Brake/Suspension/Handling - Moore Automotive Free Shipping!!!!
Brakes l Suspension l Sways l Handling
One MEGA thread for suspension parts. Its not normally what we like to do, but we want to offer the Evo community as many options as we can! Here at Moore Automotive, we really try and tailor a coilover setup that will fit within a customer budget and fulfill their needs.
I wish we were able to advertise all of our prices in one thread, but that just wouldn't be possible. Below is a list of all the coilovers that are available to us, for the EVO X.
Contact me by any of the means listed in my sig if you're interested in any of these products!!!
Buddy Club Coilovers - Racing Spec
Part #: BC02-RSD08CZA4
Notes: Racing Spec Damper Kit
MSRP: $ 1,780.00
Adjustment Bracket
With an adoption of a “adjustable bracket” the ideal low position can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
15 Level Adjustment
The 15 level adjustment corresponds to variety of racing stages, from Touge ‘mountain roads’ to circuits. Adjustment is easy with its click adjusting dial. The dial is located in the on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for street use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm).
Ksport Coilovers - Kontrol Pro Kit
CMT25-KP
Front Spring Rate 9kg/mm
Front Upper Mount Pillowball Upper Mount
Rear Spring Rate 7kg/mm
Rear Upper Mount Aluminum Top Mount
Notes Kontrol Pro Damper System
MSRP: $1,400
KW Variant 3 Coilovers (V1-V3 Available)
35265017
Front Lowering 0.9-2.1in (20-55mm)
Rear Lowering 0.6-1.7in (15-45mm)
Spring Rate (F/R) 455lbs/in / 515lbs/in
Notes Variant 3 Coilovers
Front Height Adjustable Only
MSRP: $2,495
Stance Coilovers (Full lineup available)
ST-CZ4A-GR
Front Spring Rate 10K
Rear Spring Rate 9K
Notes GR+ Coilovers
Front Camber Uppermount
Inverted Front Shocks
MSRP: $1,439
TEIN Dampers (Full lineup available)
Part #: DSE18-2USS4
Notes: Super Street Damper
Includes Pillowball Uppermount
For EDFC use EDK05-12140 (Motor) & EDK06-K4474(Strut Kit)
MSRP: $ 1,500.00
JIC Coilover System (Full lineup available)
CZ4AFLTA2
Front Spring Rate 10kg/mm
Rear Spring Rate 8kg/mm
Notes FLT-TAR Coilovers
Soft Setup
MSRP: $2,508
HKS HIPERMAX III COILOVERS
- Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases
- Strengthened rubber upper mounts – enhanced durability
- Monotube design
- Shock-body length adjustable (most applications)
- 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
- Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability
- 30-way adjustable dampening
- Hard chrome-plated cylinder shaft
- Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions
- Pillowball upper mounts optional on certain applications
- Dustboots standard
Part # 80140-AM003
MSRP:$2,000
WE Also carry a full line of Brake Pads
Hawk
StopTech
BRAKE ROTORS
SWAY BARS
Agency Power
Eibach
Perrin:
Progress:
WhiteLine
JM Auto Racing
Evo 'For Sale' Suspension / Brakes / Handling
851
Nov 28, 2022 11:31 AM
JM Auto Racing
EvoX 'For Sale' Suspension / Brakes / Handling
992
Nov 28, 2022 11:30 AM
ETS Michael
Evo 'For Sale' Electronics / Lighting / Audio
58
Mar 4, 2013 11:29 AM
TACH_MOTOR_WORK
94
Nov 11, 2012 03:16 PM
TACH_MOTOR_WORK
EvoX 'For Sale' Engine Internals and Drivetrain
11
May 21, 2011 08:48 AM
