Curb weight reduction
Old Feb 18, 2017, 12:44 PM
  #76
V.8MR's Avatar
Originally Posted by Dallas J
For those of you who think about this whole weight reduction thing, is there something in the engine bay that isn't available but definitely needs a lighter version made? Like, is the PS or Alternator bracket exceptionally heavy?
Looking for new things to make lighter/better/stronger and this is probably the crowd that has ideas about it.
Def any steel brackets including the intake manifold bracket. There is a lot of weight in just that stuff.
Or make a ACD pump relocation "kit" with some nice brackets for the passenger side trunk aft of the wheel.
Old Feb 20, 2017, 07:23 AM
  #77
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Just delete the intake manifold support. It's not needed.
Old Feb 20, 2017, 04:34 PM
  #78
V.8MR's Avatar
I'm on the fence. I also want to run a phenolic spacer/gasket so was thinking the extra support could help keep it square and help prevent a leak.
That is if I can find the spacers they used to make. MAP no longer carries/produces them.
Old Feb 21, 2017, 08:43 AM
  #79
heel2toe's Avatar
Yeah get rid of the IM bracket! I havent had one on my car for years now and also have one of those phenolic spacers and AFAIK mine isnt leaking. I can validate that my IM has yet to fall off so I think its fine.
Old Feb 21, 2017, 09:57 AM
  #80
The stock IM is light. Guys run the heavy sheet metal and bigger aftermarket cast mani's with phenolic spacer and no support. It's fine..
Old Feb 21, 2017, 10:28 AM
  #81
V.8MR's Avatar
Good to know. Thanx
Old Feb 21, 2017, 11:33 AM
  #82
kaj
kaj's Avatar
I pulled off that bracket YEEEEEEEEEEEARS ago. It's really, really in the way.
Old Feb 21, 2017, 11:41 AM
  #83
heel2toe's Avatar
That bracket sucks! My buddy still has it on his car. I hate him. That is all
Old Feb 21, 2017, 12:32 PM
  #84
Dallas J's Avatar
DSMs had that same stupid bracket that everyone threw away immediately.
Old Feb 21, 2017, 04:28 PM
  #85
RJones's Avatar
Mine has been gone for a while now... I also have a phenolic spacer. No issues.
Old Feb 21, 2017, 04:37 PM
  #86
V.8MR's Avatar
While on the subject, which one do you guys run? I wanted to use the one MAP made but no longer available. Will be doing full EGR delete and head pluging.
Old Feb 21, 2017, 04:42 PM
  #87
ER has one.
https://englishracing.net/collection...spacer-evo-8-9
V.8MR (Feb 21, 2017)
Old Feb 22, 2017, 07:44 AM
  #88
Balrok's Avatar
STM does too.
Old Feb 22, 2017, 01:05 PM
  #89
V.8MR's Avatar
Was looking for the non "thin plastic" one which I believe is what STM sells. The MAP and English ones are thick and use a diff material.
Old Feb 23, 2017, 02:21 PM
  #90
EvolTweetyBird's Avatar
Since we have to have a "working" HVAC system per se, to run our class at Grid Life, you have to sometimes think "in the box" so to say, to cut weight. I kept the heater core and have the system set up to run defrost. Shaved 5 1/2 pounds out of everything not needed in the evap case by itself. Will more then likely be able to shed some more from the blower housing.
kaj (Feb 23, 2017)
Quick Reply: Curb weight reduction
