Evo X front brake swap for Evo 8/9
#32
I'm so thankful to who open this thread because open my eyes.
Looking forwards,Will the (F97ZG02-23F7E) Alcon EVO X Advantage Extreme Front Kit 365x32 fit Evo 9?
As far as now I know what change is only the caliper brackets with a larger hole\bolts: 12mm(evo9) to 14 mm(evo X).
enlarging the mounting holes in the stub of evo IX to 14mm will made the Alcon evo X kit compatible on my evo9?
thank you
thank you
besk (Feb 3, 2017)
#35
The Evo X oem brakes will bolt onto the Evo 9. All you have to do is drill the hole in the knuckle larger to fit the larger caliper bolt. So an aftermarket brake kit will also fit, you just need to drill the mounting holes in the knuckle to the larger size.
#36
If yes you did only around the sleeve circumference in the 2 faces because you can't do it for the internal surface and i'm afraid won't be strong enough..will be great to see few pictures
other cheap solution should be replace the knuckle assembly if you are lucky enough to find a used one
#37
it would be just a sleeve to center up the smaller bolt for the bracket. the torque of the bolt is what holds the bracket in place. the sleeve wont be a structural part once the bolt are torqued down.
wilwood makes sleeve for their bbk to fit different application with one bracket.
https://www.summitracing.com/parts/wil-300-6347
besk (Feb 17, 2017)
besk (Feb 17, 2017)
#43
What kaj mean by "come upon" is that he can snag them for $100...LOL
#45
I googled "Evo x front brake caliper" and this came up...lol
http://www.ebay.com/itm/like/2920238...&ul_noapp=true
