Removing my AC
Removing my AC
I"m trying to find out what I need to do to remove my air conditioning. Do I need to do something with the belts that are driving the AC?
Has anyone done this ?
-Kyle
-Kyle
Kyle go to mitsu and get the 04 RS Non AC Serp belt. if they cant figure it out we got one here.
where ur pulling the stuff under the dash pull the dash itself out. there are a TON of little brakets and braces that can be removed. about 50 pounds worth of crap under the dash.
I'll check with them. Do you sell the belt?
50lbs on top of the A/C components in the engine bay ?
-Kyle
Originally Posted by idriveaevo
idk but if you wanna sell the parts ill take the condensor....
I'll PM you if I decide to sell
-Kyle
kyle under the dash is where the weight is. as far as we found. if its going to be a track car just pull all that stuff out. if you want to keep the heater/ac ducting just the front stuff is heavy
what did you get your time attack evo down to in terms of weight?
-Kyle
Originally Posted by mike1023
hey kyle let me knew maybe we both can do this at the same time or i help with your and then we do my. woot i have the belt already. autozone spiecal lol
How much was the autozone special part??
Kyle
Originally Posted by kingkyle
Yeah that sounds good. I was going to have my local shop do it so i dont screw anything up.
Kyle
Kyle
i got it a long time ago, i belive it was under 30. and i had called parts for the rs size but i never took out ac yet, but if you want to do it togther cant be that hard lol. just need new fluids becasue radator comes out, to get the other stuff out and will make it easyer to work on.
Cool...
-Kyle
-Kyle
if autozone has a belt... get it.. the mitsu one was 55 our cost. (our dealer discount blows nuts, even though they come over here with tech questions the MF)
sub 2800 for sure..how far under i really dont know right now. motor is out of the car. when it goes back in we will have some numbers. the car is WAY lighter than it was at CMP 2802lbs wet. thanks mainly to a new cage, a bunch of lexan, and some new dry carbon parts for the front and rear. only weight we added to the car was the air jacks.
Do you have access to the Lexan windows? are they custom? I'll buy!
-Kyle
I can have them made for you. no problem, the only thing is we removed the little rear windows in the back and made it one piece. We are taking the car back over to do a new rear window and can have them make a new full set for your car. using ours as a templet. PM and let me know what your looking for.
-Kyle
-Kyle
