oil temps/pressure at the track?
i do HPDE all year. summer temps get above 100*F.
what is a safe oil temp and pressure to run? i occasionally do the full, 20min sessions. i've added temp and pressure gauges to keep an eye on things.
engine is an OEM build with King standard bearings for mains and rods. i don't rev the car above OEM limit (though i can), if that matters.
i've searched because i'm 99% sure i saw a thread on this.. but i can't find it. any info or links would be hugely appreciated.
thanks, in advance.
thanks, in advance.
180-200 is ideal. Good oil can deal with 250-300, though I wouldn't do a 20 minute session at 250+ the whole time though. If you consistently see 250* oil temps, I would consider a cooler upgrade..
Pressure is dependent on throttle and rpm, so not sure you'll have a number to shoot for, it really varies.
I agree with what letsgetthisdone said about the temps. Personally, my evo tends to not get over 230, even on 100 degree days. I would definitely take a cooldown lap mid session if I saw temps over 250 routinely.
You want temp at the pan because that's what the bearings see. I've been running 250 lately which I'm not happy about, but I dinged my oem cooler 2 events ago. Going to a 25 row setrab over the winter...I can only get 3-4 laps before I hit 250 and have to back off for two laps to get back to 240ish. Waiting on an analysis of amsoil 10w40 to come back...
Oil temp will high right after the pump (or low if it goes through the cooler first). Need to measure it in the pan..
I don't think changing the location to the pan is needed. Its 5-6 qts of oil going full chat, its going to get hot over time. Even if it is a small difference in temps I wouldn't want some wire/sensor hanging that low. If you are running thick oil for track days and it gets to around 275* its time to take a cool down lap.
Its more important to focus on oil pressure then temps if you are running slicks. Having a good pan or an accusump is a bandaid for the right hand corner/oil starvation problem with the platform.
Sidenote running a ralliart 71* Celsius Tstat will also help to keep temps down for track days .I went from running 190-192* to 175-180* with it for the most part. I've run my car at 450whp and 10 minute sessions and its gotten to 200* water and 250* oil with an ams pan and R comps fwiw.
This link has a lot of information in it.
https://www.evolutionm.net/forums/mo...on-thread.html
i don't run too think of an oil as all my clearances are OEM, so kinda tight. to be honest, i've never run heavier than OEM weight oil. i've never had a gauge to see pressures, though.
i only run street tires. Hankook R-S3, to be specific. no crazy G forces here. my pan is OEM with a baffle welded in. it's a simple circle welded around the pick up (Buschur). better than nothing, i figured.
i've tried a cooler thermostat, but i couldn't keep the car at temps for closed loop operation, so i took it out (i drive it on weekends, etc).
i'll check out that link now. thanks!
If you want to go the oil filter route you can use something like this: http://www.lancershop.com/customer/p...?productid=330.
Been running that for years. On the temps, I was hoping to see it on my videos, but the guages angle to the driver and away from the camera so it's hard to see.
The wire doesn't hang as low as you think out of the pan. I pulled it taught up top and ziptied it to the abs pump, it's not even the lowest object, but now i run the splitter all the time which acts as a skid plate too so zero worries. I have seen 20 degree difference when measuring in other than the pan.
