Has anyone ever put their NOMEX fire suit in the washing machine?
Old Aug 4, 2008, 03:43 PM
talentsearch301's Avatar
My SPARCO suit needs cleaning... I just dont trust the local drycleaner...
SPARCO says ...recommends dry cleaning but can machine wash...
What do you do?????
Question:
How do I clean / wash my firesuit?
Answer:
Sparco recommends dry cleaning your suit to preserve the life of your safety garment for as long as possible. Your Sparco Race suit should be treated with the same respect as your Sunday Suit. After each driving session, please remove the suit whenever possible and hang dry to remove moisture and to prevent grease/oil from staining the suit while working on your car.
Washing instructions: If you wash your suit, Sparco recommends hand washing or washing it on a delicate cycle in the washing machine with COLD water. Please make sure that the belt and collar are closed on the suit, to prevent the velcro from causing damage to the nomex fabric. Woolite soap is recommended as it is a non-abrasive detergent. DO NOT use bleach or anything similar. When drying the suit, always let the suit drip dry, indoors (out of the sunlight).
Old Aug 4, 2008, 03:50 PM
EvoRicer's Avatar
well when i was a firefighter we threw our nomex hoods and nomex gloves into the wash whenever it needed cleaning. still battle fires like a champ! well use to anyway...im not a firefighter no more...but i miss it...
Old Aug 4, 2008, 04:41 PM
Richard EVO's Avatar
Wash it in Molecule, which is made for the purpose and when you put the post wash spray on it improves the fire resistant properties. I don't work for Molecule company but I have used it.
http://www.moleculelabs.com/Faqs.html
Old Aug 4, 2008, 06:14 PM
thanks
Old Aug 4, 2008, 06:20 PM
Barfly30's Avatar
Originally Posted by talentsearch301
Washing instructions: If you wash your suit, Sparco recommends hand washing or washing it on a delicate cycle in the washing machine with COLD water. Please make sure that the belt and collar are closed on the suit, to prevent the velcro from causing damage to the nomex fabric. Woolite soap is recommended as it is a non-abrasive detergent. DO NOT use bleach or anything similar. When drying the suit, always let the suit drip dry, indoors (out of the sunlight). [/I]
That's what I do after every race weekend. No problems.
Old Aug 4, 2008, 08:57 PM
DaveK's Avatar
We do the handwash method every couple of races.
Dave
Old Aug 5, 2008, 07:44 AM
jid2's Avatar
I use the machine on cold with the delicate cycle. Hang to dry. You'll be fine.
Old Aug 5, 2008, 07:58 AM
Every weekend? Every wash takes out some of the fire retardant properties. That's a bad idea unless you are going to buy a new suit (or two) every year.
Old Aug 5, 2008, 12:29 PM
CleverUserName's Avatar
your suit will be fine.
Old Aug 5, 2008, 02:43 PM
Barfly30's Avatar
Nomex is a thread material, not a chemical that will dissolve in the wash. Sure, the thread can degrade with excessive washing cycles just as it can with extended use. There was a recent article in either SportsCar or GRM which covered this topic. Washing on delicate cycle with a light detergent and hanging dry will not damage your suit and in fact may be preferable to drycleaning if there are any oil based stains on the material.
Old Aug 5, 2008, 02:50 PM
fimotorsports's Avatar
I have sent mine to the dry cleaner and they shrunk it... luckily the suit was a little big otherwise I would have to buy another one. I have put it in the regular wash on cold and let it air dry worked out perfect
vassili
Jun 6, 2009 09:15 PM
tookinkee
Apr 4, 2008 10:39 AM
Jameson_IXMR
15
Feb 7, 2008 02:21 AM
WangMan
18
May 16, 2006 06:28 AM
Quick Reply: Has anyone ever put their NOMEX fire suit in the washing machine?
