Winter wheel/tire combos
If you could pick a good winter wheel/tire combo, what would it be? I'm not too interested in keeping the lowered look, but more concerned with traction and control. The fall is coming and I want to get a new set to swap out for winter. We get some good snow here in Kansas and last winter brough the "Blizzard of Oz." I had my Tacoma last year, so the winter wasn't an issue. But with the O, I really want to take advantage of the AWD and have some fun. Just not at the expense of the stock A/S tires.
I've been on tirerack.com researching combo sets, but can't decide on a larger tire on a smaller wheel, or keep the 18 diameter......
My winter setup: For the CAR this past winter. I like a little more side wall for something "winter" or off road, so the 18's come off the car in Winter and the 17's go on. You may be able to save some coin too since 17's are easier to get than 18's and up unless you get some used wheels. You know what our Midwest weathers are like, Narrower is better with a ride this light and under powered.
Elbrus I05 wheels (not ice coated), 17x7.5, +45mm offset, 6.02" back spacing, (5x114 bolt pattern of course)
Wheels were on sale at Tirerack.com for $85 a piece, and come with lugnuts, lug adaptor, centering ring and center caps. NOTE: since these are just winter wheels I am not using TPMS sensors. By law now, NO shop will install wheels without them if your vehicle is using them as standard. You will have to put them on your self.
Tires, General Altimax Arctic (non-studded), 215/55R17 size.
4 star rating from tirerack.com I commute on interstate and hywy for work, so having a tire that has good road manners for the usually clean and dry after plowing is a must. This tire is rated high by commuters. Still great to get you through the side street crap left by incompitent road crews. $121 per tire at the rack.
Total for setup mounted, balanced and shipped. $950.39 from tirerack.com
The specs are:
- 16x6.5"
- 46mm Offset
- 67.1mm Hub Bore
- 5x114.3 Lug Pattern
- 12X1.5 Lug
- P215/70R16 OEM Tire Size
Those rim specs are the MOST common rim specs across the board. TONS of passenger cars and CUV's use those exact specs, so you should be able to find a set for dirt cheap. Just for some examples, I got a set of Hyundai Sonata rims in like-new condition, no rash at all, for $80. mRVRsport grabbed a set of rims from a junk yard (they might have been steelies, I don't recall) for I believe $10 each.
Also, 16" tires are a LOT cheaper than 17" or 18" tires.
So, in conclusion lol, a 16" setup will fit, keep your speedo correct, can be had for a low cost, and you can easily find some decent looking alloy rims off another make/model of car.
I'm not sure what tires they used in this video (I'm going to assume it's stock tires - whatever they have for Russia, that is) - it does show our 4WD quite capable running around on some fresh powder/snow at speeds >
I'm sure the skills of the driver comes into play (some) and the video showed the ASX drifting around some corners while avoiding the trees lining the trail.
Unfortunately, I don't understand what the guy is saying. Guess I'll have to ask my wife to translate the Russian for me.
Mitsubishi ASX / TopGear Ð*оÑÑÐ¸Ñ - YouTube
I think I heard some diasppointment in his voice at the end. They should have drove a Mazda instead.
I'm thinking of using the studded snow tyres I have for my Montero, they're 235/75R15's so if I get a cheap set of steels it might just work albeit 4% faster on the speedo.
Just wonder about clearances as it will be an inch larger overall.
I ski a lot during the winter which is the only reason I have the set, we don't get harsh winters here in Portland...normally
Feedback appreciated!
No idea but I did notice that the 2011 ES came with 16'' as standard so was hoping a 15'' might work at a stretch. The alternative is I sell these and get some new ones and just have the tyres swapped from the wheels every season.
Would be nice to have a winter tyre and wheel set up though rather than having to swap tyres.
I had the factory 18's and the semi-crappy goodyears they came with on my car the last two winters. In several storms with 1ft+ snow on the roads I experience minimal issues. Only a few instances where I lost the rear end in a turn, which was easily corrected, or had to make a few attempts before getting over a snow drift. Never got stuck or high-centered once. I love the clearance of this car in the winter.
I read a long-term review of a ralliart once that said the 16" factory wheels + Blizzaks took the car from tolerable to dominant in the snow. I'd probably do that as a winter setup if I didn't want to use my 18's. I'd have to imagine the 18's give you more clearance, though.
I planning on purchasing a used set of 215 /65 R16 Michelin X-Ice2 and Steel Rims. They were for a Subaru Forester 2010, and the offset is 48mm which is 2mm higher. Would that cause an issue?
Nevermind, bolt pattern's don't match
