TWM Shifter Cable & Transmission Arm bushings
yeah u gotta grease em. shouldnt do dry or ungreased underhood bushings to the stock components either. I prefer bearing bearing grease, it is heavier than the white lithium and trans assembly lube, & will stick around under high heat applications- since it does not go inside the transmission nor make any contact with fluids it's okay to use on those bushings.
Kracka
83
Jan 20, 2017 12:54 PM
TWM Performance
EvoX 'For Sale' Engine Internals and Drivetrain
230
Aug 26, 2016 01:16 PM
TWM Performance
Oct 13, 2011 11:18 AM
Golden
Jan 27, 2011 10:03 PM
