Modern Automotive Performance [Visit Site]
MAP Fall 2014 Clearance Items
Old Oct 22, 2014, 10:12 AM
maperformance's Avatar
Master Fall 2014 Clearance Thread!
We're looking to clear off a little of our old inventory and replace them with some awesome new parts. Below you'll find current clearance items. To find the most up-to-date prices, check out our website! These items are extremely low quantity so they wont last forever! Get them at these amazing prices before they're gone forever.
Browse all clearance items here on our site!
To help improve shifting response in the Mitsubishi EVO VIII and IX 5speed cars, Agency Power has released a set of stiffer shifter bushings to go along with their amazing short shifter.
When creating our new valve line we set out to create the best performance longest lasting valves available to the aftermarket. Using advanced 3D design and simulation programs we have created a stronger and higher flowing valve head design. We flow test prototype valve heads in the specific applications to make sure we have the highest flowing valve head available on the market today.
TX-280, High HP Racing cams, suits built engines with GT37/82 or similar. KCG63 Adjustable Cam Gears available.
  • Valve Spring Kit: KVS63BTK
  • Duration @ 0.1 mm Valve Lift: 280 Inlet/276 Exhaust
  • Duration @ 0.1 mm Valve Lift: 238 Inlet/230 Exhaust
  • Valve Lift @ 1.73 Rocker Ratio: 11.50mm Inlet/11.00mm Exhaust
  • Centerline @ Full Lift: 107 Inlet/115 Exhaust
  • Valve Lift @ TDC: 2.09mm Inlet/1.00mm Exhaust
These pistons are to be used in an Evo 8/9 with 156mm long rods and an 88mm crank!
Great holding power, harsh engagement. Quicker shifting due to reduced weight with a higher torque and heat capacity than organic discs with fade free characteristics.
Send me a PM if any of these items interest you, or you just want to ask a quick question. I'm ready to assist and get you lined up with the best Evo 8/9 Parts on the web!
Attached Thumbnails MAP Fall 2014 Clearance Items-gsc_valves-01-05.jpg   MAP Fall 2014 Clearance Items-untitled-2-04.jpg
maperformance is offline
Old Oct 22, 2014, 10:13 AM
For high performance use for the street, our #91, 92, 93, and 94 pad series are tailored to suit the needs of your specific application. Low noise and dusting
Replace your old worn out rubber radiator hoses with these attractive and durable silicone hoses by Squirrelly! Their silicone hose kits feature 3 layers of polyester reinforcement and feature a temperature rating of 428°F to withstand any heat your engine bay can dish out.
Old Oct 22, 2014, 12:17 PM
Here are a few universal fit clearance items you may be interested in! These would be a great compliment to any Evo 10 build, so take a look and get in on some great deals from MAPerformance!
Tomei Fuel Pressure Regulator Type-S
When the injectors and fuel pump are upgraded the stock fuel pressure regulator may not be enough to suit the required pressures for the new setup. The stock FPR is preset from the factory and is non adjustable so it will limit your options. The TOMEI Fuel Pressure Regulator will ensure stable pressures are supplied with the oversized diaphragm. This special design has proven to maintain the required pressure levels with any adjustments made.
Precision Turbo V-Band Clamp - for V-Band Clamp
Making sure you have the proper clamp mated to your turbo shouldn't be an afterthought. To help facilitate installation and removal, make sure you use genuine Precision Turbo & Engine V-Band or T-Bolt clamps.
Redline Water Wetter Super Coolant Additive (12 oz)
WaterWetter is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30F. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze.
Silicone Coupler Hose by Squirrelly (2.25" Black / Straight)
Squirrelly's line of silicone couplers feature 3 layers of polyester reinforcement and are suitable for applications with boost pressures up to 45psi. They also feature a temperature rating of 428°F for direct to turbocharger installations.
JondemandSales
65
Jan 1, 2007 03:53 PM
Gruppe-S
Gruppe-S Engineering - California
12
Dec 10, 2004 03:24 PM
Gruppe-S
Oct 22, 2004 03:13 PM
Quick Reply: MAP Fall 2014 Clearance Items
