1992 Mitsubishi Evolution 1 GSR w/ Rally Prep in Mint Cond WTT/WTS
Sold.
(Located in Issaquah, Washington)
Changes since last posted: Radiator cooling plate removed. Fog lights removed. New clutch, new fluids, runs smooth. Still has old rear diff gravel settings (grips hard on streets, reccomend taking to the shop to adjust clutch plate if used on street).
Update: Dropping the price to 15,800 w/ out coils. 16,800 with. Making a real effort to unload the car before I'm gone.
(Price dropped to 16,800 w/ out coilovers. With coilovers: 17,800 (OBO). KYB Gravel Rally Struts/springs still included)
1992 Mitsubishi Evolution 1 GSR (Yes, the real deal.. imported over from Japan. All modification list/miles on parts is listed below pics) in Aspen White Color. Only reason for selling is I'm about to leave on a 6-year stint w/ the Navy (if it doesn't sell by March 24th, it's going in to storage) and it's somewhat impractical for me to store it for that long, and I want it to go to a good home. Note: the price being asked is far less then I've already put into services, modifications, & paint. I may be willing to haggle on price if I drop some parts or you give me fantastic fellatio!
I will be changing the rear LSD settings here soon to grab less to make it more tarmac friendly. Currently set for Gravel.
I will entertain trades of 04+ STi's... assuming their condition is good and a re-sale price is on par with what I'm asking for the evo. I have a bag full of receipts I can provide for services, work done, etc.
Comes with everything listed in the modifications table. Compression is even and high, leak down tests came out flawless, and engine runs beautifully. Car was recently painted black interior and Aspen White exterior. It was sanded down, 2 coats of primer, & 2 coats of poly-u paint with an additional clear on top... very tough paint, and was done well. As the mod list says, it also included 3 sets of wheels & tires (street, winter, gravel)... and another set of bomber-proof gravel rally struts/suspension (recently refreshed).
Modifications:
Lancer Evolution GSR CD-9A (October, 1992)
Engine (evo 3)
Transmission
Suspension
Differential Gear
Exhaust system & Air cleaner
Clutch
Brakes
Rally Gear
Interior
Others
Contact me here or at: erichk@live.com if you have any questions. Thanks.
Modifications:
Engine (evo 3)
- * Forged Rebuild by ALEX (4,375 miles ago)
- - JE piston rings, thrust bearings, main bearings, front & rear main seal
- - Mitsubishi Evo new turbo Evo 3 (TDO5-Big 16G)
- - Power Enterprise 1.5mm metal head gasket
- - Power Enterprise timing belt and balance belt
- - Rally Art engine mounts
- * NGK racing spark plugs (replaced 400 miles ago)
- * NGK racing spark cables
Transmission
- * Rebuilt by ALEX (4,950 miles ago)
- - Mitsubishi ALL new bearings, synchro-mesh rings
Suspension
- * Replaced stabilizer and lower arms from CD9A (Evo 1) to CE9A (Evo 2, 3)
- * KYB Rally / Gravel springs
- - Front: 4.2kg/mm
- - Rear: 3.5kg/mm
- * KYB Gravel shock
- - Front: Rally Special
- - Rear: Rally Special
- * Rally Art suspension upper mount bushings
- * Rally Art front tower bar
- * Rally Art rear tower bar
- * Cusco Type 2 lower arm bar
- * Jspeed (Car Station Marche) fender braces
- * Cusco Zero-2E coilovers w/ Cusco Econ (currently uninstalled)
Differential Gear
- * LSD with ALEX custom setting
- - Front: Cusco LSD RS 1 way 4,000Km (4,500miles) ago
- - Rear: Cusco LSD MZ 1 way 3,500Km (4,188miles) ago
- * Evo RS front LSD conversion parts
- * Evo RS rear LSD conversion parts
- * Fujitsubo RM-01A Exhaust system
- * Fujitsubo racing down pipe
- * After market stiff muffler bushings
- * M's air cleaner
Clutch
- * Cusco Hyper clutch cover
- * Cusco Hyper light weight metal clutch disc
- * OS Giken light weight fly wheel
- * Knight Sports stainless steel mesh clutch hose
- * Mitsubishi new clutch master cylinder
- * ALEX stiff clutch pedal bracket
Brakes
- * Brake pads
- - Front: Delphi Lockheed ZR (for racing track)
- - Rear: Delphi Lockheed MT (for Rally and Auto-X)
- * Brake calipers Rebuild by ALEX 3,000Km (3,875mile) ago
- * ALEX brake piston position helper springs (inside of the front brake calipers)
- * APP stainless steel mesh brake hoses
- * Cusco brake master cylinder stopper
- * Mitsubishi new hubs and knuckles
Rally Gear
- * SAFTY21 (Cusco) 14 points CDS roll cage with
- * SAFTY21 roll cage sleeve (order made)
- * SAFTY21 (Cusco) A and B pillar reinforcement plates
- * Carrosser (Cusco) front skid plate
- * Carrosser (Cusco) gas tank guard
- * Carrosser (Cusco) differential gear box guard
- * Carrosser (Cusco) Rally mud flaps
- * ARP Extended Wheel Studs
Interior
- * Driver side
- - SPARCO Corsa 2000 model black seat
- - LaStrada Rally Super Low position seat rail
- - Sabelt racing seat belt (3 inch / including shoulder pads)
- - Carrosser (Cusco) Rally foot rest
- - ALEX custom eye ball mounts for 4 points seat belts
- * Passenger side
- - SPARCO Evo2 2004 model black seat
- - Sabelt racing seat belt (2 inch / including shoulder pads)
- * Sparco Safari Suede 350mm Steering Wheel
- * Rally Art manual shifter bushing
- * RAZO WRC style shift knob
- * Rigid Alpha break and clutch pedal covers
- * AC, CD, speakers, radio units and floor cover are removed
- * Blitz turbo timer
Others
- * Mine's race tuned ECU
- * YOKOHAMA ADVAN A035 (195/65 R15) tires
- * 5Zigen FN01R-C 17x8 wheels with Falken Azenis RT615 225/45R17 tires
- * Mitsubishi Lancer Evolution 3 stock OZ white wheels
- * Mitsubishi Lancer Evo 15" rims on Gravel Rally Tires (Rims are Mint, tires have some use)
- * Power Enterprise MAG Power 2 oil filter (changed w/ every oil change)
- * Mitsubishi cam shaft position sensor 600Km (375mile) ago
- * Red Line transmission, T-case and LSD oil (WD-90, & Heavy Shock), AMSOil Engine (10w30)
- * Evo MR Bypass Valve
- * ASI 50mm Aluminum Race Radiator + ASI Hoses
- * SuperPro Rear Control arm, Trailing Arm & Rear Sway Bushes
- * Rear Control arms reinforcement plated (by Speedware)
- * Sparco Hood Pins
- * Cusco Cooling Plate
- * Underbody recently sprayed w/ rust protectant.. any signs of rust have been sanded down and sprayed w/ anti-corrosive coating.
Bumping it up for another run at the money. We'll see if I can get it sold for this price. Already losing quite a bit of money on my "investment".... but alas that's how these car deals work
nice car, can the car be registered? How many events in has it entered? Was the conversion done here or in Asia? Used to have a Group A spec'ed E39A set up for tarmac, full HKS equipped.
Car is titled & insured. It's only gone through 2 light rally-crosses... not stage rally mind you... and it wasn't beat down by any means. The Shop where most of the major work done was in by "ALEX" in Japan.
