SRS light
SRS light
Need help with resetting my SRS light. It's been on for the past couple of months and thought it was about time to get rid of it. I called around to a couple of dealerships and they want to charge $250.00 just to reset the light. Apparently, they need to check the whole system and make sure that it's okay to reset. I know there is nothing wrong with anything. Does anyone know how to reset it?
Yeah the only thing the light is on for is to tell you that hey something happened and you should check the system, it doesnt mean it will not deploy. Its just a pesky light. Mine came on when I unplug the yellow sensor on the drivers side and forgot to plug it back in and I started the car and now it wont go away. Today I might scan my car at work and see if I can clear it. Otherwise I just ignore it and drive around w/ it as it doesnt affect anything else w/ my car.
You may have already tried this, but if not disconnect the battery and step on the brake pedal a couple times to disapate any residual charge in the system. leave the battery disconnected and check all the srs connections. obviously fix any issues then reconnect the battery. the system should've reset itself and unless there's still a problem the light should go off.
I've never heard of this actually working, have you done this yourself??
Wasn't evoscan promising srs support for future updates.
I think they have one for Subaru
