55 pounds is equal to how many gallons? - evolutionm.net
New Off-Topic Open to all members. Talk about daily events, or other items not really related to the Lancer and Lancer Evolution in any way.
Thread Tools Search this Thread
Old Mar 14, 2005, 03:13 AM   #1
Derek888's Avatar
Drives: EVO 8
16 oz =1 pound? so is it 6.8 gallons for 55 pounds? If that is correct then the price for 6.8 gallons of methanol is only 18 bucks where I live.
Offline
Old Mar 14, 2005, 04:32 AM   #2
Kelmar's Avatar
liquid (measurement) ounces are measured differently than weight ounces (if that makes any sense)
Find the weight of methanol and you shall have your answer [/philosophical moment]
Offline
Old Mar 14, 2005, 08:30 AM   #3
Drives: 04 evo
water tips the scales at 8# per gallon, and i would assume that methanol is a little bit lighter, but not much.
Offline
Old Mar 14, 2005, 08:32 AM   #4
pgmike's Avatar
Drives: 02 1.8T, 98 Land Rover, 03 OZ (blown)and 05 SV650
somebody didnt listen in science class in 7th grade
Offline
Old Mar 14, 2005, 09:00 AM   #5
El Jefe
WestSideBilly's Avatar
Drives: POS
55 lbs is 8.3 gallons. Usually sells for about $10/gallon here. $18 for a 55lb drum would be pretty damn cheap.
Offline
Old Mar 14, 2005, 09:25 AM   #6
Derek888's Avatar
Drives: EVO 8
Quote:
to be exact its 25kg for 18 bucks of methanol which is about 55 pound
Offline
Old Mar 14, 2005, 10:37 AM   #7
PDXRalliArt's Avatar
Drives: E85 tuned 05' WRX
"Density" or weight per gallon of pure methanol is 6.63 lbs/US gallon.
Offline
Old Mar 14, 2005, 11:03 AM   #8
El Jefe
Drives: POS
Which, coincidentally, when you multiply by 8.3, leaves you with 55.
Offline
Old Mar 14, 2005, 11:37 AM   #9
BigNumber12's Avatar
Drives: threads off-topic
Billy, how many hectometers are in a kilojoule?
Offline
Old Mar 14, 2005, 05:16 PM   #10
pgmike's Avatar
about eleventeen, but that is if it is in a vacuum
Offline
Old Mar 14, 2005, 05:59 PM   #11
nasdale's Avatar
Drives: 2001 Chevy Silverado, 2006 Harley Springer Classic
The weight of fuel per gallon depends on the temperature and I believe the altitude. For everyday use it won't make much of a difference, but for racing it can play a role in figuring amount added and fuel mileage. I worked in NASCAR, Busch Series, for 3 years as a catchcan man and gasman and we would get the weight every race when we went to fill the dump (fuel) cans before the race. We used scales to measure the amount of fuel in each dump can. We also recorded the amount the fuel pumps showed when we got the cans filled but they aren't 100% accurate. I was looking through some of my old racing notes and found the base number for the racing fuel we used (Unocal 120 octane) was 6.0 pounds per gallon. Chicago Raceway on 14 Jul 01 it was 5.95 pounds per gallon and Memphis Raceway on 14 Oct 01 it was 6.016 pounds per gallon.
P.S. If anyone is looking for a Gasman for a race team, email me!!!
Offline
Thread Thread Starter Forum Replies Last Post
55 gallon drum for e85? Evoaddicts Evo General 2 Apr 16, 2013 05:04 PM
Dyno tuned the IX tonight, 393/340 - "Lana" neonglh Evo Dyno Tuning and Results 46 Jun 9, 2010 11:39 AM
55 gallon drum of methanol injection with 30-35 gallons typac69 Midwest Region 21 Sep 27, 2009 11:22 AM
Looking for 55 gallon clean drum, also.... tnt1106 South Region 24 Dec 5, 2008 07:08 AM
BR EVO X, weight information. David Buschur Evo X Engine / Turbo / Drivetrain 18 Mar 5, 2008 09:02 AM
Tags
55, altitude, equal, evo, fuel, gallon, gallons, gas, hiw, lbs, methanol, pounds, quarts, racing, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
