4g93 wich rom for turbo???
hello everyone, i have a question, i have a mirage 4g93 with turbo and i want to run the H8 ecu, ok in other forum they told me this:
What year is your Mirage? Is it MAF or MAP? USDM?
The easiest solution might be to use a DSM ecu or just flash your ecu with a DSM rom.
(Do not try to flash the DSM rom until you are 100% sure they are compatible, or you could possibly brick it.)
If you have a MAF, H8 ecu Mirage, the ecu connector/wire should be the same.
Making the DSM rom pretty much plug and play, after you copy some maps over from your Mirage rom.
MY QUESTION IS: where to find those DSM roms??? any special setting to run the 4g93 engine with this maps??
thanks for any help
thanks for any help
thanks everybody... (yeah right) one or two people help me on inbox. after that i can help here saying: for mirage ls 1.8 use the ceddymods 20550011 speed density rom, change the injectors cc & dead time for the injector that is in your project, use the ignition timing of mirage ls and then lower until 15 grades for turbo aplications!!! good luck
Alchem1st
Mar 15, 2022 08:47 AM
