINE MAJOR BUILD KIT $887.19 SHIPPED
CONTAINS:
MitsubishiParts.NET EVOLUTION VIII & IX GOLD SERVICE KIT
VIII - $657.02
IX - $708.89
CONTAINS:
Shipped To 48 States | Call To Order 360.352.8558
The prices listed here are subject to change without notice. Due to the manufacturers ability to change pricing without notice you will need to contact us directly regarding any kits you see here that are not listed on our site.
360.352.8558
CONTAINS:
- Water Pump
- Balance Belt Tensioner
- Balance Belt or GATES Kevlar Belt
- Timing Belt or GATES Kevlar Belt
- Timing Belt Tensioner
- Timing Belt Tensioner Pulley
- Timing Belt Idler Pulley
ENGINE REBUILD KITS
CONTAINS:
- Oil Pick-Up Gasket - MD183240
- Oil Pump Gasket - MD322521
- Oil Filter Gasket - MD322522
- Water Pump Gasket - MN137262
- Oil Return Pipe Gasket - MD194403
- Gasket - MD363254
- Oil Return Pipe Gasket - 1226A002
- Gasket - MD329503
- Air Outlet Fitting Gasket - MR281085
- Oil Seals - MD343563/MD343565/MD359158/MD365697/MD372536
- Exhaust Manifold Gasket - MR323654
- Exhaust Fitting Gasket - MR299686
- T/C Gasket - MR404547
- Intake Gasket - 1540A019
- Head Gasket - mn155760
- O-Ring - MD041021
- Oil Drain Plug Gasket - MD050317
- O-Ring (9) - MD075834
- O-Ring (10) - MF660063 (2)
- Union Nipple Gasket - MF660064 (2)
- Governor Pipe Packing - MF660065 (4)
- Valve Stem Seal Intake - MD306079 (8)
- Valve Stem Seal Exhaust - MD307343 (8)
- Seal Washer - MR497720 (2)
- Valve Cover Gasket - MD340535
CONTAINS:
- Complete Engine Gasket Kit
- Oil Pump Kit
CONTAINS:
- Oil Pump Kit
- MitsubishiParts.NET OEM Timing Kit
VIII - $657.02
IX - $708.89
CONTAINS:
- Water Pump
- Balance Belt
- Timing Belt
- Spark Plugs
- Spark Plug Wires
- Serpentine Belt (w/AC)
- In-Cabin Filter (AC Filter)
- Oil Filter
- Thermostat Kit
2 New Kits ADDED
CONTAINS:
CONTAINS:
CONTAINS:
- Oil Pump Kit
CONTAINS:
- Oil Pump Kit
Is it necessary to change the water pump at 60K?
Could I get a price for the Gates Timing Belt Kit + a serpentine belt as well? Thanks
We finally got some Evolution X Gasket Kits in. These were just released by Mitsubishi and we have had the only 3 in existence on back order for about 2 months now.
If you are planning on rebuilding your 4B11T Id suggest snagging one up because its going to be a while before I can get more.
We are also stocking 4B11T Oil Pumps & Water Pumps. These will fit the Lancer, Ralliart & Evo X.
ORDER HERE
ORDER HERE
